E15 gas...good idea or bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Notoneiota, Oct 30, 2018.
  1. Oct 30, 2018 at 7:51 PM
    Notoneiota
    Notoneiota [OP] Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I drive a lot of highway miles and often fill up at Kwik Trip gas stations. They apparently have their own blend of 88 octane that is E15 and about 10 cents cheaper than 87 octane E10.
    My gas cap specifically says no E15-E85. I will admit that I filled it up once with E15 because I was being a cheap ass when gas prices were going up and noticed nothing performance-wise.
    Any idea what long term effects of running E15 might be? Just trying to save a few bucks on my travels.
    I married my tacoma likes this.
  2. Oct 30, 2018 at 8:35 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    saves 10c a gallon for possible significant harm to all fuel system components in a 30k$ truck.... dont let that shit touch your truck again, the fueling systems on these trucks are NOT designed for ANYTHING higher than E10 commonly found at stations (which usually range from around a 5-8% ethanol content, E10 is MAX 10%)
    also... dont bitch about your gas prices.... Grand rapids is ~ 1$-1.10, yes OVER ONE WHOLE DOLLAR LESS per gallon than out here in ventura county california.
    Jimmyh, ABNFDC, Olson and 7 others like this.
  3. Oct 30, 2018 at 8:51 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    My experience, on 1GR-FE, 10% ethanol, 87 octane, no more no less, best. Don't know why, just is.
  4. Oct 30, 2018 at 10:07 PM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    When I have some extra money I really want to try a few tanks of non-ethanol. it actually made a good bit of difference in my previous car so I'm curious to see what it does in the taco.
    PackCon likes this.
  5. Oct 31, 2018 at 2:51 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    We have a pump out close to me that ethanol free, tried it couple times didn't notice much maybe .5 mpg difference to many variables to be sure..but it did run smoother not as noisy.
    armyofsquirrels likes this.
  6. Oct 31, 2018 at 6:06 AM
    jross20
    Georgia
    well I don't recall noticing any economy changes but it definitely made the car a bit more peppy! :)
  7. Oct 31, 2018 at 6:42 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    That's awesome I didn't notice any peppiness my truck has some weight with taller tires an stock gears.
    BassAckwards likes this.
  8. Oct 31, 2018 at 6:43 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    $0.10/gallon difference, on a 21 gallon tank. So even if you run the tank bone-dry you're only saving $2.10 :cookiemonster:
    Long term effects could include premature emissions system component failure, and/or fuel system component failure. They weren't designed/spec'd for long term exposure to those chemicals in these models.
    FWIW, your owners manual backs up what your gas cap says:
    Clearwater Bill and Taco-Grinder like this.
  9. Oct 31, 2018 at 6:49 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Stick with the e10 or less. The more ethanol in the fuel, the more fuel flow that is required to maintain the same safe AFR. Many high performance vehicles use e85 ethanol for the 110octane rating, but you have to flow like 30% more fuel for the Air fuel ratio to be in the safe range. If the truck was designed to run on e10 or less, just use that, it's not worth the 10cents a gallon you're saving to risk having to make major repairs down the road
  10. Oct 31, 2018 at 6:54 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    One thing to remember is how new is that gas. The E10 tanks get filled more often, so you should be getting newer gas. :notsure:
  11. Oct 31, 2018 at 8:37 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    A gas thread :bananadance:
    DustStorm4x4 and smithe3006 like this.
  12. Oct 31, 2018 at 2:10 PM
    jfoster92
    jfoster92 Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    I’ve ran non ethanol in my 08/4.0 for the last year and half at least. I noticed it ran smoother and my fuel mileage was a lot more consistent.
    Boatbldr likes this.
  13. Oct 31, 2018 at 2:13 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    It should be illegal to even sell that crap
  14. Oct 31, 2018 at 2:17 PM
    jfoster92
    Justin
    Farmerville, la
    Crap?
  15. Oct 31, 2018 at 2:22 PM
    Woolybugger
    Woolybugger Well-Known Member
    Aaron
    2005 blk acess cab trd 4x4
    King coilovers
    Don't Know about Tacomas but the higher ethanol fuels definitely rot out lines And seem to cause more fuel system issues in motorcycles. After seeing this first hand I have an aversion to this corny bs.
    Boatbldr and Lawfarin like this.
  16. Oct 31, 2018 at 2:23 PM
    Taco'09
    Taco'09 Well-Known Member
    I ran about 10 consecutive tank fulls of the high octane none ethanol when it first appeared here and have to say that I noticed......nothing, except a hugh price difference. I did not even notice a reduction in pinging and certainly no increase in power. Made my chain saw start easier though...
    Lester Lugnut and TacomaMike37 like this.
  17. Oct 31, 2018 at 2:24 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    E-15. Ethanol is no good for most motors and fuel systems. Kills small engines. Negatives outweigh the positives. My guess is someone’s pockets are getting lined because law makers keep pushing for higher Ethanol content.
  18. Oct 31, 2018 at 2:30 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Higher ethanol content supports Iowa/corn belt farmers. Its a vote thing.
  19. Oct 31, 2018 at 2:39 PM
    jfoster92
    Justin
    Farmerville, la
    Ah. I would agree there. It’s just uncle sams way of being able to say hes doing something to be less dependent on fossil fuels with no real benefit
  20. Oct 31, 2018 at 2:40 PM
    IA Mike
    IA Mike Well-Known Member
    Iowa
    2022 Tacoma Limited MGM
    Custom lightened wallet and shiny new payment booklet
    FWIW...I don't run ethanol anything in any of my gas burning things, old or new. Here in Iowa (yes I live in the corn state and don't like ethanol) there is a $.50/gallon surcharge for non-ethanol fuel. I pay it. At least it is truly non-ethanol; many states have at least some in all fuel. In the old stuff it is asking for fuel-related problems with varnish, seals, etc. In the new stuff, it has a mileage penalty even if the system is configured to tolerate some of it.
    Just filled my truck today and did notice the no E15-E85 marking on the filler cap. While I don't know the exact reason, I suspect the concern is over fuel system seal longevity somewhere.
    Don't want to get into some political thing about it, especially since I live in Iowa. Just too many experiences with fuel-related issues (at a minimum a drop in fuel mileage) to justify the cost savings.
    eherlihy and Blockhead like this.
