Dsp? HU? Line output converter?!amp?!?! Wtf?!
Discussion in 'Audio & Video' started by Ryan914, Jul 10, 2023.
  1. Jul 10, 2023 at 9:35 PM
    Ryan914
    Ryan914 [OP] Well-Known Member
    1980 4x4 pickup, 21’ army green trd off-road 6mt
    22re, warn 8274, 33x12.5 swampers, waggys up front, chev 63’s out back, bobbed longbed. 21’ trd OR 6mt premium army green- stock
    Hey everyone, just after some opinions here… please don’t roast me if there has been a similar post and I didn’t see it on a search (I have searched!!!)
    I’ve been a little irritated the past couple weeks working on bringing some bass to my 2021 trd OR non JBL stereo (6mt blessing or curse)
    Either way, currently running a factory HU, line output converter(to right front channel apparently), kicker CXA400.1 amplifier with remote bass knob, a Skar audio fiberglass “jL stealth box” with a JL 10tw3-d4 wired at 2 ohms.
    I’ve had sealed and ported subwoofer setups before… last truck(07 ranger ext cab) had a RF p2d2 8” in a ported box tuned to roughly 35Hz with a 1000w rockville amp @ 1ohm.
    what I’m getting at is that I’ve been having the hardest time tuning my JL 10tw3 with this amp, I’ve always had aftermarket head units with sub pre-outs. I’m not trying to spend a crazy amount of money on this stereo system at the moment but looking for good sound for sure, and trying to do this in stages… I think next will be a full door speaker/tweeter swap with kicker speakers(plug and play)
    my dilemma is that I have not been able to tune this in a “linear” way… some music hits hard and low, but other music I’ve used for tuning in the past almost sounds like there is no SW at all, what do you guys think would be the best route next? HU? DSP? Or a 5.1 amplifier?
    I KNOW the factory HU limits bass output at higher levels but would a DSP or different amp bypass that better, or is it just the Amazon line output converter?
    ALSO: had a kicker L7t sealed 8 (pre-made box by kicker) in same location behind rear passenger seat before the Skar/JL enclosure… JL sounds much cleaner and doesn’t sound like a hollow thud behind the seat at low volumes. I’m not MAD at this current setup, just disappointed at times.
    thanks in advance guys.
  2. Jul 10, 2023 at 10:20 PM
    TimPall13
    TimPall13 Well-Known Member
    Tim
    Sandy Oregon
    3link SAS 02 SR5 Limited V6
    Lift: TrailGear 3link SAS with Fox 2.0 Coil overs in front. Custom Alcan Leafs with relocated Fox 2.0 shocks in rear. Sitting at 6in of lift. Armor: Relentless Fab Front bumper with home made hoops and Warn VR Evo 10s winch. Relentless Fab Rear bumper with swingout gate. Gears/Grip: 4.88 gears with ARB Air lockers front and rear. 35x12.5 Mickey Thimpson Baja Boss MTs on 17in Trail Ready Beadlock wheels. Lighting: 6000k 55w HID head lights in Retrofit Prejectors, KC Slim Light LEDs behind a Grillcraft grill and on CBI windshield mounts, And LED rock Lights. Performance: 6" deckplate mod, URD Crank Pulley, K&N air filter, ISR mod, and a AirRaid throttle body spacer, magnaflow muffler. Audio: Alpine speakers and sub running on a Alpine 5ch amp. All ran with Stinger wire kit, and a Alpine touch screen reciever. Extras: 15% Window Tint, Spray in bed liner, LineX coated factoey fender flares, Custom Roof rack/Track system, SoftTopper Canopy, Viair Dual 444c Onboard air with dual 2.5Gal tanks.
    Hey Ryan,
    I can't say for certain what is going on with your set up. It doesnt sound like this is your first setup so i apologize if im saying things you have done or tried.
    I have ran converters in past though. One thing to remember is that if you have audio tuning on your factory HU, it effects the sound coming out of your sub as well. I personally always ran my converter out of the rear speaker vs the front since I like more highs in front and lows in rear.
