DuraGo Wheel Bearing & Hub Kits?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Phessor, Dec 13, 2019.
  1. Dec 13, 2019 at 9:18 AM
    Phessor
    Phessor [OP] Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    Has anyone had any experience with the DuraGo Wheel Bearing & Hub Kits from RockAuto?
    https://www.rockauto.com/en/moreinfo.php?pk=8843260&cc=1317633&jsn=1814
    I have an extra set of ADD steering knuckles that I am getting my Total Chaos gussets welded onto and wanted to rebuild the assemblies while I was at it. They will be converted to manual hub assemblies to replace my current set.
    From RockAuto, the DuraGo Wheel Bearing & Hub Kits are $75.79 per side.
    From Toyota I am looking at $365.80 per side.
    Any real world input would be greatly appreciated.
  2. Dec 13, 2019 at 11:30 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    The reviews for Durago brand wheel bearings on Amazon are pretty bad. They're Chinese low quality stuff. In some places we can get away with running lesser quality parts, I wouldn't recommend durago or any other Chinese wheel hubs/bearings. I've yet to see an aftermarket Chinese wheel hub/bearing that I'd run on my own vehicle. I have installed a few for customers, their choice. If I do run into a Chinese wheel hub/bearing that does seem comparable to OEM I will definitely let the forum know.
    I think the pricing compared to OEM also tells you how the quality likely is
    Phessor[OP] likes this.
