drizzohs '21 off-road build
Discussion in '3rd Gen. Builds (2016-2023)' started by drizzoh, Dec 17, 2021.
  1. Dec 17, 2021 at 9:01 AM
    drizzoh
    drizzoh [OP] itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Sup d00ds, I'm Andrew and I have a 2021 Tacoma Off-Road 4x4 DCSB that I ordered in June '21 with no options other than tech package because I knew I would mod everything else.
    I'm very into the OEM+ feel and I'm learning that I'm generally not happy with off-the-shelf anything so I've put a ton of work into modding mods and tweaking settings for my liking. That includes doing full custom paintwork for the interior trim, rebuilding a TRD Pro knob to fit with the OR color scheme, changing leaf packs a few times and having the ADS 2.5" shocks revalved twice. It was nice having a daily driver so I could put the proper amount of time into doing modifications correctly and getting this setup exactly the way I wanted.
    I need to get better about taking pics of this thing, but here's a few:
    Ze Build Specs:
    Engine & Performance:
    Custom KDMax Pro 10 Tune
    K&N 57-9039 Intake Kit
    TRD Intake Flow Accelerator
    Borla High Clearance Y-Pipe
    Magnaflow Overland Series SS Catback Exhaust
    Powerstop Z36 Extreme Brake Pads
    Powerstop Drilled & Slotted Rotors
    Crown Performance Extended SS Brake Lines
    RedlineTuning +7" Hood Struts
    Fumoto F-133 Oil Drain Valve
    OEM Metal Oil Filter Housing
    OEM TRD Oil Cap
    OEM TRD Radiator Cap
    A/C Drain Mod
    Suspension:
    ADS 2.5" Extended Travel w/ Reservoirs & Clickers (Custom Tuned)
    JBA HD Upper Control Arms
    WarFab Tie Rod Sleeves
    OEM 4Runner Lower Shock Bolts
    Wheelers Superbump Bump Stops (Front)
    Cab Mount Chop w/ Total Chaos Plates
    Deaver J66 Leaf Packs
    Toytec 1/2" Rear Axle Shims
    Archive Garage Hammer Hangers
    Archive Garage 3.6" Shackles
    Archive Garage Stealth HD U-Bolt Flip Kit
    Archive Garage Yellow Speed Bumps Bump Stops (Rear)
    ARB FK29 Carrier Bearing Spacer
    Sway Bar Delete
    Exterior:
    Morimoto XB Evo Headlights w/ Superchargers & XPEL PPF
    Diode Dynamics Elite Series Fogs
    OEM TRD Pro Grille w/ OEM TSS Garnish
    Heritage Grille Badge
    Raayoo Front Camera
    Hella Supertones Horns
    OEM TRD Skid Plate
    Ark Splash Guards
    Squareone Creations Frame Caps
    SNS Designs ABS Sensor Guards (Front)
    Westcott Designs 20° TIG Welded DOM Rock Sliders
    Black Painted Calipers & Rotors
    MESO V5 Sequential LED Side Mirror Turn Signals
    AVS Low Profile Smoked Window Deflectors
    MESO 'The Gasshole' V1
    Archive Garage ABS Sensor Skids (Rear)
    OEM Header Bed Rail w/ End Caps
    Rocky Mounts Driveshaft Track Bike Mounts
    Charvonia Designs Billet Tie Downs
    @TMCmakes Wheel Deal's Bike Wheel Mounts
    OEM Bed Mat
    OEM LED Bed Lighting Kit
    OEM 2016-19 Driver Side Bed Storage Compartment
    Total Chaos Bed Stiffeners
    OEM Electronic Tailgate Lock
    OEM '21 TRD Pro Tail Lights
    MESO Total Tail Stage 1
    TRD Heritage Tailgate Badge
    EyeCatcher Tailgate Letter Inserts
    Interior:
    OEM LED Homelink Rearview Mirror
    Banks iDash SuperGauge
    MESO Custom 9-Switch Left Panel
    AOB Factory Style Push Switches
    OEM Glass Breakage Sensor w/ Tundra Mic
    Cali Raised LED 6000k Interior LED Kit
    VLEDS Aqua Footwell Lighting
    Qi Charger Delete
    Door Beeper Speaker Removed
    Screen ProTech Film Protection Kit
    Tacos4Cheap MGM Glove Box Letters
    Tacos4Cheap MGM Bucket
    JKCOVER Glove Box Organizer
    K&N VF2005 Cabin Filter
    OEM RAV4 Cubby Light
    Z Precision Cup Holder
    Custom MGM Full Dechrome
    Custom OEM TRD 'Off-Road' Shift Knob
    MESO Black TRD Push Start Button
