Easy method to grease the clutch fork ball
Discussion in '4 Cylinder' started by iroh, Oct 7, 2015.
  1. Oct 7, 2015 at 11:00 PM
    iroh
    iroh [OP] Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I hate squeaking. It makes my Toyota sound like a (insert your despised domestic of choice). I really had hoped I had this licked when I pulled the tranny off last year and got the fork/ball/new throwout bearing all clean and greased. Well, gosh darn it, 10k miles later and my moly grease was apparently not up to par.
    Note, this is for the super duper clutch squeak that some of us get; not that wimpy creaking that comes from the plastic on the pedal under the dash, like so:
    (video from last year, but it sounded almost this bad again already)
    https://youtu.be/1AWqhYEu_zY
    Woah, not the way I like my truck to turn heads. I could hear it with every shift... how annoying! Let's fix it.
    Things needed:
    -3/8" ratchet with 12mm socket
    -grease rag
    -good grease in a tub or tube. I'm trying high-temp wheel bearing grease this time
    -drinking straw, get one for free next time you go to Mickey Ds
    -scissors
    -portable light if you're doing it in the driveway at 1am like me
    -I can't stand beer but some people work better with it
    So first thing to do is make sure the truck won't roll over you so chock a wheel, set the ebrake, and put it in gear. Engine off, duh! Grab that ratchet and crawl under the truck behind the driver's side front tire. The top of the clutch slave cylinder has 2 bolts on the top you can't really see, take 'em out and move the slave cylinder out of the way a bit. The clutch line can bend a little but don't get carried away.
    With that out of the way, take off the rubber dust boot that's around the fork. You should be left with this:
    Ack. Dry already.
    Take that straw and cut the end twice with the scissors, like so
    Then dip it 1/4" into your tub or tube of grease. That gives you a small blob of grease inside the straw to work with. You shouldn't need (or want) too much in there.
    Note we're not using spray grease. Bad stuff to be spraying around the clutch! Hence the straw.
    I held the fork away from the ball with one hand and snuck the business end of that straw between the two with the other. That ball is only in about 2" from the opening so it's not difficult. Move it around a bit like a paintbrush to get better coverage, then pinch it between 'em and pull to squeeze the rest out. Move the fork back and forth a bunch of times to make sure it's spread well on the ball.
    The straw works great because it can bend into the space you need the grease to go, it's dirt cheap, and you'd have to be really silly to somehow lose it in the bell housing.
    Put the boot back on, put a small dab of grease into the pocket on the end of the fork for the slave's ball (prevents rust), bolt the slave cylinder back up, and enjoy the squeak free ride.
    Easy peasy! Silent shifting again.
    That sure felt like a long write-up for a 15 minute job... oh well, feels good having it fixed (again).
    t1m829, po35042, Marc70 and 9 others like this.
  2. Oct 30, 2015 at 10:56 PM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    Thanks for the post. This looks easy to do. I will try it before it starts raining here.
  3. May 29, 2016 at 5:41 PM
    Utah
    Utah Member
    Utah
    Vancouver BC
    2010 Tacoma 2.7L 4X4 SR5
    Hey Iroh,
    I had the dealership grease my fork ball under their good will policy about 4 months ago. They used some special grease Toyota had used for the under-cariage of a Prius. It lasted 4 months. I'm about to use your method to re-grease, did your high-temp wheel bearing grease do the trick?
    Utah
  4. Nov 12, 2016 at 10:44 PM
    iroh
    michigander
    tonneau
    Yes. Almost a year later the fork was still totally silent. Apparently the grease I had used in '14 when I pulled the tranny was too thin as that stayed quiet about 3 months. The red wheel bearing grease was much better.
  5. Jan 11, 2017 at 1:15 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Sweet. I had been using fluid film which would last about a month each time - I'll try this when the squeak comes back!
  6. Jan 14, 2017 at 4:47 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    If you can find it I'd run some NLGI 3 grease it is much thicker and stays better. If you're in cold climate then run NLGI 2 high temp. I have a preference to Mystic grease the JT-6 high temp NLGI 2 is top notch and has a high drop out temp and low washout characteristics.
  7. Jan 24, 2017 at 3:35 PM
    tunabrad
    tunabrad Well-Known Member
    Brad
    California
    2019 White DCSB SR5
    Still running quiet? I need a permanent fix to this damn noise
  8. Jan 24, 2017 at 3:57 PM
    Taco Pete626
    Peter
    Southern California
    Buy an automatic
  9. Jan 24, 2017 at 4:44 PM
    tunabrad
    Brad
    California
    2019 White DCSB SR5
    But shifting gears is just too much fun
    Dalandser likes this.
  10. Jan 24, 2017 at 4:54 PM
    Taco Pete626
    Peter
    Southern California
    It sure is!
    Yeah, it's just something that needs routine maintenance like lubing door hinges and locks. It sucks, but it doesn't take too much effort to get some sort of lube in the assembly.
  11. Jan 24, 2017 at 8:45 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Even using fluid film once a month has been nice - not that much effort. Makes the whole transmission respond way faster in gear changes too since it's a smooth operation.
  12. Jan 25, 2017 at 12:03 AM
    tunabrad
    Brad
    California
    2019 White DCSB SR5
    I think im going to do it tomorrow, looks pretty easy
  13. Jan 25, 2017 at 12:24 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It made the truck fun to drive again for me - hope it works well for you!
  14. Jan 26, 2017 at 4:51 PM
    tunabrad
    Brad
    California
    2019 White DCSB SR5
    Jut did it, took about 15 minutes and the squeak is gone...now lets see how long it lasts
  15. Jan 29, 2017 at 12:46 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I used PTFE-impreganted grease and a bamboo skewer a couple of years ago and the squeak hasn't returned.
  16. Jan 29, 2017 at 12:46 PM
    2.7taco
    Texas
    Y'all should really try some thicker grease.
  17. Jun 20, 2018 at 2:34 PM
    tunabrad
    Brad
    California
    2019 White DCSB SR5
    anybody have any luck with a long term fix? Been having to redo this every couple months and getting really tired of it.
  18. Jun 20, 2018 at 5:55 PM
    Taco Pete626
    Peter
    Southern California
    hate to say it but.... AT
  19. Jun 20, 2018 at 6:27 PM
    tunabrad
    Brad
    California
    2019 White DCSB SR5
    I guess I'll buy more grease haha. 5 speed for the win!
    luka4600 likes this.
  20. Jun 23, 2018 at 7:47 AM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    stay out of the mud
