Drum and shoe kit for rear
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Jan 28, 2019.
  1. Jan 28, 2019 at 8:21 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    Go OEM , Centric, or Powerstop? OEM around $375 and the other two around $125 for complete rear
    Drums (2), shoes, wheel cyl (2), and hardware
  2. Jan 28, 2019 at 2:11 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    As of Late I have been using Napa Ultra Premium Brake parts
    Never used any other parts but Toyota
  3. Jan 28, 2019 at 2:38 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Drums are real finicky, anything aftermarket is a crapshoot. For drums I'd for sure go OEM unless @Wyoming09 knows for sure that drum kits from Napa are good quality. Lots of other people using other stuff and having nothing but problems with them being out of round and stuff.
    Wyoming09 likes this.
  4. Jan 28, 2019 at 2:44 PM
    vettehigh
    Jon
    Upstate, NY
    I'll stick with OEM...does anyone know if there is an OEM hardware kit for the rear?
  5. Jan 29, 2019 at 12:35 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Knowing Toyota you most likely you have to buy the parts one by one
  6. Jan 29, 2019 at 12:44 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    This might seem strange but brake drum must be stored flat since this tends to take up more space lots of vendors tend not to follow this. Does not take much to cause one to go out of round .
    When I was told this long ago I thought I was being teased but over the years had a few brake manufacture Reps confirm this
    Might be some of the reason so many are out of round plus poor quality control
  7. Jan 29, 2019 at 4:13 AM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    When I changed the shoes on my old Nissan, I got shoes from Auto Zone...
    I couldn't install them, at first I was sure it was my back-yard ability that was the
    fault. Finally, I went and got NAPA ones, and they "fell into place out of the box"... nowadays
    I'd probably just get OEM...
    -Mike "still only have back-yard ability..."
    tony2018 likes this.
  8. Jan 29, 2019 at 10:19 AM
    vettehigh
    Jon
    Upstate, NY
    One by one is right for the hardware hit...damn. Would any of these hardware kits work well instead to go along with all the others being OEM: ACDELCO, CARLSON, CENTRIC, RAYBESTOS, BECK ARNLEY, or WAGNER?
  9. Jan 29, 2019 at 10:39 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Just get a kit from Napa. The drums themselves are really the only thing that needs to be of a trusted source.
  10. Jan 29, 2019 at 1:54 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I would venture I used most of the different brands before they got made in China or Mexico
  11. Jan 31, 2019 at 9:13 AM
    vettehigh
    Jon
    Upstate, NY
    Just went all OEM. 2 drums, 2 wheel cylinders, and shoes for $360 shipped
    The hardware will be from Carlson...$30 shipped
    JJ04TACO likes this.
  12. Feb 1, 2019 at 12:23 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I tried aftermarket drums once. Hit the brakes and the whole rear shuddered worse than an out of balance washing machine. I only buy OEM these days. Maybe pricey sometimes, but most of the shit i replace lasted 10-15 years. Worth the expense.
    Glad you went OEM...
    2002Tacoma4x4 and vettehigh[OP] like this.
  13. Feb 2, 2019 at 8:50 AM
    vettehigh
    Jon
    Upstate, NY
    Just received my parts. Any idea time wise how long it takes to change out the drums, shoes, hardware, wheel cylinders, and bleed?
  14. Feb 2, 2019 at 9:49 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Depending on skill level I’d say a few hours. Disassembly is pretty quick. Do one side at a time so you can have a complete side for reference.
    Cylinders are fairly quick. If you’re speedy, you can minimize the amount of air in the lines. Bleeding doesn’t take long. It’s reassembly that takes time. Adjust your shoes so that the drum barely fits over and spins with little drag. Then you have minimal adjustment to do with the drum on.
    Also, practice adjusting the shoes from the rear with the drum offso you can visualize what’s happening inside when the drum is on...
    vettehigh[OP] likes this.
  15. Feb 6, 2019 at 7:52 AM
    vettehigh
    Jon
    Upstate, NY
    My mechanic told me $95-$120 labor for the complete rear. Seems fair to me
  16. Feb 6, 2019 at 8:00 AM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    That’s a good price on labor imo, unless you have a power bleeder bleeding brakes is a complete bitch by yourself.
    vettehigh[QUOTED][OP] likes this.
  17. Feb 6, 2019 at 8:51 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    That’s isn’t bad at all. They are probably way faster given their experience level and equipment...
    That’s about an hours labor?...
  18. Feb 6, 2019 at 9:19 AM
    vettehigh
    Jon
    Upstate, NY
    Figure 1.5 hours if all goes as planned
  19. Feb 6, 2019 at 9:27 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Nice. I'm still too cheap to pay for labor. Unless its a big job. But sometimes it's worth it for the little stuff too.
  20. Mar 29, 2019 at 7:25 AM
    vettehigh
    Jon
    Upstate, NY
    Getting my complete OEM rears done today. The ones that were on there were go as new I guess, but I wanted all OEM. Should I sell my rears (drums/shoes/hardware)?