    MESO Extended Fuse Cover V2
    MESO Steering Wheel Control Fix
    MESO Black Door Handle Covers
    Suntek CIR Window Tint
    JDMCAR Rubber Center Console Inserts
    JSTOTRIM Seat Bolt Covers
    Tufskinz Heritage Door Sills
    Black TRD Striker Covers
    Husky X-Act Floor Liners
    Wheels & Tires:
    Volk RAYS 17x8.5 -10 TE37XT M-Spec Wheels
    9SIX9 17x8.5 -10 SIX-1 [TE37 Rep Spare Wheel]
    Nitto Ridge Grappler 285/70r17 C-Load Tires
    WheelAdapter.com Extended Lug Studs
    Muteki SR45R Lug Nuts
    Hodakaguy's Spare Tire Hoist Relocation Mod
    Audio:
    Pioneer DMH-WC6600NEX
    JL Audio VX700/5i DSP Amplifier
    Focal Flax Evo PS 165 FXE Component Front Speakers
    Focal Flax Evo PC 165 FE Coaxial Rear Speakers
    JL Audio Stealthbox w/ JL 10TW3-D4
    iDatalink Maestro RR2 Interface Module
    JL Audio Water Resistant Master MAXI Fuse Block
    KnuKonceptz Wiring
    45 sq/ft of Second Skin Damplifier Pro Deadening
    36 sq/ft of Second Skin Heatwave Pro Thermal Insulation
    Other Accessories:
    Overland Equipped Auxiliary Power Kit
    Cali Raised LED Relay Holder
    Aspire Brite Box Fogster
    Baja Designs 30" S8 Light Bar
    Baja Designs S2 Chase Light
    Fluids:
    ATE TYP 200 Brake Fluid
    Mobil1 0w20 w/ TRD Filter
    Redline CV-2 Grease
    Awaiting Install:
    Performance Pedals Billet Aluminum Pedals
    ExperiMental Designs Anytime Locker
    Future Plans:
    ARB Air Compressor w/ Tank
    FS Thread w/ take-offs and other items: drizzoh's 3g parts for sale thread | Tacoma World
  2. Dec 17, 2021 at 9:02 AM
    Tacospike
    Two Trucks
    Looks great!
    drizzoh[OP] likes this.
  3. Dec 17, 2021 at 9:04 AM
    drizzoh
    Andrew
    Arizona
    Pics from suspension install weekend:
    Took 3.5 months for all these parts to finally arrive. Was hoping to do this the week I took ownership of the truck.
    ADS 2.5" Extended Travel shocks w/ reservoirs and clickers | Icon RXT Leaf pack | JBA HD Arms | Wheelers Superbumps w/ Archive Garage u-bolt flip kit
    EDIT: These leaf packs have been replaced with the Deaver J66 (RXT is too stiff for a truck without additional weight).
  4. Dec 17, 2021 at 9:16 AM
    drizzoh
    Andrew
    Arizona
    Custom interior dechrome:
    Started with all the MESO pieces but wasn't thrilled with their fit and finish, so I dechromed the OEM pieces and repainted a few of the MESO parts I liked to end up with a very clean interior color scheme that most wouldn't notice was modded if they didn't know.
    OEM trim after chrome removal:
    Primed, painted and 1k cleared:
    MESO MGM vs my painted pieces:
    Center console [ac controls have since been paint-matched but not pictured here]
    Polythemus and FlyingBison like this.
  5. Dec 17, 2021 at 9:31 AM
    drizzoh
    Andrew
    Arizona
    Other odds and ends photos. Probably stuff most of you have already seen already, but..
    Morimoto Gen2 XB LED Headlights vs OEM Off-Roads:
    OEM RAV4 XLE radio knobs installed. Haven't seen anyone else running these either on this platform which is pretty cool. They're fantastic to use and look great.
    Needed to shave down the back side of the RAV4 knobs so they would work with the push button functions - then they were pnp:
    Before:
    After:
    Offroad side markers vs the smoked sequential ones from Taco Garage:
    Morimoto XB LED fogs vs OEM (these have since been swapped out for the DD Elites):
    When doing the electronic tailgate lock, I added a little deadening added to the tailgate to help it not sound so cheap when closing:
    Already had to deal with a really annoying rattle behind the glove box (<1k miles on my truck):
    Stock Wranglers vs Nitto Ridge Grappler 33's:
    Before mounting :)
    MulletTaco and MGMDesertTaco like this.
