Duplicolor perfect match 2014 tacoma Grill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maze, Aug 3, 2014.
  1. Aug 3, 2014 at 3:58 AM
    Maze
    Maze [OP] Active Member
    Hawaii
    tacoma TRD full package
    So i know there are quite a bit of threads
    on how to do this, but wanted to share my
    experience along the way. Hopefully help
    shed some light on little details some of us
    like myself might miss.
    Anyways here we go...
    What you need:
    3m 400 grit wet/dry sandpaper
    3m 600 grit wet/dry sandpaper
    3m 2000 grit wet/dry sandpaper
    microfiber cloths and/or shop towels
    cleaning products; Soap, Wax, grease and Tar remover and/or Rubbing alcohol
    Paint supplies:
    at least 2 cans of Duplicolor Perfect match (I used black 202)
    1 can duplicolor adhesion promoter
    1 can duplicolor wet sandable primer
    2-4 cans of Duplicolor Clear coat
    I began with cleaning the Chrome really good; Washed w/ Soap then grease
    tar remover. prep is key.
    Once cleaned begin sanding w/ 400 grit
    clean w/ your cleaning products between
    each sanding from 400 to 600.
    I cross hatched to make sure it was even strokes.
    You can wet send, but it took forever to get
    the desired look and feel i was after.
    Took little while, but take your time
    this shouldn't be rushed. took me maybe a few hours w/ brakes?!
    when finished it should look not as shiny,
    like brushed aluminum. Kinda cool looking.
    Clean really good after sanding.
    began spraying Adhesion promoter.
    start with light even coats. A tack coat.
    wait like 5min between each coat.
    with a total of 4 coats. Not necessary to add more coats.
    make sure to get all the corners and bends really well.
    Once Promoter is dried(maybe 7-10min) lets start with Priming.
    Once again, light even coats. first coat tack coat.
    2nd coat. little heavier. Starts to even out
    4th Coat. all evened out. should look smooth and well covered.
    I let mine try for a day before sanding.
    Just cause i was busy with other things,
    but should be sandable after few hours.
    Clean again before sanding. maybe not necessary,
    but I am a perfectionist. prep is key. ok.
    begin wet sanding w/ 2000 grit to smooth
    out any dust, specs runs. I used warm soapy water to sand.
    I also sanded in one direction.
    Watch out for the corners. I had to go back
    and re-sand and do all steps again to cover these up.
    AAAAHHHH!!! SHIT!!!
    Ok... Once primed and sanded. let dry really well. I waited a day.
    just cause I am lame. moving along...
    I know this isn't necessary, but i sprayed 2 light coats of
    adhesion promoter over the sanded Primer. Why? i don't know...
    lets paint. Yay! the scary part.
    first light even tack coats. take your time smooth strokes.
    2nd Coat. should have about 30% visibility.
    3rd coat. Starts covering it up more.
    4th coat... i know almost there.
    Here is the last paint coat. not sure what number
    i lost count. Damn. maybe like the 7th? Shit.
    Anyways. should look well covered and semi smooth w/ matte finish.
    Let the paint dry maybe an hour before clear coat.
    I let mine dry over night, just cause i was being daddy.
    Ehh... Can we clear coat now? Ok...
    I did like a total of 10 clear coats w/ like 6min between coats.
    1st coat. light even coats. will get heavier later ok?
    2nd coat.
    3rd. starts to shine up little more. yeah baby. shiny!
    Fast forwarding... more coats. starts to get really shiny.
    be careful not to go to heavy or close which will cause runs.
    i believe i was maybe 6inches away?
    Think this is like my 6 or 7th coat. almost done.
    More coats to even out the blemishes. Once again
    its probably not necessary for this many coats, but..Hey
    nice and shiny ;)
    Now heres the fun yet time consuming part curing.
    i let mine cure for about a week. before i wet sanded w/ 2000 grit.
    clean real good then lightly wet sand. the idea is to just smooth out the coat
    so we can buff the scratches out later.
    totally dried and cured.
    the fished product. I am really happy how it turned out.
    paint is dead match and really close if not perfect shine
    as the hood. I buffed it out w/ turtle rubbing compound
    then ultimate polish did it like 3 times with rotary polisher
    then waxed the fucker and calledl it a day. I am done baby!
    Hope you all can learn and enjoy one of many mods yet to come.
    custom Satoshi style grill coming soon. in the works for DIY!
    Cheers,
  2. Aug 3, 2014 at 4:09 AM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Looks great!
  3. Aug 3, 2014 at 4:19 AM
    jwinky
    jwinky Well-Known Member
    oklahoma
    2006 Access cab 4x4 5 speed
    5100's with OME 885 coils, Wheeler's 2" AAL
    That looks amazing! Definitely doing this later down the road.
  4. Aug 3, 2014 at 4:22 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    Excellent job! Looks professional. How many hours did it take from start to finish?
  5. Aug 3, 2014 at 5:53 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    You do good work. That turned out great! :thumbsup:
    Camelback Toyota sells one for $180 shipped and color is a dead on match for those that don't want to go through all the time and effort of painting theirs.
  6. Aug 3, 2014 at 6:08 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Good job and good write-up!
  7. Aug 3, 2014 at 6:12 AM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    I did mine a little different. My dealer sold me a color matched for $160 plus tax and I sold my chrome on CL for $120.
    Great work but man, my way was a little easier.
  8. Aug 3, 2014 at 8:20 AM
    1eyedjack
    1eyedjack Old Pirate
    Southeast USA
    2014 MGM DCSB TRD Sport Tow
    Outstanding results - Know you have got to be pleased...
  9. Aug 3, 2014 at 12:50 PM
    Maze
    Hawaii
    Thanks guys! Yeah it took maybe a total of 72hours. Although i was busy so total of like 7days. I did really want to buy a color matched, but decided for now $50 was better. Although I do believe these trucks need nothing but the best. :)
  10. Aug 3, 2014 at 7:27 PM
    stevespens
    stevespens Tacoma Addict
    Fort Mohave, Arizona
    06 Pre-Runner Quad Cab Rad Red
    2014 nose conversion in Radiant Red, Raceline Raptor wheels w/ 265/75R16's, Go Rhino chrome nerf bars, Pioneer AVH-X3600BHS stereo, leveling kit 2 1/2" and 1", tinted windows, color matched grill, Dynomax Syst-Ultra flow cat-back,
    Nice job. Looks like factory. I did mine this weekend. I used 2X primer, base coat and 2X clear coat. I was doing some other painting on the nose, so what better time to take care of it.
  11. Aug 4, 2014 at 2:50 AM
    Maze
    Hawaii
    That looks excellent! Love the red, striking
  12. Aug 4, 2014 at 8:19 AM
    RearViewMirror
    Craig Christ
    Amazing job on the conversion and the paint man! You do excellent work. I'm impressed :thumbsup:
  13. Aug 5, 2014 at 4:59 PM
    stevespens
    Thanks so much. It was so well worth it to me. Wouldn't look back for a second. Sorry for the highjack. :eek:
  14. Aug 5, 2014 at 5:05 PM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    dang! both your grilles look amazing! i was lazy too and bought mine and sold the chrome one on CL.
  15. Aug 5, 2014 at 5:14 PM
    Rsamani
    Rsamani Well-Known Member
    Socal
    14 DBSB O/R 4x4
    not a lot
    FS: Chrome grilles of a 2014:)
  16. Jul 16, 2016 at 11:46 PM
    4pntlifted"
    4pntlifted" Active Member
    Zach
    2008 White Tacoma TRD 4x4
    Do they make them also for 08 models for 180$?
