Dumb question on coolant level
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mastiff37, Apr 2, 2022.
  1. Apr 2, 2022 at 9:10 AM
    Mastiff37
    Mastiff37 [OP] Well-Known Member
    Tucson, AZ
    2011 Regular Cab 4x4
    The overflow says something like "high" and "low". Other vehicles I've had are more like "hot" and "cold". Is it the same? Or more to the point, if my truck sits just a little above "low" when cold, is that correct, or should I top it off a bit?
  2. Apr 2, 2022 at 9:17 AM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    I find that the tank level doesn't change much, hot or cold. Thus I keep my vehicles more toward the "high" level when cold. Just don't go over that mark. Having the coolant level in between high/low is a good compromise.
    Dm93 likes this.
  3. Apr 2, 2022 at 9:46 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Don't forget to check the level in the radiator too from time to time but only do that when the engine is cold.
    b_r_o and TnShooter like this.
  4. Apr 2, 2022 at 10:49 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I fill mine to the "Full" line. When it's running, the level will drop about an inch or so because the coolant is in the engine. As long as it stays between these levels, you're good.
    Replace your radiator cap. If the old one is weak it might not be working properly.
  5. Apr 2, 2022 at 11:16 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    i keep it around the top line when cold. Plenty of room for expansion when hot even at the top of the line.
    Key-Rei and mistermanny like this.
  6. Apr 2, 2022 at 8:44 PM
    Waasheem
    Waasheem
    2007 xrunner
    High is hot, low is cold. If you over fill the reservoir, it’s not gonna hurt YOU. It simply spits the excess out. It’s not exactly environmentally friendly to spit coolant on the ground. Motorcyclist don’t like it either. Nothing like coming to a stop, setting your foot in a slippery puddle, then doing the splits with a motorcycle between your legs.
    If you work on your cooling system, say replacing a popped hose, I like to fill the radiator, let it gurgle a bit, top it off. Put a little in the reservoir. Then start and rev the engine for a good amount of time, enough for the thermostat to open. Then once hot, top off the reservoir to just above the upper line. Then in a day or two, top it off again.
    Reservoirs loose a slight amount from evaporation so they need topped off again every so often.
    wilcam47, ScrippsRanch67 and Key-Rei like this.
  7. Apr 2, 2022 at 11:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Something tells me, the answer to your question is in the owners manual.
    I’m not trying to be a prick. I’m just trying to stay out of a debate.
    I’ll give you a hint. You check it and fill it when the engine is cold.
    6 gearT444E, wilcam47 and Waasheem like this.
  8. Apr 3, 2022 at 5:08 AM
    Family1st
    Family1st Thneeds?
    Upstate New York
    2010 DCSB 4x4 auto SR5 52,000 miles
    -All Pro dual swingout rear -AllPro Front Bumper -Lear topper -Prinsu CabRack w/Cali-raised lightbar -Rhino Rack Pioneer Rack for topper(sold) Rhino Rack tracks and Aero bars for topper -AluCab 270 Shadow awning -Roofnest Condor XL -Weathertech fronts/rears -ARB series II 50qt -Total Chaos bed supports -5 SCS RAY10’s Dark Matte Bronze w/285 75 16 Atturo M/T -FOX Performance Elite front coilovers with ICON tubular UCA -FOX Performance Elite rears riding on RXT (option 3) -Brand New Frame (dealer installed) -IN THE MARKET FOR Sliders, fridge slide, Considering decked system (in desperate need to organize), Electronics control center, as the list gets shorter it keeps getting longer.
    Topped mine off to the reservoir full line before the last road trip for parts. Still at that line.
  9. Apr 3, 2022 at 11:58 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The expansion reservior isn't there to provide an exact measurement. Its just a convenient way to get a quick look at the coolant level.
    Best place to check the level is under the rad cap when cold
    TnShooter and Dm93 like this.
  10. Apr 3, 2022 at 3:06 PM
    Waasheem
    Waasheem
    2007 xrunner
    Thread jacking a bit here.
    I wonder if anyone has ever tried the waterless coolant, I think it was by a company called Evans. As any manufacturers would claim, it’s the greatest thing in the world and will change your life. Just I’ve never heard of anyone trying it.
