Dual color fog lights.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by taintedtattoo, Feb 26, 2024.
  1. Feb 26, 2024 at 8:41 AM
    taintedtattoo
    taintedtattoo [OP] Member
    Hey guys, a while back when browsing thru fog light info, I saw a light that had programmable dual color option. It offered the 6000k white light, and also the amber fog when needed. This seems like the perfect solution I am looking for, I can't remember who makes it? Any thoughts? and also anyone run something like this. P.S. the amber is NOT just a backlight option, it is a true fog light.
  2. Feb 26, 2024 at 8:53 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I don't recall seeing this, but I can't get to everything.
    One note; If you found such a unit, I would research before buying, there lots of henky no name LED automotive companies out there peddling lighting. Especially when looking for colors, color changing, etc. I'd be highly suspect of their creditability.
    soundman98 likes this.
  3. Feb 26, 2024 at 9:07 AM
    2wheels & Toyotas
    2wheels & Toyotas New Member
    2022 Toyota Tacoma
    The only thing that I have heard of is some companies offer amber covers that attach to the lights to change the color of them.
  4. Feb 26, 2024 at 9:30 AM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    GG may have something like this.
  5. Feb 26, 2024 at 9:38 AM
    Danner488
    Danner488 Well-Known Member
    2016 TRD Sport
    AlphaRex Double Tap. I saw them when was researching fogs.
    I wound up purchasing DD SS3 Max's so can't comment the AlphaRex's performance.
  6. Feb 26, 2024 at 10:14 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
  7. Feb 26, 2024 at 11:24 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    Wiring harness sold separately per Rigid's product description.
  8. Feb 26, 2024 at 11:29 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Toyota offer OEM dual-color LED fog lights on some of their JDM small-car models. I wish they did here -- I have to change lenses on my Diode Dynamics SS3 Pros when I want to change colors.
    rolled93slc likes this.
  9. Feb 26, 2024 at 2:31 PM
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    Lasfit has a dual color LED that replace the fog bulbs. I've had them for a year and a half, and while one did have an issue, it was warrantied no questions. I've been happy
    Andrew.arw likes this.
  10. Feb 26, 2024 at 2:35 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  11. Feb 26, 2024 at 3:03 PM
    5nahalf
    Erik
    Minnesota
    Thats why I have OEM led lamps with yellow stickers on them... Im not spending much more than $100 for fog lights.
    RIX TUX[QUOTED] likes this.
  12. Feb 26, 2024 at 3:14 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  13. Feb 26, 2024 at 3:31 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Lt. Dangle and soundman98 like this.
  14. Feb 26, 2024 at 3:35 PM
    TacoTuesday1
    FL
    seems like wasting money to cut output in half by dividing the unit into smaller beams, instead of choosing a solid yellow light that is better
    supposedly DD makes the best yellow fogs, that can run in stock bumper or steel
    Done
    I've got stock ARB fogs. They're cheap. If I ever upgrade down the road, it'll probably be DD yellow, and they'll be good.
    Yellow performs better. And looks better.
    Maybe for now would put yellow film on the ARB lens.
    jmneill, crashnburn80 and NmapFE like this.
  15. Feb 26, 2024 at 4:56 PM
    RIX TUX
    jmneill likes this.
  16. Feb 26, 2024 at 6:17 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The Rigid units quoted below are the only legitimate dual color fog light on the market that is SAE compliant. There are no others.
    PnP multi-color LEDs are utter garbage, stay away from those and don't fall for that BS. For LEDs to make multiple colors, they need to use multiple emitters, and if using multiple emitters you cannot place both in the same location as a halogen filament because they cannot both occupy the same space. So the emitters are not positioned correctly and the result is far worse glare and beam pattern than a standard PnP LED in a halogen housing.
    You can see the full review in the J583 thread linked earlier and below.
    Rigids are the only ones. Aside from using snap on yellow lenses over a white lamp, but even in that case if trying to use a snap on yellow lens over a 5000-6000k color temp, the yellow is still not actually compliant.
    If interested in the Rigid dual colors, I have a few that are basically new in box that I would sell for much less that the retail pricing. Realistically, there is no need for dual color fogs. Fogs should only be used when needed in actual poor weather and in those conditions yellow is better performing, so make all the light yellow for the best performing lamp.
    eurowner, dilbert, Laxtoy and 3 others like this.
  17. Feb 26, 2024 at 6:32 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    taintedtattoo[OP] likes this.
  18. Feb 26, 2024 at 6:33 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Those are the exact kind of products mentioned earlier that are utter garbage and should be avoided. That vendor was also banned from this forum.
    jmneill, eurowner, Chew and 1 other person like this.
  19. Feb 26, 2024 at 7:00 PM
    TacoTuesday1
    FL
    never thought I'd see deautokeyled and DD mentioned in the same place
    not everyone's gonna win I guess
  20. Feb 26, 2024 at 7:05 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Apparently the new, less expensive land cruiser will have them.
