Early downshift when braking?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by danoo, Jan 8, 2021.
  1. Jan 8, 2021 at 5:05 PM
    danoo
    danoo [OP] Well-Known Member
    2021 Trail Edition
    Brand new 2021 SR5 V6 4x4. 350 miles on it.
    I have noticed since day one that when I brake it seems to downshift a bit earlier than it should. Somewhere around 20ish mph. I don’t jolt forward but it is noticeable, meaning I can’t smoothly brake to a stop without a little hesitation. Not too concerned about it, just curious.
    I searched here and found a few threads but they were a few years old. Is this normal on the new 2021s?
    I’m not sure if it’s actually downshifting, that’s just the best way I can describe the feeling.
  2. Jan 8, 2021 at 5:26 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    My 2020 does this around 20/25mph when braking. The transmission downshifts and the engine revs up which makes a small vibration felt through the truck. Seems normal for some, I've seen others complain about it as well.
    Chew, danoo[OP] and Junkhead like this.
  3. Jan 8, 2021 at 5:36 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    The transmission learns over about the first 1500 miles. Things are a bit clunky for the first 100-200 miles but it will smooth out. Runs couple of tanks through it and let us know. Low transmission fluid level from the factory was not uncommon in recent years but I don’t think they have the auxiliary tranny cooler since 2019.
    Big tall dave likes this.
  4. Jan 8, 2021 at 5:39 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    It’s called engine braking. Normal. You’ll learn to appreciate it.
    hiPSI, jmneill, Chew and 2 others like this.
  5. Jan 8, 2021 at 6:26 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    “than it should!” What degrees do you hold?
    Tullie D and danoo[OP] like this.
  6. Jan 8, 2021 at 6:45 PM
    danoo
    2021 Trail Edition
    thanks man. I had a typo there. I actually have 350 miles on it. But will see if it smooths out.
  7. Jan 8, 2021 at 6:47 PM
    danoo
    2021 Trail Edition
    I’ve driven enough vehicles to know that I shouldn’t feel a stutter like a downshift as I’m slowing coming to a stop. Why you gotta harsh the mellow my man?
    Thatbassguy likes this.
  8. Jan 8, 2021 at 6:51 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Tundras have had this feature since '07. It saves on brakes. You will soon not notice it unless you are consciously expecting it.
  9. Jan 8, 2021 at 7:22 PM
    s7726
    s7726 Well-Known Member
    2019 DCLB TRD OR Cement
    You're one of the people that made them add "shift points" to CVTs aren't you :rofl:
    koditten and danoo[QUOTED][OP] like this.
  10. Jan 8, 2021 at 7:22 PM
    TacoFritz
    TacoFritz Member
    2020 TRD Offroad 6A SB
    I think it is engine holdback as you slow down and then around 20 mph it disengages. I recall this being noticeable when the truck was new, but it's completely gone now. I think part of it is also the brakes seating in. They definitely didn't feel great new. Much better with a few miles on them.
    danoo[OP] likes this.
  11. Jan 8, 2021 at 7:29 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    They all do it, more noticeable on 2nd gens actually. It's beneficial for performance as it keeps the revs up if you need to get on the gas again.
    danoo[QUOTED][OP] and Chew like this.
  12. Jan 8, 2021 at 9:49 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    ECT uses less engine braking, give that a shot and see if your concern goes away.
    G8R_Taco likes this.
  13. Jan 9, 2021 at 6:19 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    If i'm doing 50 mph or so going down a steep hill with my 2020 and tap the brakes the truck will automatically downshift.
    The ECT mode seems to be a bit of a mystery. It locks out 6th gear when in that mode and in drive. If i disable ect...the trans will go into 6th as normal.
  14. Jan 9, 2021 at 6:46 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    @danoo
    At what point would you expect the "downshift"?
    Why would you expect the "downshift" at your particular point?
    na8rboy, Tullie D and Chew like this.
  15. Jan 9, 2021 at 7:19 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I dunno either
    I'll never understand why someone buys a vehicle with an automatic transmission and then spends their days questioning why a group of engineers programmed it that way. You can buy a manual and shift how you want, or reprogram if you know more about it than them.
    Not trying to be rude, but come on, you accepted someone else's work when you bought an auto. I don't think my auto is absolutely perfect, but I like the way it drives overall, and accepted that way when I bought it.
    na8rboy and philth like this.
  16. Jan 9, 2021 at 8:10 AM
    danoo
    2021 Trail Edition
    Thanks for those who had a constructive answer.
    For everyone else, I just asked a simple question how it seems like there’s more engine braking/a downshift feeling than I expected.
    I don’t have a degree in engineering. I don’t question why the engineers did what they did. Im simply asking if what I’m perceiving is normal. But I guess I’ll go f myself. :thumbsup:
  17. Jan 9, 2021 at 8:22 AM
    zoo truck
    None
    Imo, there's very little felt downshifting, and engine braking effect with the 3.5 compared to my 01 4.7 tundra.
  18. Jan 9, 2021 at 8:33 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    My apologies, I wasn't directing that at you. You're right, the simple answer is; yes it's normal.
    There's a new thread nearly daily about people complaining about the shift patterns, and have all kinds of fantastic ideas of how better them, and how they're gonna push the truck off a cliff, or make Toyota but it back.
  19. Jan 9, 2021 at 8:43 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Dude. Public forum, public will comment.
    The Tacoma is designed to provide engine braking to assist regular brakes. You will feel a downshift when braking and in a few weeks will come to appreciate it, especially when you won't need brake pads for 70K or more. It's normal.
    zoo truck likes this.
  20. Jan 9, 2021 at 8:46 AM
    Knute
    Interesting response. I just asked a couple of questions about your expectations...........
    Hope you come to enjoy your truck.
