Dual Color Switchback Bulbs for DRL/Turn Signals
Discussion in 'Technical Chat' started by Scott W, Jul 28, 2012.
  1. Jul 28, 2012 at 1:14 PM
    Scott W
    Scott W [OP] Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    Does anyone know how to wire in Dual Color Switchback Bulbs for DRL/Turn Signals
    Hey Tacoma Electrical Wizards, Got a challenge here. My 2012 Tacoma has the amber DRL. I really would like to change them to a dual color switchback bulbs. White DRL with amber Turn Signals. I got the LED Bulbs and Resistors for hyper flash. I have run into some issues with the 4157 bulb and socket. Was going to convert the socket to 3157 which I thought would be no problem. It turns out the Tacoma uses the same input crt (bright element) for both DRL and Turn Signal when Headlamps off.
    When you turn the Headlamps on, the input crt changes to the dimmer element of the bulb for Park Lamps(DRL turn off) and continues to use the bright element for Turn Signals (like what I need for switchback bulbs to work).
    Switchback bulbs require 2 independent crt to work correctly. Is there a way to change the DRL crt out put so it uses the the dimmer bulb element crt. and the Turn Signal continues to use the bright element crt. with headlamps off. (like a normal 3157 crt.)
    I have a very good working knowledge of auto electricity. I am a 20 year auto tech. I just have no access to Toyota Schematics.
    Hope someone can help. Scott
    claw1981 likes this.
  2. Jul 28, 2012 at 9:03 PM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    This might help. Good luck
  3. Nov 4, 2012 at 5:45 AM
    Scott W
    Scott
    Saranac Lake, NY
    DRL FB LED Update.
    I got my Flash Back LED's working. No need to swap out DRL Relay and Harness (didn't work anyways. 2012 wiring is different).
    I got a hold of Tacoma 2012 Schematics, researched and did this procedure.
    I explose the back side of the Diver's Side Interoir Juction Block. Locate the White, 12pin, M1 Connector which is plugged into the backside of the Juction Block. I, rather than cut the wire, disconnected the M1 Connector and with the proper Terminal Removal Tool, I pulled the #10, light green&red wire terminal from the connector. Taped it off so it can always be reinstalled if needed. This disables DRL's. Now you have manuel control of your lighting.
    The result is: No Headlamps, Park Lamps or DRL's in off mode. The only way to run your White LED "DRL" is in Park Lamp mode (only thing is that your Outer Marker Lights will be on also (but I can live with that). They will always stay white even in Headlamp on mode. Your Outer Marker Lamps are now "Park Lamps". When you signal left or right the FB LED's will switch and flash amber. They also will flash amber when Hazards on turned on.
    It works for me. The Super White LED are really nice looking when on and no more annoying HOT amber bulbs to distort my lenses. FB DRL's can also be turned off by simply switching HeadLamps to off mode.
    Thats what I did. Hope it helps.
    BruteTaco, johnny340 and Joseapq78 like this.
  4. Feb 12, 2013 at 9:01 PM
    firetaco18
    firetaco18 Well-Known Member
    Scott, you have answered my prayers. I have been trying to get my switchback leds to work forever now and I think this may be the solution. I will try it this weekend. Im not too experienced but im hoping it is easier done than said. The detailed instructions hopefully appear the same in my '13. Any pics of these wires? thanks
  5. Jun 10, 2013 at 6:43 AM
    txleadclimber
    txleadclimber Member
    Ben
    Colorado Springs
    2012 Tacoma TRD Off Road
    Toytec 3" Lift, DTRL Mod, Fog Light Anytime Mod, 6000K HID Fog Lights, 6000K HID Headlights, Switchback Turn Signal/DTRL, Red interior LED lighting, Relentless Fabrication Hood Light Mounts, B.A.M.F. Grill light Mount with two Kragen 7" and two Kragen 4" Lights, Grillcraft Upper and Lower, ARB Bed Rack with Hi-Lift mount and Double Jerry Can carrier,
    Scott, this worked like a charm. Thank you for the write up and the replies to all my questions.
    Scott W[OP] likes this.
  6. Jun 10, 2013 at 11:03 AM
    BamaToy1997
    Bill
    Navarre, FL
    A bit of information that I have gleaned from the time I have been working on LED conversions. This is specific to many vehicles, but does include the Toyota Tacoma.
    Standard switchback LED's do not work on the Tacoma as designed. You have to get the 3157 CK type 2 LED switchback bulbs to work properly because for whatever reason Toyota, in their infinite wisdom, have their 3157 sockets wired differently than most other manufacturers. This is from one of the distributors that I have contacted. Now take into account this is information from THEM, so don't take this as gospel truth here.
    "If you own any of the following Toyota vehicles like the Camry, RAV4, 03-08 Corolla, Highlander and all Tundras/Tacomas, don’t use the standard type 3157 bulbs. Please selects the CK type 3157 bulbs."
  7. Jun 10, 2013 at 11:18 AM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I might be missing something but, can disconnecting "the #10, light green&red wire terminal from the connector" and taping it off disable my DRL without the need to change the bulb and still have parking lights?
