dynomax super turbo muffler?
Discussion in '4 Cylinder' started by devilsalmostfree, Dec 26, 2009.
  1. Dec 26, 2009 at 12:11 PM
    devilsalmostfree
    devilsalmostfree [OP] Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    i have a 99 tacoma 4X4, reg cab, 5 spd, 2.7 ltr. im looking to get a dynomax super turbo muffler. i was wondering if anyone else with a 1st gen was running 1, & if so, whats the part # u all had? ive found the 17741, & i im thinking that is the right 1 for my taco. i just want to be sure before i order it!
    http://www.jegs.com/i/Dynomax/289/17741/10002/-1#
    heres the details on it Super Turbo; Muffler; Universal; Round; 6 in.; 2.25 in. ID; 14 in. Shell Length; 19.5 Overall Length
  2. Jan 27, 2014 at 3:40 PM
    TacoLoco98
    TacoLoco98 Well-Known Member
    Grass Valley, CA
    '98 4x4
    bump looking for same answer here!
  3. Feb 1, 2014 at 6:25 PM
    FmrFronty
    FmrFronty Member
    TacomaPrerunner
    I recently installed a super turbo muffler from dynomax,mellow rumble,very low drone on hiway speed,pretty quiet at 1500rpm.
  4. Feb 1, 2014 at 11:40 PM
    bamufflers
    bamufflers Active Member
    Keith
    Escondido
    03 SR5
    DirtyDeedsIndustries long travel, King coil overs with King bypass up front. 3X16 triple bypass kings out back to dampen the Deaver SUA pack. Long tube headers with full race exhaust system. Too much to list.
    is that a 'straight thru' design? From what I've seen it's not, it's just a smaller version of stock and it's just designed to make a little more noise.
    A 'straight thru' design properly sized will make the best power and sound:)
  5. Feb 2, 2014 at 1:51 AM
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    I had that exact muffler in the 3" flavor on my supercharged h22 Prelude... it was horrible. sound was tinny and flow sucked. it is NOT a straight through design. I cut it off after one day.
    btw.. crazy how a question in '09 has resurfaced in 2014.
  6. Feb 2, 2014 at 9:53 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    wormhole ;)
  7. Feb 3, 2014 at 6:47 PM
    TacoLoco98
    Grass Valley, CA
    '98 4x4
    Because I have the same truck and want the proper part number!! no point in making a new thread..
    17741 or 17748..??
  8. Feb 3, 2014 at 10:41 PM
    tooter
    Greg
    Los Angeles
    This thread is good. Sorry, I was just joking around. ;)
    #17748 is 2 1/2" so that will work fine.
    You could also use 17741 which is 2 1/4" but the muffler shop will need to swedge out the ends as the stock pipe is a metric diameter that comes out to about 2 3/8". But every muffler shop has a hydraulic pipe expander that opens up the ends in just a couple of seconds so it's not really an issue.
    Greg
  9. Feb 3, 2014 at 10:56 PM
    Weasel09
    Weasel09 Well-Known Member
    Wes
    Wahiawa, Hawaii
    6 Speed TRD Offload & X-Runner
    Atleast someone knows how to use the search feature instead of being lazy and making a repetitive thread!!!!
  10. Feb 6, 2014 at 6:56 AM
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
  11. Feb 6, 2014 at 8:05 AM
    crawl
    Greg
    Valencia, CA
    chris4x4 knows his shit!!
    That said, I have no idea about what he dyno tested, the parameters, the engine, the mods, etc........
    All I'm saying is that the Dynomax Super Turbo is a compromise between sound and flow. I will promise you that any brand straight through muffler will put out more flow and more power on a dyno. This is not my opinion... it's fact.
    If somebody's motor puts out more power with a super turbo or any restrictive muffler over a straight thru design, then something else is restricting the system. The old school concept of "a little back pressure is good" is a MYTH!!!! A motor is a pump...air in, air out. Add any restriction in the system and you will lose flow. VELOCITY is something completely different than back pressure and people confuse the two. For the most power possible, you want ZERO restrictions and the highest velocity.
    Don't take my word on this... call a real life exhaust/header fabricator and ask them yourself. that's what i did. oh......and lots of research on the subject as I built my supercharged prelude
  12. Feb 6, 2014 at 7:21 PM
    bamufflers
    Keith
    Escondido
    03 SR5
    Very well put!!!^
  13. Feb 6, 2014 at 9:38 PM
    tooter
    Greg
    Los Angeles
    oh oh :anonymous:
  14. Feb 7, 2014 at 7:46 AM
    crawl
    Greg
    Valencia, CA
    ^^haha!!! Greg... I know you had a bad experience with opening up your exhaust and upgrading your muffler, but there could have been other factors that made you "feel" a torque loss. Our factory header back exhaust system is very well designed. Way better than my 2000 Honda exhaust. I'd like to remove the second cat and get a better sounding (and louder) muffler
  15. Feb 7, 2014 at 7:53 AM
    crawl
    Greg
    Valencia, CA
    thank you.. i usually sound like an idiot when i write or speak. my brain and the words that come out are not always in synch.
  16. Feb 7, 2014 at 8:57 AM
    tooter
    Greg
    Los Angeles
    My situation is a little different from most in that I'm not looking for top end performance because my Taco is used as a utility vehicle for work. So all I need is bottom end pull and good gas mileage. I fully agree that opening up the exhaust gets you more top end performance. Heck, I still changed out my exhaust because I wanted some sound. ;)
    Greg
  17. Feb 8, 2014 at 10:03 AM
    crawl
    Greg
    Valencia, CA
    ^^I like your theory of wanting more low-end torque.. even on my non-work DD truck :)
