E Fan Conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cbeyer, Sep 22, 2020.
  1. Sep 22, 2020 at 9:22 AM
    cbeyer
    cbeyer [OP] Active Member
    San Diego
    2017 Tacoma TRD Off Road
    So I decided I wanted to do an electric fan conversion. No particular reason other than I wanted to tinker. I've installed E fans of several cars and trucks in the past, and have seen the benefits so I figured why not.
    Parts:
    After a bunch of research I settled on a Derale dual shrouded fan. (16927). It's rated for 4000 CFM. I also picked up a Dakota Digital bluetooth fan controller and OBD-11 module. I also had to use a few different mounting brackets and an aftermarket coolant overflow tank.
    Install:
    I didn't take any photos along the way, but install wasn't super difficult. Removal of the stock shroud and fan was super easy. I think it was a total of about 6 bolts. The coolant overflow tank is molded into the stock fan shroud so I had to buy an aftermarket one and find a place to mount it. The most difficult part of the install was simple finding brackets that would work. The stock radiator is much thinner than I expected and I couldn't find brackets that would fit right. I ended up modifying a set of brackets to fit and than isolated everything with high temp rubber so there is no metal on metal contact anywhere. Wiring was wiring. It was somewhat straight forward just time consuming. Each fan is wired individual so I basically had to do everything twice, but this allows me to operate the fans independently.
    Function:
    The fan controller I bought pulls speed and temp data directly from the OBD sensor, it also allows me to operate each fan independently. Basically one fan kicks on at a lower temperature. They both kick on when the AC is running. Also they is a speed shutoff. So above 65 both fans shutoff.
    It has been extremely hot in southern CA since I installed the fans, so its been a good test. I've pulled a 5000lb trailer, done some slow off roading/crawling around, and sat in traffic all at 100+ degrees and no overheating. I've used a scangauge to monitor temps and the truck runs about 2-3 degrees warming then stock which isn't much.
    The truck runs much smoother. You can barely tell its running at idle. Mpg seems to be 1-2 mgp better, and there is a small increase in power. The power increase is more noticeable at high RPM.
    CONS:
    The only draw back so far is at idle the stock alternator has a hard time keeping up with how much power the fans pull. Especially when the AC is running. The fans draw about 40 amps, and at idle I think the stock alternator struggles to feed them enough power. So I may upgrade that in the future. Other than that so far so good.
    EMR, soundman98, Junkhead and 3 others like this.
  2. Sep 22, 2020 at 9:40 AM
    nartmot
    nartmot Well-Known Member
    Cool mod. Thanks for sharing. I had no idea these fans draw so much current. I believe the stock alternator with towing package is 130 amps but it only hits that at highway speeds. If your fan is pulling 40 amps and you are doing something else like using an air compressor or a winch, you might be in for some trouble.
  3. Sep 22, 2020 at 10:12 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Nice! I'm doing an Efan conversion as well. I was surprised how heavy that stock clutch fan was.
  4. Sep 22, 2020 at 10:14 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    I'll stick with the clutch fan. For me I don't see the niche benefit compared to the risk and the cost.
    na8rboy and Chew like this.
  5. Sep 22, 2020 at 4:21 PM
    cbeyer
    San Diego
    That's good to know. I wasn't sure what the stock one was rated for. I think a high output alternator will be added in the near future.
  6. Sep 22, 2020 at 4:37 PM
    MJTH
    MJTH PretenderLander
    Joe
    Colorado-Westslopebestslope
    19 OR- Land Yacht, w/ fireplace
    I did not realize this was thing you could do. Very cool, thanks for sharing.
  7. Sep 22, 2020 at 4:44 PM
    caribe makaira
    Caribbean, Puerto Rico
    Even though you've stated wiring is wiring, up the gauge of the fan juice & ground. And check the crimps and choice ground.
  8. Sep 22, 2020 at 4:45 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    @cbeyer Some other folks in the performance parts of the forum have also done this. I think some run additional temp monitoring just in case the efan starts to act up. Scanguage might help but you can run additional temp sensors too.
    There are several makers of HO alternators. You can find posts through search. Sorry I don't have any bookmarked.
  9. Sep 22, 2020 at 4:48 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    https://www.ebay.com/i/254076686110?chn=ps&mkevt=1&mkcid=28
    zerotimeouts[QUOTED] likes this.
  10. Jul 8, 2021 at 6:39 PM
    Johnny_Ut
    Johnny_Ut New Member
    Any new insights or information on this?
  11. Dec 28, 2022 at 1:20 PM
    Woodythebluetaco
    Woodythebluetaco Well-Known Member
    2016 Tacoma SR5 Blazing Blue
    Stacked plate transmission cooler Front: Custom Fabtech 2.25 Resi Coilovers, King springs, Eibach Tenders Rear: Fox 2.0 Resi, Custom OME Dakar Leafs, Caltracs Rebuilt 3.5
    @cbeyer did you need to wire any resistors or do anything to keep away a CEL after removing the stock fan setup?
