Dual Y pipe exhaust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wdavis18, May 4, 2017.
  1. May 4, 2017 at 3:03 PM
    wdavis18
    wdavis18 [OP] Active Member
    2014 Black TRD Sport Tacoma (4.0L v6)
    4inch suspension lift, 2inch blocks, 33x12.5xR20 mud tires, front steel bumper
    I was looking to put a deeper sounding exhaust on my truck. I've done a lot of research but my friends truck has dual Y pipes with a muffler deletion (with factory cat) and it sounds really good. I was wondering if anyone knew any good places to buy dual Y pipes?
  2. May 4, 2017 at 3:10 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    As in an X pipe?
  3. May 4, 2017 at 3:29 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    I'd think your best bet would be to go to an exhaust shop and have them make it for you. They can take the pipe, cut and bend as needed.
  4. May 4, 2017 at 4:12 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Say again over
  5. May 4, 2017 at 4:13 PM
    inwood customs
    Dave
    As in true duals?
    Which means NO ypipe?
    Is that wut we talkingbout?
  6. May 4, 2017 at 4:14 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    xpipe tends to make it less deep. sounded literally like a civic when i ran one
  7. May 5, 2017 at 5:14 AM
    wdavis18
    No, I was thinking of leaving my Cat converter on and then doing a Y pipe into a dual exhaust and taking out the muffler
  8. May 5, 2017 at 5:25 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    dual off each cat? 4 tail pipes?
  9. May 5, 2017 at 5:53 AM
    wdavis18
    no, just a y pipe off where the muffler would be into duals.
    https://www.youtube.com/watch?v=6lnfXwgDOfo
    this is what i was going for. Sounds super good in my opinion. His description says "Y'd duals with no mufflers and factory cats."
  10. May 5, 2017 at 6:19 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    ok, think i can picture it now.
    literally just cut off muffler and stuck a Y in its place to make duals.
    Everything forward from there still stock. Is that right?
  11. May 5, 2017 at 6:22 AM
    wdavis18
    Ya that's what i was thinking. That video clip makes it sound pretty good. Only thing is, I can't find a good Y pipe
  12. May 5, 2017 at 6:24 AM
    wdavis18
  13. May 5, 2017 at 12:28 PM
    inwood customs
    Dave
    That rasp may get old... just a heads up.
  14. May 5, 2017 at 12:44 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    This is dead on exactly what my truck sounds like and all i did was put in an Aeroturbine 2525 where the old muffler was :notsure:
  15. May 5, 2017 at 12:56 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah ... every single aftermarket exhaust i have heard on almost any standard v6 sounds like dog shit. Super raspy or just droney and lame sounding. OP stick with stock, or at most the TRD cat back.
  16. May 5, 2017 at 1:20 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Hey man, to each his own.
    But I agree, fast forward to 2:40 on that video and ask yourself, is that the combo I want with a head ache going home from work? That's not just his tires.
    That said, you can surely find an exhaust shop that can give you a quote to create what you want. Between the spare & fuel tank, you probably want to have a chat with them to figure out exactly what you want out of it.
    That said, here is a dual out the side y pipe from Flowmaster:
    And this one
    Not finding what you want right off, but the parts are there to weld or clamp your own together. Given the prices for dual systems check with a local shop and get what you want. Or try to email the guy that made the video and find out where he had his fab'd.
  17. May 5, 2017 at 2:28 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    That lawn mowery leaf blower sound is def not the exhaust, in fact you can barely hear the exhaust besides a little rumble every now and then in the video. Sounds like the guys got a mini fan going in there haha. But man those tires are loud.
    wdavis18[OP] likes this.
  18. May 5, 2017 at 2:29 PM
    devinzz1
    devin
    2023 aclb trd or mt
    y pipes or "dual outlets" dont really sound any different than a single exhaust. more or less just a visual thing.
  19. May 6, 2017 at 7:36 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    If that's the case then a couple of paper towel rollers covered in aluminum foil will do the trick. I think I'm gonna make some for me!
  20. May 6, 2017 at 11:42 AM
    wdavis18
    Can you upload a video clip? I would like to avoid any welding if possible, which is what that guy did (cut out the muffler and welded a y pipe in). I'm just looking for a deeper sounding exhaust, which I also know is hard to do with a v6...
