Eastwood internal frame coating rust inhibitor
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004TacomaSR5, Dec 23, 2018.
  1. Dec 23, 2018 at 5:04 PM
    2004TacomaSR5
    2004TacomaSR5 [OP] Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
  2. Dec 23, 2018 at 5:08 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I used it on my 04 4runner. I don’t think I’d spray it inside a frame if it was brand new and not rusted. This product is meant to convert rust and essentially paint it at the same time. If your frame is still pristine I’d stick with something like fluid film or any other corrosion inhibitor on the inside, and I’d probably flush the boxed sections of frame real good after winter to increase longevity.
    This reminds me, I have some product leftover that I’d like to test on a piece of rusty metal just to see how it holds up. Right now inside my boxed frame I’m just hoping it’s done it’s job. I topcoated with CorrosionX to be safe.
    Edit; I’ve done a lot of searching on Eastwood internal frame coat and there aren’t really any long term results or pictures out there.
    GQ7227 likes this.
  3. Dec 23, 2018 at 8:58 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    GQ7227 likes this.
  4. Dec 25, 2018 at 7:49 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    I use fluid film on my frame and apply a coat every fall. My frame was replaced in 2013 and still looks like it’s brand new.
    2002Tacoma4x4 likes this.
  5. Mar 16, 2020 at 5:29 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    can you give more info on what you did exactly, the more deets the better!
    starting conditions, pics, process, results after time elapsed, etc.
    these wands do look much better quality than the limp richard FF wands all curled up in a baggie
    i am running into more complicated issues than i thought i was going to run into and am looking for best results, no fks
    970btu and Taco critter like this.
  6. Mar 17, 2020 at 9:05 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    talked with a customer rep at Eastwood about this product
    unfortunately it is not UV resistant so i cannot test its efficacy on clean blasted metal on the outside frame before i spray it inside after removing all loose coating chips :facepalm:
    the service rep said there was a prior comment to their database of a Jeep person spraying this on whatever they have and it does stick well to clean uncoated metal
    but jeep metal may be of different quality than toyota metal :notsure:
    i do not desire to spray this inside only to find it peeling off internally years down the line because of the possible lack of internal rust to adhere and convert/encapsulate
    they do have a newish product called Rust Encapsulator Platinum that is supposed to adhere to both clean and slightly rusty metal
    https://www.eastwood.com/eastwood-rust-encapsulator-platinum.html
    but is not available at the moment in a rattle spray can as the Internal Frame Coating is
    and the bummer, here it comes...
    found several negative dissatisfied comments with the Encapsulator Platinum product on their website
  7. Mar 17, 2020 at 2:33 PM
    RonJon31
    RonJon31 Well-Known Member
    Ronnie
    Alaska
    04 Single Cab Tacoma PreRunner
    5100s 265/75/16 Wildpeaks
    Dude it’s not UV stable because it’s supposed to be on the inside of a frame. If you have UV rays going in there then you have some serious other issues to address first
    970btu likes this.
  8. Mar 17, 2020 at 2:37 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    It can also be top coated, so another point for UV stability irrelevance lol
    970btu likes this.
  9. Mar 17, 2020 at 4:36 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the inside of frame is supposed to have rust for it to properly convert and adhere to, whatever the chemical process is idk!
    the service rep said it will adhere to clean uncoated metal but not loose chips, is a good idea to clean the loose stuff out of the inside
    i just wanted to test it on the outside area to see how well it adheres first to clean toyota metal, maybe spray some under the middle somewhere inner rail and see what it does over a few months time
    and if i will or will not have to resort to flash rusting the inside of my truck frame for it to work properly
    whatta mess!
  10. Mar 18, 2020 at 5:12 AM
    Kansas TRD Taco
    Kansas TRD Taco Active Member
    Aaron
    Littleton, NH
    2002 Toyota Tacoma 4X4, V6, TRD, Ext Cab, 5 speed manual
    I used the East Wood frame encapsulator on my '02 Tacoma and my wifes '05 Lexus last fall, before we moved from Kansas City to the North East.
    I also coated the inside & outside of the frames and underbody of both trucks with Wool Wax in the fall, prior to the snow flying.
    I taped a metal wire to the straw to stiffen it up some, making application easier. It was a cheap and easy fix to the limp & curled straw problem.
    IMO, its a thin product, but covered well and does a good job of creeping into places from what I could see inside the frame. I did two light coats.
    I havent done anything more than a couple quick rinse offs of the frame this winter and everything looks great under both vehicles so far. Will know more of how it held up this spring, once I can give the underbody a good washing.
    GQ7227 likes this.
  11. Mar 18, 2020 at 5:24 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    was that Eastwood Internal Frame Coating sprayed in a replacement frame with all good intact factory coating inside still?
    or is it a different product of theirs you used?
    they have a variety of products all with different yet similar names lol
  12. Mar 18, 2020 at 5:31 AM
    Indy
    Indy Master of all I survey.
    I'm in the process of using it now on a 56 mercury. Im using both the internal spray and the brush on. The internal stuff has no reason to be uv stable. The brush on comes in 3 different mixes, 1 is uv stable and ther others need a top coat. The flexible hose gets around bends fairly easily, has a few exits so the spray goes everywhere. Just put it in all the way and spray as you pull it out, not the other way around. From what I can see it's doing a pretty even application. Then spray some carb cleaner through to clean the hose before it dries. The hose also works on rustoleum cans.
  13. Mar 18, 2020 at 7:04 AM
    Kansas TRD Taco
    Aaron
    Littleton, NH
    The Tacoma had a frame replacement done about 7 years ago. I was not the owner of the truck when it was replaced, so thats an estimate. There was light surface rust on the outside of the frame and inside, but no major flaking.
    The inside of the Lexus frame was worse and had heaver rust as its the original frame and not sure the prior owner washed the underbody as much as they should have.
    I washed out both frames real well with water and let them dry for a week or so before using the internal frame coating. And yes, I used the same stuff you put in the link. The aerosol spray internal frame coating.
  14. Mar 18, 2020 at 11:08 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    I do have a section on the outside under by the bumper that needs blasted to bare metal that is not readily exposed to uv light
    Could possibly spray this on that to see how well it sticks over the next several months before tackling the boxed section
  15. Mar 18, 2020 at 12:37 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    I’ve shot a rusty 4Runner frame interior and a lightly rusty Lexus GX frame (same exact frame basically) and the coat is still visibly adherent inside both. What I do is coat, then come back a week later and coat with my product of choice CorrosionX HD. Fluid film or whatever else would function the same. Point being I don’t just rely on the Eastwood.
  16. Mar 18, 2020 at 1:46 PM
    Kansas TRD Taco
    Aaron
    Littleton, NH
    Same thought and process. Belt + suspender approach....
  17. Mar 18, 2020 at 2:26 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this is what i will be working with to clean out before spraying internally, this old coating looks like its ready to flake and peel idk
    humidity corrosion on the topcoat?? the wimpy primer!? its probably this way throughout the inside
    i might first try some blasts of compressed air before hunting down a water jet with conical nozzle to shred all the loose stuff off
    good or bad idea?
  18. Oct 25, 2020 at 5:47 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    over the late summer i was able to tape a stiff wire to the limp wand and probed deep into this rear area enough to squirt it out through the top hole right here
    [​IMG][​IMG]