  8. Jun 22, 2013 at 3:44 PM
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
  9. Aug 8, 2015 at 7:55 AM
    Joseapq78
    Joseapq78 Member
    2010 tacoma SR5 crew cab grey
  10. Aug 13, 2015 at 11:03 AM
    Joseapq78
    Joseapq78 Member
    I have a question does your drl harness have two or three wires coming out of the plug I need to know because mine has only two and will this work or do I have to add a third wire to the harness to make my switchback led bulbs work properly just in case yes they are srck bulbs please let me know I will wait for your feedback
  11. Apr 3, 2016 at 10:36 AM
    claw1981
    claw1981 Active Member
    Dallas, TX
    2012 Nautical Blue DCLB Prerunner
    Led's all around, tailgate lock,headlight projectors, dtrl elim, 265,75,16's, debadged, devil horns
    Thank you 100 times to the op!!! I have been looking for a fix so I can hook up my switchback LEDs for weeks! If you lived in Tx I would buy you a beer!
  12. Apr 3, 2016 at 2:28 PM
    claw1981
    Dallas, TX
    Also if anyone in the future has any questions regarding this mod ask me. I keep up with this forum so i can answer back pretty quick.
  13. Jun 2, 2016 at 4:30 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    So if the 3157 CK type bulbs are purchased will they work without removing the DRL wire? I want to use the switchback LED bulbs but in not willing to lose my DRL.
  14. Jun 2, 2016 at 5:43 AM
    claw1981
    Dallas, TX
    No, switchbacks will not work without disabling the Drl. I think there is a mod you can do to the flasher relay involving taking it apart and shaving down some solder but it seemed too much work for me!! I personally had to cut the wire as the op suggested.
  15. Jun 2, 2016 at 5:53 AM
    sundene
    sundene Active Member
    Jenks, OK
    2012 Tacoma White 4x4
    It will work without disabling the DRL's. I have the below listed switchback LED's in Amber with CK wiring. This is the best deal on these AND they work better than the guy that sells the $90 bulbs here on Tacomaworld.com **I DID do the mod on here somewhere that allows me to disable the drl's with the wiring DIY in the fuse/relay, but it does work.
    I have a 2012 Tacoma. What is awesome about the ebay bulbs is that they are not on when I don't have the drl switched ON on the steering column lever/switch, but when I turn on to just the 1st turn (or DRL mode) the white lights come on. Then when I use the turn signal it turns to amber and then when it switches off it goes back to the white LED after about 2 or 3 seconds. It looks WAY better and works way better than the guy that sells the $90 LED CK wiring bulbs on this forum for Tacomas. His didn't do any of that. I have had the same pair for over 2 years and they haven't burned out yet. I do have load resisters installed and they only get used or HOT when the turn signal is on - so it's good!
    http://www.ebay.com/itm/271245336551?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
  16. Jun 2, 2016 at 3:41 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    You need to fully describe how you moded the DRL'S to allow operation. Do you have a link to your work? Also do have a video of the lights in operation?
  17. Jun 2, 2016 at 8:31 PM
    sundene
    Jenks, OK
    There is a thread on here somewhere that show's how it's done. Tried to find it, but this forum is loaded with junk and it doesn't search well. Some info below and no video.
    Here's my pic of what the wiring setup looks like on my 2012.
    https://www.tacomaworld.com/threads/leds.376343/
    I got my led bulbs on ebay - NOT from the guy on this board CSJumper?? The one's here on this board were way more expensive. They also may work different. The reason I cut the DRL wire under the dash is that on my 2012 Tacoma the drl's come on when the truck engine is on and when the steering column switch for lights (both drl and headlights) is in the OFF position. Toyota does this for safety reasons - I guess - as the amber lights will be on when running or when in first position on knob. Since I cut my green wire under the dash my drl's don't come on when the truck is running (though without they are ON and AMBER colored. Thus I can turn on my lights to the first position on the steering column knob (drl position) and they will light up WHITE and not amber - as they will with a "normal" modification. I like the look of having WHITE LED's on when driving the truck without the headlights ON (but the drl's are ON in white - in first position on stick/steering knob) - without it they would be AMBER because the DRL module over-rides it.
    It's kinda confusing.
  18. Jun 2, 2016 at 8:49 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Something I really don't want to do is cut my DRL wire under the dash. I also don't want to have to turn my headlight switch to the first position to get the LEDs to come on. I would love a set up that would allow the switchback feature and the DRLs would come on after start up.
  19. Jun 28, 2016 at 10:39 AM
    surfyota
    surfyota Well-Known Member
    mike
    Tampa, Florida
    17 mgm dcsb Trd sport 4x4
    Lifted, kmc 17x9, Cooper 33s, katzskin leather, topper, front bumper light bar.
    i have a 3rd gen tacoma and just installed switchbacks hoping my drl would be white instead of amber but they are only white when the headlights are on and amber when only the drl are on. would this mod be the same for the 3rd gens
  20. Jul 26, 2016 at 8:05 PM
    Flyryguy78
    Flyryguy78 Well-Known Member
    Winter Park CO
    '13 TRD OFF-ROAD ACLB 6spd.
    TX BAJA Suspension. Black 16" TRD wheels. BFG AT TA/KO winter tires
    Can you describe in detail, your process? This is truly the first description of how I have wanted my SB's to function. This is basically what the $150VLED setup is.
    Turn Signal Stem on Column as follows:
    Off=Off
    DRL=White
    Parking=White w/cornering lts. on
    Headlights=White
    Left/Right Signal=Amber Flashing
    Is this how you are describing? If yes, this is my answer. And no, I don't mind cutting anything. Hell, I'll add a birds nest of wires that get tangled in my clutch pedal and on my feet causing serious hazards to other drivers if thats what it takes!