    Another thing, make sure you tune the sub at the volume level you plan on playing at the most often. This helps optimize the tune.
    Lastly, I'd personally go with 5ch amp at the same time you do door speakers. You will notice the gains more. If you plan on running factory speakers with you new sub for a while, then I'd look at aftermarket head unit with 5ch rca out for easier set up later.
    Hope you figure it out soon!
    Tim
    ZMan2k2 likes this.
  3. Jul 11, 2023 at 3:50 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    @TimPall13 nailed it. It’s the factory “tune” of the headunit that makes sure when you turn it up, you don’t kill the factory speakers. Problem is, as you turn it up, the bass rolls off, killing your “thump”. What you want, if you want to keep the factory H/U is a DSP, which can be as much or more than a new aftermarket H/U. So you’re left to decide how married you are to the factory H/U.
    Sorry about the wallet. :spending:
    soundman98 likes this.
  4. Jul 11, 2023 at 4:30 PM
    Ryan914
    Yeah, my wallet and or wife probably aren’t happy with me after getting two different subs/enclosures, an amp, a wiring kit, and two different line output converters in the past two weeks. Lol
    Correct me if I’m wrong, but if I did a separate amp (for door speakers and sub) wouldn’t I be able to somewhat bypass the factory head unit roll off to an extent?
  5. Jul 11, 2023 at 7:46 PM
    ZMan2k2
    Richard
    ‘Berta
    Without altering the garbage signal before the amp, it’s “garbage in - garbage out.” If you want to simplify some, the Audio Control D5.1300 is a DSP/amp combo (5-channel). Takes a little pain out of that step. There are others too, from Kenwood, Kicker, JL Audio etc. They are becoming more popular, with factory units becoming more integrated. There’s also the Kicker KEY 200.4, if you can find it, that does the tuning with a mic and some test tones for you.
  6. Jul 11, 2023 at 8:50 PM
    Ryan914
    I am aware of the garbage in-garbage out. however,If I were to install an amplifier for door speakers and subwoofer and kept the head unit at lower volumes, would this still not assist the problem with the head unit roll off? As long as I did not crank the volume on the HU obviously.
    also, on a separate note. I realized today that there is an EQ on the Spotify app, I did some adjustments with this EQ and the output on my Toyota system sounds a whole lot better. My work truck however (22 ford maverick) did not appreciate the addition settings to the speakers, I am willing to deal with this for better sound in the Tacoma. I will just have to not blast music in the work truck quite as loud I guess, even though it get many more hours and miles on it than my Tacoma.
  7. Jul 11, 2023 at 9:00 PM
    ZMan2k2
    Richard
    ‘Berta
    An interesting idea, gain matching as you suggest. It might well work as hoped, my only concern would be the amp. It might not like the lower voltage input level and hiss and crackle something awful. Really only one way to find out, find the volume where the all-pass filters kick in on the H/U and do a quick-n-dirty tune. Worst case, a reset. I’m actually very interested in this. It might be another option for those wanting to keep the factory H/U.
  8. Jul 11, 2023 at 9:10 PM
    Ryan914
    Question is, how do I find this level? I do not possess the equipment necessary for finding the factory filters to kick in. I suppose I could do it all by ear… major downside “do NOT surpass 35” on factory head unit… to anyone that drives my truck. Which honestly has only been two people other than me in the past two years, minus the service techs at Toyota.
  9. Jul 12, 2023 at 6:31 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    This is the stock headunits output at different volume levels. The stock headunit doesnt actually limit bass at higher volumes, it does seem to limit 200-400hz though
    volume level 10
    volume level 20
    volume level 30
    volume level 40
  10. Jul 12, 2023 at 9:12 AM
    Ryan914
    Interesting that the roll off is 200-400hz, maybe it just lacks the power to actually put out the lower frequencies at higher volumes?
