Drum Adjuster Not Touching Star Adjuster
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wicked1, Jan 4, 2024.
  1. Jan 4, 2024 at 12:21 PM
    wicked1
    wicked1 [OP] Well-Known Member
    I had new wheel bearings put on, which requires disassembling the drums. The mechanic put new pads on, while everything was apart. Braking was not good when I got it back..
    The drums needed to be adjusted, which helped. But they aren't auto-adjusting w/ the parking brake. And more concerning is the drivers side adjustment lever does not touch the star adjuster.. I can spin the adjustment wheel freely in both directions, so it might be able to loosen itself.. I took the drum off to look. It all looks OK. It's assembled correctly. And I noticed if I push the front shoe up, or rear shoe down, the adjuster lever does make contact w/ the wheel. But when I get it all re-assembled, it no longer contacts.
    Anyone have any ideas? It's all held loosely together w/ springs, so I can't figure out how to keep it all aligned. I guess I should take it back to the shop... But they didn't get it right the first time, so if I can fix it... I'd like to. (and I do almost all the work on my truck.. Pressing the bearings on was a bit more than I wanted to try, though, so took it to a shop)
    My guesses are maybe it needs new springs.. (they weren't replaced.. only the shoes were). Or the aftermarket shoes they used might have an issue.
    Thanks for any advice.
  2. Jan 4, 2024 at 12:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    While my case wasn’t exactly like yours.
    Mine was due to misshapen aftermarket springs. The spring was bent in the wrong location. Which was pushing the lock bar off of the star adjuster.
  3. Jan 4, 2024 at 12:55 PM
    Waasheem
    Waasheem
    2007 xrunner
    Ive seen this happen with aftermarket parts. Sometimes you can bend the lever slightly to get it to work. It’s pretty easy to get the reassembly incorrect. Find a pic of how it’s supposed to be assembled, compare to yours.
  4. Jan 4, 2024 at 1:28 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Aftermarket adjuster arms won’t work, you’ll need oem.
    TnShooter and FastEddy59 like this.
  5. Jan 4, 2024 at 1:56 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    IMO adjusters are voodoo magic that dont work no matter who makes them or how much you lube them. Obviously the arm should at least hit the star wheel though. Id find pics of how its supposed to be as Washeem said or compare to the other side.
  6. Jan 4, 2024 at 2:38 PM
    wicked1
    Thanks for the replies..
    It all looks fine.. It's definitely assembled correctly. But each side can shift up and down.. And when it shifts, it's off again.
    I can get it all aligned w/ the drum off. I can adjust it, with it clicking properly, as I repeatedly put the drum on, adjust the shoes wider, put the drum on, repeat.. Until it's a tight fit.
    I put a couple lug nuts on it, to hold the drum in place.
    I give it a few more clicks of adjustment from the back, so there's a slight drag.. Everything still working properly w/ the adjuster clicking/only spinning in one direction..
    Then I apply the brakes, apply the parking brake. It all feels OK as far as pedal pressure and number of parking brake clicks.
    But then I check the adjuster again, and it's freely spinning either direction.. The lever thing has moved again.
    I really want to just buy new shoes and springs and do it all over myself... But then I'm throwing way a bit of money.
    I guess I could spend the $30 on a spring kit, though, and try that w/ the shoes they sold me.... (I'm not liking the looks of the shoes they sold me, though... urg.. Hate mechanics.. I think he's lying to me about the parts brands, too.. He said he'd use OEM wheel bearings, but they are not. (The outer housing which is visible externally is machined differently to OEM ones). He said these are PFC shoes, costing $90, but I cannot find any such product.. And this shop came highly recommended....)
    (I know PFC is a real company.. I have their pads in my front calipers.. But I can't find any rear shoes from them)
  7. Jan 4, 2024 at 3:10 PM
    Waasheem
    Waasheem
    2007 xrunner
    If the star doesn’t touch the arm, you shouldn’t hear clicking. Or maybe you’re just referring to, if I adjust the star this much it WOULD click?
    I would be concerned too. Don’t leave it like that for long. The star could potentially loosen, causing less braking force or worse, blown wheel cylinders. Now you have brake fluid everywhere, contaminated shoes.
  8. Jan 4, 2024 at 3:17 PM
    wicked1
    At that point it is clicking properly.. It's aligned properly.. Until I give it full braking force. Then things shift around, I guess.
  9. Jan 4, 2024 at 4:21 PM
    Waasheem
    Waasheem
    2007 xrunner
    SR-71A likes this.
  10. Jan 5, 2024 at 6:37 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Classic symptom of a "stretched" cable. The one that holds the metal piece that clicks (ratchets) the self adjuster. It's a very common issue on older drum brakes. I've worked on drum brakes going back into the 70's and seen this issue a hundred times. A brake parts kit at any good auto parts house with a new cable will do it. You can even bend (tweek) the metal.part of the cable where the eyelet crimps the cable. This in essence shorten the cable to eliminate the excess stretch.
    BTW make sure you have the shoe with the shorter brake material on the forward facing position. These are "self energizing" brakes. Its a common mistake to mix the shoes position.
    And a new brake "hardware" or spring and misc. kit is cheap and always a good idea.
    Not thoughly cleaning/white lubing the adjuster is also common. That will hinder proper self adjusting
    Jimmyh likes this.
  11. Jan 5, 2024 at 10:45 AM
    wicked1
    Thanks for the replies.. I rebuilt it all again, and so far.. seems OK.
    (and I guess I'll mention, I don't "hate mechanics", like I said a few posts ago. All the mechanics I know are awesome, problem solving, fun people. I guess I hate shop owners, though... Just be honest!! WTF.. If they need to make more on a job, say it took longer than expected so we need to charge more labor.. Don't make up a fake part you can charge 3x the normal rate for.. urg..)
    SR-71A likes this.
  12. Jan 5, 2024 at 11:05 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    The self adjusting rear drum brakes is the one topic this forum has not figured out yet, imo.
    SR-71A likes this.
