E-brake mount after lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheCubicleDaydreamer, Sep 12, 2020.
  1. Sep 12, 2020 at 8:26 PM
    TheCubicleDaydreamer [OP] Well-Known Member
    19 Cement TRD Offroad
    Evening everyone... so I installed the OME Dakar rear leaf springs and noticed that if I were to use the e-brake mounting location on the leaf it would put unnecessary strain on the cable. So I was wondering if everyone just cuts there bracket off, do you make an extension bracket, or do you install a spacer on the bracket? Thanks in advance.
  2. Sep 12, 2020 at 8:40 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I dont have your answer but I do know the extension is mandatory. Some folks have had the rear brakes lockup while traveling after a lift from not extending their ebrake.
    icebane and Pportera like this.
  3. Sep 12, 2020 at 9:14 PM
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    Are you referring to the metal brackets on the parking brake cable that attach to the fan brackets? If so I just left them off and ziptied them up so they wouldn't rattle and haven't had any issues.
  4. Sep 12, 2020 at 10:37 PM
    I am referring to the metal bracket. I did the same thing but my OCD wants it to be in cleaned up.
  5. Sep 12, 2020 at 10:38 PM
    How does one go about extended their e-brake? I haven't heard of that before.
  6. Sep 12, 2020 at 10:52 PM
    Bishop84
    Bishop84 Well-Known Member
    Bend it with your hand until there's no tension. No need for extension on any 1-2" lift. I always just manipulate it and have never had an issue with the numerous lifts I've done for customers.
    The abs and brake lines need extensions on the big lifts.
    Kcruisin likes this.
  7. Dec 22, 2024 at 10:22 PM
    Javi's Taco
    Javi's Taco Active Member
    What was your solution?
  8. Dec 24, 2024 at 10:51 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Take a snips and delete the bracket, you don't need it, it can cause the E-brake issues after a lift at full droop.
    Aftermarket leaf packs droop much more than factory with sometimes the next limiting factor being the rear shock length.
    Been running no bracket for 5 years now with no issues.
  9. Dec 24, 2024 at 11:28 AM
    Javi's Taco
    How do you attach the e brake line to the rotor then?
    Do you have a photo you can share?
    I was thinking about doing this.
    https://youtu.be/CkcRTuqpXJM?si=E9wb8gr10NMOX_MF
  10. Dec 24, 2024 at 11:34 AM
    JFriday1
    Jesse
    Lakewood, CO
    Sorry but im confused. Ebrake line in the back attaches to the frame in front of the rear wheel. That remains, the bracket that attaches to the leaf pack gets removed, then the line attaches directly to the shoe in the drum. There are no rotors in the back unless its the new 4th gen which I have not had the pleasure of working on yet.
  11. Dec 24, 2024 at 12:07 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Zip tie an old heater hose around the part that rubs against the leaf spring. Replace heater hose after couple years because it will wear a hole eventually.
  12. Dec 24, 2024 at 1:22 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I installed Dakars in 2020 (or maybe 2021) and don’t remember this issue at all.
    In general, springs are terrible at limiting up and down travel (they bend), thus engineers use other methods like bump stops for up travel and shocks for down travel.
    I think it’s a common misconception that installing a lift causes your wheels to droop farther. There might be a small difference, but as long as you are using OEM replacement shocks, your suspension travel is very close to stock. CAVEAT: top hat spacers can put you out of spec.
