E Load Tires - Are they necessary ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by REAL_OG, Jan 31, 2023.
  1. Jan 31, 2023 at 5:33 AM
    REAL_OG
    REAL_OG [OP] Well-Known Member
    All,
    wanted to hear everyone’s thoughts on E load tires and whether they are a must or if C load is acceptable for places like Colorado, Moab .
    I have E load and no major complaints , just don’t know if it’s worth going to C for less weight and road noise but weaker tire.
  2. Jan 31, 2023 at 5:40 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    I would say avoid E load if at all possible. I have E load on my 3/4 ton truck, not on the Tacoma.
    C and D load tires will flex more when aired down, that's what you want. I recommend 12 psi if you are not a high throttle wheeler.
  3. Jan 31, 2023 at 5:45 AM
    Tacoma Rant
    Tacoma Rant I can’t be good all the time.
    Wisconsin
    2023 Tacoma TRD Sport Electric lime
    Agreed, E load tires are overkill on a Tacoma.
    They were great on my Duramax 3/4 ton truck pulling my 33 foot camper.
    ColoradoTJ and ZColorado like this.
  4. Jan 31, 2023 at 5:47 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    What’s your pucker threshold? I “need” E load tires 2-3 days in a year. I also have a road car, but when I want a truck it’s there, when
    I want a play toy it’s there.
    MalinoisDad likes this.
  5. Jan 31, 2023 at 6:13 AM
    REAL_OG
    That’s sort of where I am, I really only need E load 2-3 weeks out of the year when I off-road . But when you’re off-roading off the grid, that risk is not worth it in my opinion but don’t have enough experience off-roading with C rated tires to know they’re just as reliable
  6. Jan 31, 2023 at 6:19 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    I have 33's which are typically E load for full size trucks. Skinnys are hard to find and expensive
    In 30-31in tires, you have more c load tire options for SUV's
    32" tires have some c load options
    I currently use off brand 285's which were $160 each instead of $250-300 each.
    Any gas they eat because of weight is offset by my slow driving and the cost i saved in buying an offbrand.
    Are E load necessary on a tacoma? Hell no!
    The max load The tires are for would crush the tacos suspension.
    However, i have the heaviest made springs and typically overload my truck.
    Also, if you are prone to getting flats, E load tires are less likely to get punctured and hold a plug better, if you do get a puncture.
    If you have a mall crawler or a daily hwy driver, just use c load tires in 265
  7. Jan 31, 2023 at 6:38 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Depends where you drive I only use e load but I camp out remote back country alone street wise they’re pretty quiet and smooth (fallen wildpeaks)
    winkel likes this.
  8. Jan 31, 2023 at 6:44 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I had E rated tires on my Tacoma for a day and it felt like I was driving on concrete blocks. The sidewalls don’t give very much so it makes the ride feel stiff and they weigh a lot more.
    My tire shop put the wrong tires on by mistake, so I got a free trial of E rated tires. It was a huge improvement when the correct ones went on.
  9. Jan 31, 2023 at 7:03 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    This is from Toyo's website
    Open County AT3
    P 285/70R17 SL 46 lbs
    LT 285/70R17 C Load 55 lbs
    LT 285/70R17 E Load 55 lbs (BSW)
    LT 285/70R17 E Load 53 lbs (WSW)
    LT 255/80R17 E Load 50 lbs
    Thats from Toyo. If you look at other sources the weight may be different.
    I'm running the SL version and going to Moab end of March. Debating if I should change out to 255.
    Read from plenty of people on here running the 255s and they were happy with how smooth they are for an E load.
    FishaRnekEd likes this.
  10. Jan 31, 2023 at 7:10 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    235/85/16 was only E rated so I went with it. I'm driving a truck, not an S Class so its no big deal.
    I will be moving to 255s sometime in the near future and those are also E rated
    BC Hunter and Taco-Grinder like this.
  11. Jan 31, 2023 at 7:37 AM
    GrandMasterChooch
    GrandMasterChooch Well-Known Member
    east coast
    snow tires
    For durability they cant be beat. Fuel economy, performance and handling are noticeably worse running my BFG KO2s E rated. Its a trade off only the operator can decide on.
    BC Hunter likes this.
  12. Jan 31, 2023 at 9:41 AM
    REAL_OG
    me too , I have E load wildpeaks.
    I’m not worried about overloading the tires, more for the tire protection from off-roading, so not sure if C rated is still reliable enough for those remote camping trips
  13. Jan 31, 2023 at 9:59 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I wheel on lots of lava rocks and roads with my C load tires and they're just fine. The lava rocks will tear open any load rated tires, so it's about wheel placement for me.
    I went with C load for better ride and reduction of rotational mass.
    I ran E load for years and appreciate my C loads now.
    moon22 likes this.
  14. Jan 31, 2023 at 10:05 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Does anyone make a decent tire in 255/80/17 or 255/85/16 that are C Load? I haven't seen any, but I've only just started looking as my current tires are nearing replacement.
  15. Jan 31, 2023 at 10:06 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I ended up with "E" as the KO2 in a 285/75/17 only come in "E".
  16. Jan 31, 2023 at 10:09 AM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
  17. Jan 31, 2023 at 10:19 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Before I got my camper, I was still running SL Duratracs under my Tacoma with AT Habitat. Done a good hunk of the WABDR, lots of forest service roads, some trails like at Tahuya, and some of that wonderful rocky stuff where it sounds like your driving on piles of broken glass. Never had an issue (maybe I was super lucky). I've since upgraded to E, but simply due to the weight of my camper and everything else on my truck. It's pushing the limits in that regard. But my main point here is that I'm sure a C tire, or a D, would treat you well, and save you from the weight/stiff ride of the E.
  18. Jan 31, 2023 at 10:20 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I'm running 265/75 -16 load range E Toyo open country mud terrain tires on my 02 tacoma 4cyl Pre Runner . No issues with these tires I've had in the 6 years /30k miles they have been on my truck
    Only thing I've done was set the air press at 30psi which is 50lbs less than max pressure rated for this tire and there is no harsh ride quality moticed
    Taco-Grinder likes this.
  19. Jan 31, 2023 at 11:37 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I had E rated Duratracs, then P rated Grabber APT's & Toyo AT3's, and now back to E rated Motomaster Eliminator Eliminator X-trail A/T. The P rated tires stopped doing well in snow/winter within 2-3 years due to their lower tread depth.
    Yes, E rated are more harsh, but I likely won't go back to P rated because I don't want to have to switch tires out every 2-3 years (40k KM's)...
    However, if I didn't have to worry about winter, I'd for sure stick with P rated!
  20. Jan 31, 2023 at 11:40 AM
    YF_Ryan
    Kent, WA
    I feel like these are the extreme's of the spectrum. Passenger to E rated. Have you thought of trying anything in between?
