dtc p0001....what is it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by oldjim, Sep 15, 2015.
  1. Sep 15, 2015 at 7:52 AM
    oldjim
    oldjim [OP] New Member
    jim
    1998 tacoma xtra cab trd
    receiver hitch an trailer brake controller, fifth wheel hitch
    My 98 trd has check engine light on and chek with code reader displays P0001...fuel volume regulater control circuit open... I have asked other drivers about this code and they mostly say it is an unused code and means nothing....If so why does it return? I have checked the wiring for the fuel pressure regulater and if looks ok. does anyone know what to check or replace to placate this code... Thanks for ypu help..
  2. Sep 15, 2015 at 8:02 AM
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    That is not a code used by Toyota on the 98 Tacoma. Are you sure it is not a P0101?
  3. Sep 16, 2015 at 9:23 AM
    oldjim
    jim
    Absolutely certain, The code reads P0001, verbage "Fuel Volume Regulater, Control Circuit Open". I reappeared yesterday and I checked again to be sure. I guess I will leave the check engine light on for a few days and see what happens. Everything seems to be functioning ok.
  4. Sep 16, 2015 at 10:25 AM
    thefatkid
    Brian
    Colorado
    2004 thingy
    I would try and find another code reader to see if the same code appears on that tool.
  5. Sep 16, 2015 at 11:03 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    That code does appear in lists of codes, but my '99 FSM does not list it.
    The first code mentioned in the diagnostics section is P0100.
    :confused:
  6. Sep 18, 2015 at 4:55 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Its a generic code, but i dont think it applies to this car. You would be experience other drivability issues relating to lack of fuel mixture control. Many generic codes are obsolete but are still stored inside code readers. I would clear the code and see if it comes back in a few cycles.
