DRL on with interior dash illuminated
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jdeutsch, Aug 29, 2018.
  1. Aug 29, 2018 at 6:39 PM
    jdeutsch
    jdeutsch [OP] Member
    21’ OR / DC / 4x4 /Cement
    I have a 18’ OR - I have seen a couple posts relating to this. I want my LED DRL’s on with my interior dash/cluster lights on as well without having to select parking lights or headlights.
    Anyone seen any mods for this?
  2. Aug 30, 2018 at 12:38 AM
    Massappeals
    Massappeals Guest
    You mean like having it one notch up from DRL? One notch under low beam on.
  3. Aug 30, 2018 at 6:28 AM
    3Tacos
    3Tacos Well-Known Member
    Maine
    2017 Silver. TRD OR DCSB
    What is this sorcery of which you speak?
  4. Aug 30, 2018 at 9:01 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    its the second option after drl, it looks like a break lights icon, it will keep your drl lights on and turn on your console lightning and also you rear lights without turning on your headlights.
    gurneyeagle likes this.
  5. Aug 30, 2018 at 9:03 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    sooooooooo basically the parking lights + fogs?
  6. Aug 30, 2018 at 9:04 AM
    LivinOnEdge
    Land of The Lost
    Fogs is a seperate option, tail lights will be active though.
  7. Aug 30, 2018 at 9:07 AM
    LivinOnEdge
    Land of The Lost
    OFF = OFF
    DRL = Daytime Running lights only
    DⱭ = DRL+Tailights+Console Lights
    D= Headlights+tailights+console lights
    The secondary turnstyle is dedicated to fog lights on/off
    Ganjafornia likes this.
  8. Aug 30, 2018 at 9:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just saying: The existing set up is a feature, not a bug. My opinion, after seeing way too many cars driving around with just DRLs in the middle of the night, is that back lit gauges with DRLs only or full time backlit is bad bananas. There is no way to even signal peeps that do this.
    Yesterday, I came up behind a Forester running like this. Flashed my lights. All they did was slow down from the 60mph speed limit to something under 40 for whatever reason. They never figured out the problem.
    Even peeps coming the other way running dark have no clue after trying to signal them.
    Like I said, just my thoughts.
    Clearwater Bill likes this.
  9. Aug 30, 2018 at 9:14 AM
    LivinOnEdge
    Land of The Lost
    Here in sunny (hot af) california, we occasionally get a light fog. It's nice to have the option to show your existence from the front and the back without necessary headlights during a morning commute. Just my two cents.
    tonered[QUOTED] likes this.
  10. Aug 30, 2018 at 9:17 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I hear you. We do have that option with the parking light function. Dashlights are on, DRLs are on, front ambers and rear reds are on, and fogs are available.
    DRLs only and dash lights in fog is not good, IMHO?
    The usual reasoning for backlit gauges plus DRLs only is for tunnels.
    LivinOnEdge[QUOTED] likes this.
  11. Aug 30, 2018 at 9:22 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Subarus light setup is the absolute worst. I prefer how Toyota has it. I drove around in my wife's Subaru with the rear lights off more than a couple times. It's confusing for sure.
  12. Aug 30, 2018 at 9:26 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Exactly. They are not the only ones. Although prior to the newest ones, Subaru freaking used dimmed high beams for DRLs. I hated those in daylight let alone when folks run with just DRLs at night. I did the courtesy of unplugging the DRL connector on my wife's Forester. She leaves it in Auto mode, so we're at least not dazzling folks in daylight.
  13. Aug 30, 2018 at 9:31 AM
    toyotatacomaTRD
    Good idea. I will say, I got very good at changing out headlights. I don't think I went 7-8 months without replacing one. I wouldn't go anywhere without one in the glove box.
  14. Aug 30, 2018 at 9:44 AM
    LivinOnEdge
    Land of The Lost
    I mean, fogs wont turn on anyway until you switch to parking lights anyway so if anything its just another unnecessary light to turn on unless of course you have dense fog then yes, use the fogs. I rarely get fog bad enough that I cant see 10 feet in front of me though. Again. YMMV
  15. Aug 30, 2018 at 9:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    But, that is not what the OP is wanting to do.
  16. Aug 30, 2018 at 9:49 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    Glad Toyota has done it this way. Having a dash lit up all the time causes people to drive at night with no lights on. It's got so bad that Canada is now mandating daytime running TAIL lights starting in a couple years...
  17. Aug 30, 2018 at 9:49 AM
    LivinOnEdge
    Land of The Lost
    Then I honestly don't understand the issue so I'm out ¯\_(ツ)_/¯
    :D
  18. Aug 30, 2018 at 9:50 AM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    Aren't headlights on during fog not so you can see but so that others can see you?
  19. Aug 30, 2018 at 9:52 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry! :cheers:
  20. Aug 30, 2018 at 9:52 AM
    wahudiditagain
    wahudiditagain Well-Known Member
    Wes
    Central Ohio
    2017 TRD OR DC 4x4 Inferno
    This is a huge problem. Every night I drive home from work I see someone with only DRLs on.
