easiest way to fit 33x12.50x16?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fitryders2, Jul 7, 2010.
  1. Jul 7, 2010 at 8:04 AM
    fitryders2
    fitryders2 [OP] Well-Known Member
    shawn
    virginia
    07 trd sport
    hey guys i was wondering which way i can go to get a 33x12.50 on my truck. would the 5100's with a rear add a leaf work? thanks
  2. Jul 7, 2010 at 8:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Mount them to wheels before trying to mount them on your truck.....
  3. Jul 7, 2010 at 8:16 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    RCD, Procomp, or Fabtech basic kit would be the easiest! The best ride, the most suspension travel, and the least fender cutting.
  4. Jul 7, 2010 at 8:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    How do you figure "Most suspension travel"?
  5. Jul 7, 2010 at 8:20 AM
    fitryders2
    shawn
    virginia
    07 trd sport
    what about the cheapest? i dont really need much travel. most of my offroading is in the sand. i just want the truck to sit a little higher and look good.
  6. Jul 7, 2010 at 8:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A drop bracket lift doesnt give you anymore travel than whats stock. Consider looking at a 2.5" to 3" lift set up. The 5100's with OME 885 springs are good, as is a full OME set up, or a coilover of your choice.
  7. Jul 7, 2010 at 8:21 AM
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    [​IMG] That is what the guy at 4 wheel parts told him when he bought his kit
  8. Jul 7, 2010 at 8:24 AM
    toku58
    Mall Crawler!
    Well, I guess the travel essentially stays the same. But the useable travel is better. Because a 3" lift added to your stock suspension, is basically like going hiking in heels. You will loose down travel. (I know not a good example but you get the idea);)
  9. Jul 7, 2010 at 8:25 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    here is mine with 5100's @ 2.5 and a toytec aal in rear with 285/75/16
  10. Jul 7, 2010 at 8:26 AM
    toku58
    Mall Crawler!
    Actually that's what I told the guy at 4WP!:p They really don't know much about these trucks.
  11. Jul 7, 2010 at 8:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok. Travel remains the same though. You just have more upward travel (providing the lift installed allows and the coils dont bind before upper travel limits are reached, I.e., spacer lift). When used with a Uniball UCA, travel is increased.
  12. Jul 7, 2010 at 8:30 AM
    toku58
    Mall Crawler!
    No! Actually the suspension stays the same. The UCA's will allow easier movement, but the stiffer/longer coils is why you loose the useable travel.
    The DB lifts will keep the LCA's at the mid point. So up travel and down travel stays optimum.
    As far as UCA's go I have issues with the designs out there. but that's a different topic.;)
  13. Jul 7, 2010 at 9:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    THe Uniballs have more range of motion than the Ball joints. We have been over this before. More range of motion allows for more down travel.
  14. Jul 7, 2010 at 9:29 AM
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    no such thing as 33x12.5x16....16.5 yes:p
  15. Jul 7, 2010 at 9:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A 315/70/16 is close
  16. Jul 7, 2010 at 9:42 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    3125!? That's a wide tire chris! :D
  17. Jul 7, 2010 at 9:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!! Edit made :eek:
  18. Jul 7, 2010 at 10:08 AM
    fitryders2
    shawn
    virginia
    07 trd sport
    sorry. i had a s10 before this and i had 15s. im just use to saying 33x12.50x15. i was looking at ome or the 5100 set up. they both seem to have good reviews. just when i research it seems like everyone is running something slightly different.
  19. Jul 7, 2010 at 11:27 AM
    peotaco
    peotaco Member
    peoria
    trd offroad
    go with the 33x11.5 with a 5.5 backspacing...the 33x12.5 are going to rub real bad!! and the 11.5 looks awesome...they will stick out of the wells about 1/2 inch.
  20. Jul 7, 2010 at 11:56 AM
    fitryders2
    shawn
    virginia
    07 trd sport
    the most flexing i have to do is over ruts in sand. maybe some mud and trails during hunting season but not a whole lot. the 5.5 backspace would be better then 4.5? i was looking at xd hoss wheels with 4.5.
