Dual Battery/power bank reliable budget battery recommendations?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yodastacotruck, Feb 9, 2023.
  1. Feb 9, 2023 at 1:58 PM
    Yodastacotruck
    Yodastacotruck [OP] Well-Known Member
    2021 MGM 4x4 trd off road
    Stock
    Hey guys looking to build a dual battery setup with only a 50ah lithium battery running only a fridge and charging small things, did a lot of research and this seems to be the most reliable reviewed, budget friendly option:
    https://www.amazon.com/Ampere-Time-...2&sprefix=li+time+50ah+battery,aps,253&sr=8-3
    I don’t know much about this company but it has good reviews but a couple bad ones that say is only good for 6 months, these things are a pain to return I hear so I don’t want to get stuck with a paperweight, if anyone has experience with this battery I’d be interested to know your thoughts and how it’s holding up and how long you’ve had it, or some suggestions on another proven battery that’s budget friendly if not may just go the jackery or Bluetti route or save for battleborns.
    Thanks in advance guys appreciate it.
  2. Feb 9, 2023 at 7:03 PM
    JDKred
    JDKred Well-Known Member
    JD
    16 MT KDMax Tuned
    Are you planning on tying this battery to the factory system?
    I'm not sure how lithium ion batteries work with factory alternator and factory charging components.
    Assuming the use of a battery isolator is sufficient, I would recommend using a LiFePO4, again, assuming safety is not an issue.
    These batteries last 10x longer and are generally better all around. There are some things to consider though when using them in cold situations.
    For ease of use and less headache, the lithium ion is probably the best route for sure.
    If you are looking to go powerpack route, ecoflow is, IMHO, hands down the best way, especially with their new units.
    Yodastacotruck[OP] likes this.
  3. Feb 9, 2023 at 7:51 PM
    Fat taco
    Fat taco Well-Known Member
    Nor Cal
    2021 TRD SB offroad
    Pending
    Yeah I was a little leary of buying some random lithium battery off Amazon but took the leap with this battery https://www.amazon.com/gp/aw/d/B08G8HXNJK?ref=ppx_pop_mob_b_asin_title
    Its a 100ah that came with the charger and has a built in 12v socket. I don't have it connected to the truck electrical and placed it in a box big enough to fit the battery and a solar control charger (100w x 2 solar panels mounted on roof of my rtt). Using anderson plugs so I can easily remove it if I don't need it. Only had if for a month so no long term longevity test but might give ya an idea on a cheaper alternative to those solar charger.
  4. Feb 9, 2023 at 8:20 PM
    Yodastacotruck
    Stock
    No tying to the alternator just but it self, do you have a eco flow unit?
  5. Feb 9, 2023 at 8:35 PM
    JDKred
    JD
    16 MT KDMax Tuned
    I have an ecoflow river pro. Awesome unit and they just come out with an updated unit that is better. The river series is good for small electrical loads, but the delta series is a better option for higher needs. But, it's also about 500 more then the river series...
    Now that eco flow has the river and delta series with the lifepo4 battery tech, it's a far better value then the lithium ones.
  6. Feb 9, 2023 at 9:17 PM
    Yodastacotruck
    Stock
    Lots of competition for jackery now it’s a wonder why they won’t change to P04 tech
  7. Feb 9, 2023 at 9:57 PM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    I've been looking at the ecoflow delta mini. It looks like there is an eBay account 'ecoflowdirect' or something like that selling refurbished products with a renewed warranty. $529 for 883wh has me wanting to believe this is a good deal.
  8. Feb 9, 2023 at 11:19 PM
    Yodastacotruck
    Stock
    in my experience sometimes it’s better to just save up and pay retail but may be worth it life’s a gamble I guess
  9. Feb 10, 2023 at 12:00 AM
    Pakuadragon
    Pakuadragon Active Member
    2003 Extracab 4X4
    I would not advice using your alternator to charge LiPO batteries directly as they require a higher charge voltage - eventually the battery will be ruined along with your alternator. You'll need a DC to DC charger (like from Renogy) that can charge these batteries. Another option, as another has stated, is using solar with a charge controller that has a LiPO charge setting.
  10. Feb 10, 2023 at 12:02 AM
    Yodastacotruck
    Stock
    yeah I meant not tying to the battery, i need a dc to dc adapter of some sort for that correct seems far too complex compared to An agm battery
  11. Feb 10, 2023 at 12:17 AM
    Pakuadragon
    2003 Extracab 4X4
    The good part is once you have a DC to DC charger, you can charge different chemistry batteries. The advantage of LiPO is you can utilize the full rated Ah of the batt. As opposed to AGM where you're only able to use half of the Ah. Plus the LiPO has more charge cycles.
  12. Feb 10, 2023 at 12:25 AM
    Yodastacotruck
    Stock
    Are you running a system like that?
  13. Feb 10, 2023 at 12:33 AM
    Pakuadragon
    2003 Extracab 4X4
    Sorta. I have one agm batt being charged by my alternator using a Battery Doctor isolator. I also have a 200W solar setup that just charges my 100Ah LiPO. The agm runs my truck accesories and the LiPO runs my cooler.
  14. Feb 10, 2023 at 6:00 PM
    Yodastacotruck
    Stock
    That’s exactly how I wanted my setup I only want the lip04 to power a dc fridge cooler, what brand battery do you have?
  15. Feb 10, 2023 at 6:29 PM
    Pakuadragon
    2003 Extracab 4X4
    I've got a Renogy 100Ah and a very rare Costco brand AGM deep cycle size 24. I say very rare because I cant find it anyway - I believe it's been discontinued.
  16. Feb 10, 2023 at 6:39 PM
    Yodastacotruck
    Stock
    how long have you been cycling/running the Renogy LI battery? Any issues so far?
  17. Feb 11, 2023 at 4:44 PM
    Pakuadragon
    2003 Extracab 4X4
    No issues...been running over a year. Cycle wise, I don't really know - its a set it and forget it kinda setup with Renogy. The agm batt is at least 3 years. So it works for my needs.
  18. Feb 11, 2023 at 7:12 PM
    Yodastacotruck
    Stock
    Thanks for the info, I’m going to just spring the extra 70 bucks for renogy, I don’t really trust the ampere time li time battery, I just need to find the right solar controller for p04 battery