  11. Jul 12, 2023 at 5:59 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    stupid question, but have you played with the phasing of the sub?
    if you're running the rest of the stock setup, it means you don't have a crossover on any of the door speakers. so if they're trying to emit bass, and the sub is trying to emit bass 180 degrees out of phase, the result will seem as though there's no bass.
    of course, that amp doesn't have a phase option, so you'd need to wire the sub backwards to alter it's phasing.
  12. Jul 12, 2023 at 6:57 PM
    Ryan914
    Lol, not a stupid question, and yes. I did change the phase on the sub. It’s actually sounding pretty good now. It’s just been the hardest sub/amp combo I’ve had to tune, not that I’ve really had that many. 8 if I recall, with a mix of sealed and ported. This is just the first one with a factory head unit, and with all the tech in my factory HU I wasn’t really trying to replace it so I decided to work around it. Not entirely sure if it matters but my truck has the 360 cameras as well and there’s quite a few plugs in the back of the HU.
  13. Jul 12, 2023 at 7:00 PM
    5nahalf
    Erik
    Minnesota
    The biggest issue you will run into on the stock headunit is that the rear speaker outputs are very very very low. So if you try to tap into the rear speakers for your signal, your going to be disappointed.
  14. Jul 12, 2023 at 7:12 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    My set up is on my 01 Land Cruiser, stock head unit, results will be different.
    I did lots of research on line output converters and landed on the one below. My system sounds phenomenal with a single 12" woofer. I would try a different line output converter first, if it were me. For $20 worth a shot.
  15. Jul 12, 2023 at 10:31 PM
    Zuba Gooding Jr
    Zuba Gooding Jr Well-Known Member
    200-400hz are lower mids and the most common culprit for muddy sound in small rooms. One could argue a car is a small room.
    So it would make sense that those are compensated for by the head unit for the average consumer.
    In mixing/mastering its pretty typical to do cuts in that same range to clean up a crappy or sub par mix.
    For the OP maybe get a subwoofer phase knob that allows for variable control 0-180 degrees, not just A/B polarity. Then properly phase align sub with a program like AudioTools. Also kill the rear speakers completely.
    You would want to do all this tuning with you sitting in the drivers seat as well with engine running to factor in your mass and engine frequencies.
    More sophisticated room correction includes real-time noise sampling and dynamic eq adjustments. Maybe someone is incorporating that into car audio already via an app, dont know.
  16. Jul 13, 2023 at 6:16 PM
    Bigmatt503
    Bigmatt503 Well-Known Member
    I went thru this same thing with my 2021 stock head unit. At first I had the kicker key 200.4 running mids/highs and a 8 inch Rockford Fosgate powered sub. It never sounded crisp or that great. I researched headunits and ended up installing the Sony 9500es. It's expensive but it sounds way better. Next is upgrading to a pair of 10 inch subs. In my opinion a new headunit will get you to the finish line
  17. Jul 13, 2023 at 7:41 PM
    bismarck
    bismarck Well-Known Member
    2023 TRD Off Road
    I went with buy once cry once.
  18. Jul 13, 2023 at 10:41 PM
    Ryan914
    Bismarck, I had been waiting for your update, I believe in the “what did you do to your 3rd gen” thread… I believe you also have the Skar audio box, what driver did you install in the box and how has it been sounding?
  19. Jul 14, 2023 at 12:00 AM
    bismarck
    2023 TRD Off Road
    I got a kicker.
    https://www.amazon.com/gp/product/B08NFJK21W?ie=UTF8
    It sounds pretty good. down the road, I may buy a better sub. JL, Rockford Fosgate are a couple I'm looking at.
    If there's a good deal on black friday, I'll pick one up then. Till then, I'm good with this.
    waiting for a mic to do the sound check. I ended up using an old laptop for the sound check, using TrueRTA for the software, https://www.trueaudio.com/rta_abt1.htm.
    I got a M-Audio interface. The mic comes in on Monday, so I should be done next week heat permitting.
