E-Type Silhouette SolidWorks Drawing
Discussion in 'Guns & Hunting' started by Hunter.V.White, Sep 20, 2014.
  1. Sep 20, 2014 at 6:33 PM
    Hunter.V.White
    Hunter.V.White [OP] Well-Known Member
    Hunter
    Fairbanks, AK
    2013 DC 4WD TRD-Off Road
    Pelfreybilt Steel Armor, Famous Fabrication Sliders, OME 3" Lift, 886x coils, Dakar Leaf Packs, TC UCA's, Fuel D551 Wheels, 285/70/R17 Toyo Tech RTs, Warn Zeon 10s Winch, Rigid Industries 20" E2 Flood, RI 20" SR Spot/flood, RI Duallys, SwitchPro SP8100, Uniden Bearcat 680 CB Radio.
    Hey TW,
    I just recently got access to SolidWorks again since I left my mechanical engineering program at Georgia Tech. Now I can start designing all of the projects I've been keeping in my head!
    My plan is to make most if not all of these designs available to TW for the good of the forum. I'm sure at some point, I'll be asking for feedback when I get to designing my front plate bumper, enclosed bed rack, and other projects I come up with.
    My first project is was to make a steel target for precision rifles. It will be made out of 3/8" AR-500 steel to hold up to 5.56 and 7.62 rounds. I chose to go with an E-Type silhouette that I will mount on a pressure treated 4x4. My plan is to leave the 4x4 in the ground where ever I decided to set up the range, and then be able to quickly place/remove the target when I want to shoot. I'm going to try and ensure that I can drive to the 4x4 though, because I don't want to carry this plate 600+ meters! The bracket that the 4x4 will slip into is trivial, and as it always happens, I came up with a much simpler, better design (KISS) as I was driving home after printing off the drawing. Oh well.
    The important things are the dimensions of the E-Type silhouette. These were difficult to come across. The most important dimensions are the height (40 inches), width (19.5 inches), head width (8.5 inches) and head height (10.5 inches). These are important for military range estimation with mil-dot scopes or ACOG's. I made some of the rest of them up (radius for the corners, etc.)
    I will post pictures when I get the plate back from the shop!
    Enjoy.
    Target Assembly Drawing.PDF
  2. Apr 29, 2015 at 7:09 PM
    Yota64
    Yota64 Professional Threadjacker
    Looks very nice. You're good with that program. Any progress since?
  3. Apr 29, 2015 at 10:23 PM
    Hunter.V.White
    Hunter
    Fairbanks, AK
    Yep! I've had it built and I've tested it out :)
    It takes a little explanation, but I was sighting in my precision rifle at 250m on this iron maiden. Notice the two shot groups that start at the bottom of the silhouette, and work upwards. I finally placed three two-shot groups into the chest/base of the neck (second picture), decided it was zeroed, and handed the rifle off to a buddy and his girlfriend. That's when the pattern started to "open up". Those two-shot groups are about 1" apart - the gun was holding ~0.5 MOA :)
  4. Apr 29, 2015 at 10:37 PM
    Hunter.V.White
    Hunter
    Fairbanks, AK
    The precision rifle...
    - Krieger barrel; blank turned to my design and chambered in 5.56 NATO, 1/8 twist.
    - Adams Arms piston system
    - Noveske lower
    - Vltor [matched] Upper
    - Giessele SSA-E trigger
    - Leupold 4x12 scope
