Dumb question on heat coming from the brake pedal area
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco Stevie Doo, Oct 31, 2020.
  1. Oct 31, 2020 at 6:20 PM
    Taco Stevie Doo
    Taco Stevie Doo [OP] Member
    Was driving today and my brake foot was getting really warm. Hot actually. When I parked, I felt down around the break area and there are two steel tubes/lines that were super hot to the touch. They sit just above the pedal assembly. I could not hold on to them they were so hot. What are these things for? Why would they be so hot. I never noticed this before and just had my truck serviced by the dealership this morning. Thanks for your help folks.
  2. Oct 31, 2020 at 6:23 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Without a picture I can't say for sure but I would assume they're HVAC lines.
  3. Oct 31, 2020 at 6:23 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Pictures might help to pin point them ..
    RedWings44 likes this.
  4. Oct 31, 2020 at 6:26 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Initial impression is that something doesn't sound right. I can't imagine what would be hot enough that your foot is feeling hot. I can't imagine the HVAC system, alone, gets hot enough to do that.
  5. Oct 31, 2020 at 6:31 PM
    Taco Stevie Doo
    Thanks guys , that was fast!!
  6. Oct 31, 2020 at 6:31 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Any CEL?
    Not sure if there's a catalytic converter down there, but if they get unusually hot, they can heat floorboards.
  7. Oct 31, 2020 at 6:33 PM
    RedWings44
    Michigan
    If I'm guessing correctly, those would be lines leading from your engine coolant system into your heater core. Strange that you'd be able to feel them radiating that much from your feet though. That, or the AC lines doing the same thing, but I'd be more inclined to believe the former.
    Junkhead, mtip and jerkwithkeyboard like this.
  8. Oct 31, 2020 at 6:34 PM
    Key-Rei
    Key
    Florida
    Definitely looks like the air conditioning lines, coming from the cold coil and or going to the condenser to be cooled off.
  9. Oct 31, 2020 at 6:36 PM
    Taco Stevie Doo
    well I was wearing flip flops. I had my Pedal Commander line twist tied to these things to get it up out of the way but maybe that's not such a wise idea. I'll keep an eye on it. Thanks fellas!
    Junkhead likes this.
  10. Oct 31, 2020 at 6:39 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I noticed the same thing too when I was installing my PC. I thought I better not wrap that cable tight around those tubes.
  11. Oct 31, 2020 at 6:42 PM
    Taco Stevie Doo
    Thanks T_13. Sounds like it might be normal then. I love this form.
    Junkhead, Key-Rei and Tacoma13_NC like this.
  12. Oct 31, 2020 at 6:49 PM
    Key-Rei
    Key
    Florida
    Just pop the hood find where they come through the firewall and see where they trace back to either the A/C or the block. Done deal.
    If they're both too hot to touch then they are probably heater core lines, makes sense too as the cold line on the A/C would generate condensation and should have a drip tray under it.
    IIRC the 2nd gens heater and cooler lines go through the passenger side.
    If they're too hot for your flip flop feet you could wrap them in Reflectix and foil tape.
    :notsure:
  13. Oct 31, 2020 at 6:54 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
  14. Oct 31, 2020 at 6:56 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Those are the lines for the heater core. There’s 180 degree coolant running through them. If it’s noticable, get some pipe insulation
    Junkhead, Tacoma13_NC and 3JOH22A like this.
  15. Oct 31, 2020 at 7:28 PM
    Taco Stevie Doo
    YOU GUYS ROCK!!! Happy Halloween
  16. Oct 31, 2020 at 7:50 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    That is exactly what it is.
    has been talked about for years now. If you want, its a toe warmer.
    2016 sport
  17. Oct 31, 2020 at 8:03 PM
    Spraynard
    Spraynard Priapism survivor
    hagrid
    Pittsburgh
    '19 AeroTundra PRO
    Maybe some type of full coverage shoe technology is warranted.
  18. Nov 1, 2020 at 12:35 PM
    1klynnen1
    1klynnen1 Daily Driver | Weekend Warrior
    Los Angeles County, California (Coastal)
    21 | SR5 | ACLB | 4x4 | V6
    O.E. | Packages & Accessories ——————————— • Hard tri-fold tonneau w/ 16" dark gray alloy wheels. • Alloy wheel locks, bed mat, exterior cargo net, door sill protectors, mudguards, security system, spare tire lock. Daily driver basics . . . ——————————— • WeatherTech: FloorLiner HP mats Side window deflectors Sunshade. • Duluth Trading Co: Bodyguard seat covers Trash commander. • Edbetos: Center console organizer tray Center console dividers Glove box organizer. • Rokform: Swivel dash mount (magnetic). • Thinkware: U1000 dash cams w/ radar module. • KC Hilites: Gravity LED G4 amber fog light kit. • Sylvania: Silverstar Ultra H11 Halogen bulbs. • iDrive-USA: Throttle controller. • OEM Audio Plus: Reference 500 speaker system.
    What is this “pedal commander” you speak of? An A.M. electronic throttle adjustment module?
  19. Nov 2, 2020 at 4:05 AM
    RedWings44
    Michigan
    Basically. It doesn't give you more power or anything, but changes how the computer reads your pedal input. Jeepers also use them quite a bit.
  20. Nov 7, 2020 at 8:34 PM
    Taco Stevie Doo
    Pedal Commander is this thing you hook up to your gas pedal that sends a fake signal to the engine to work a little harder. Sorry for my late reply and I'm sure you already googled it, but after about one month of PC on my 2019 Taco Off Road, I have to say I really like it. It gives you a lot of get up and go and I don't even use it on it's max setting. If you are unhappy with that squishy feeling you get when you step on the gas, then get the PC. It's only like $150 or so. You can hook it up in like 10 minutes.
