Dryflow vs. Oiled filter
Discussion in 'Performance and Tuning' started by 05RedTaco, Sep 24, 2010.
  1. Sep 24, 2010 at 5:00 PM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Give me your opinions... Which is better, safer for the engine? I am mostly concerned about longevity of the engine & easiness of washing the filter.
    I am leaning towards the aFe, because, I am not fan of oiling the filter.
  2. Sep 24, 2010 at 5:15 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    i've had a K&N for 5 years and no probs. you have to be a moron if you cant oil a filter correctly.
  3. Sep 24, 2010 at 5:18 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    i have dry and just shake it out once a week and wash once a month
  4. Sep 24, 2010 at 8:09 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I've had K&N's for atleast 10 years in various vehicles. Never had a problem with them and I cleaned/oiled them twice a year. With this truck, I decided to try the AFE.
    With both K&N and the AFE - I used the AFE/K&N cleaning agents (and oil for K&N).
    The K&N has much better/more air flow than the AFE.
    The AFE is easier to clean simply because you don't have to apply oil to it.
    It all depends on what you want out of it. If you over-oil the K&N, it can give you problems. If you don't clean ithe K&N enough, can cause dust to pass through it.
  5. Sep 25, 2010 at 8:00 PM
    ScootsOFP
    ScootsOFP Well-Known Member
    Scoot
    Wisconsin
    03 PreRunner SR5/TRD
    deckplate, white LED gauges, fog light mod (Beau02 write up), Scion t1814 head unit
    I go with AFE prodry just because it seems like it'd be way to easy to accidentally over oil and mess up my MAF.
  6. Sep 26, 2010 at 12:37 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    ... i even have a K&N in my quad and dirtbike. never had any probs. i guess it all personak preference.
  7. Sep 26, 2010 at 3:01 PM
    00tactrouble
    00tactrouble Active Member
    South Texas
    2000 Toyota tac prerun
    New Dakota A/T tires in 31x10.50-15", 2 coat Rhino Liner on the the bed, Mossy Oak package interior, 8" bazooka system pumping my jams, Platinum system plugs underneath the hood with Gates belts keeping it turning, 6" deckplate mod and amsoil is keeping this thing lubed year around.
    What do you guys think about the spectre air filters?
  8. Sep 26, 2010 at 3:44 PM
    05RedTaco
    Tony
    Scottsdale
    Spectre = Autozone crap.
  9. Sep 27, 2010 at 8:24 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Check out bobistheoilguy web site. They review oil analysis results showing differences between air filters. From what I've researched, the K&N gives worse oil analysis results than the AFE dry. In other words, more dirt passes the K&N vs. the AFE, but note that the clean AFE also passes more dirt then a stock filter.
    It's all airflow vs. filtering ability. Do some more research if you want more details. If you are getting/wanting more airflow, then filtering ability has to decrease. A clean K&N or AFE does not filter as well as a dirty K&N/AFE, but they do flow more air.
    And as for cleaning and oiling, I've had a couple in the past and have decided I'm done with oiled filters. Stock or AFE for me. Biggest pain for oiled filters is that they need to be completely dry before oiling. As such, you need to have the truck down for half/full day, or keep a stock filter around for when the oiled filter is drying.
    slinkz419 likes this.
  10. Sep 27, 2010 at 10:35 AM
    05RedTaco
    Tony
    Scottsdale
    Thanks for the input! Your posy actually makes sense and is not biased towards one brand.
    This post convinced me to go with aFe. I want to be able to clean the filter easily and fast, I am not so concerned about flow. Really at the end of the day, what is the difference in horsepower between K&N & aFe? Maybe 0.5rwhp?
    aFe I am willing to sacrifice some flow for easiness to clean & better filtration.