  6. Dec 17, 2021 at 10:17 AM
    drizzoh
    Andrew
    Arizona
    More rando's:
    OEM paper tweeters vs the Subaru Kickers. Decent upgrade and love the ease of install. Would be considerably happier if these were $60 though vs the $110 they currently are, but nice temporary audio upgrade until I finish the system.
    OEM vs WheelAdapter.com '1/2" Extended lug studs'. Unlike a girl on her third date, I was not as excited to find out these were actually bigger than advertised.. but after drilling a few holes, they're in and I feel much safer having like 18 lug turns on my Volks vs the 5.5 I was getting with the tiny stock studs. Fronts were easy to replace (just had to bend the dust shield out of the way). The rears required drilling a 3/4" hole in the drum backing plates. This was preferable to doing a complete brake disassembly and pulling the axles out. There's already a bunch of holes and rubber plugs on that piece so this should not cause any structural issues - especially with them being 5/32" thick. I have new plugs on order as the ones I originally ordered were much too thin to fit that thick of a surface. Found a flat spot where I only had to remove 1 of the lighter tensioned springs and the install went pretty smoothly. These lugs are some long boiz. Also what is up with the paper gaskets on the rear end? I removed them and coated the mating surfaces with anti-seize.
    And an older garage pic showing off the Taco and daily tC:
    MGMDesertTaco likes this.
  7. Dec 17, 2021 at 10:48 AM
    drizzoh
    Andrew
    Arizona
    Thanks Tacospike! It's been the most frustrating build of my life but hoping it will all be worth it.
    Tacospike[QUOTED] likes this.
  8. Dec 20, 2021 at 10:38 AM
    drizzoh
    Andrew
    Arizona
    Alignment day!
    Went to see my buddy Eddie today @ Forza Automotive in Tempe, AZ and got my truck set @ 4° caster and in spec for all the rest. No issues achieving this with the JBA HD UCA's and so far no more rubbing with the 285's. MPG also went up 3+ mpg on the drive back to the west side of town. Took 3 times on and off the rack to get it perfectly dialed and it was absolutely worth it. The ride is so much better. Been going to Eddie for 10+ years and highly recommend this shop if you are in the area. One of the few shops I actually feel comfortable letting work on my vehicles.
  9. Dec 21, 2021 at 8:46 AM
    drizzoh
    Andrew
    Arizona
    Annnnd alignment didn't change ride quality as much as I was hoping, so the suspension is off and being sent back to ADS for a revalve. Still way too stiff on the road even @ full soft.
  10. Dec 21, 2021 at 12:34 PM
    oyemengitsamie
    oyemengitsamie amie.
    Gainesville, FL
    2020 Toyota Tacoma SR V6 4x4 in MGM
    how are you liking the morimoto xb headlights? about to pull the trigger on a set.
  11. Dec 21, 2021 at 12:54 PM
    drizzoh
    Andrew
    Arizona
    The output is pretty fantastic and they are super clean. Better looking and brighter output than the factory led offering and with a much sharper cutoff and a better warranty. Output is significantly improved vs just putting an led in the factory housing - I was not happy at all with the Morimoto 2 Stroke 3.0s. I come from a history of retrofitting my cars and I would say the 2.0 version is probably a bit brighter than a standard rx350 retrofit with hids but likely not as bright as if you went ahead and did quad rx350 projectors.
  12. Dec 21, 2021 at 12:58 PM
    oyemengitsamie
    Gainesville, FL
    damn, those look sexy! I plan on going with the amber DRL. I'm glad you're liking them. I was gonna go OEM LED, but I really wanted the amber DRL.
    drizzoh[QUOTED][OP] likes this.
  13. Dec 21, 2021 at 1:08 PM
    drizzoh
    Andrew
    Arizona
    Thanks man, Morimoto did a nice job on these. The amber led would be amazing paired with the amber fogs, but with my truck being white I thought I'd keep it clean and match em up. And the switchback from the 5500k drl to amber sequential turn is trick. If you put sequential side mirror signals, these have the sequence going in the same direction as well unlike factory.
    They were a full pnp install as well, but aimed super low out of the box. Needed to crank them up a bit, but they adjust like normal lights with a #2 Phillips screwdriver.
  14. Dec 21, 2021 at 1:10 PM
    oyemengitsamie
    Gainesville, FL
    was the install hard?
  15. Dec 21, 2021 at 1:43 PM
    drizzoh
    Andrew
    Arizona
    Not bad at all. If you've changed the grille that's 1/3 of the install. Just grab extra blue and orange plastic fender clips as they're one-time use. A bag of 100 is like $7 on Amazon. They're some good videos available. Not sure which one I used, but I only separated the bumper enough to be able to swap the lights.
  16. Dec 22, 2021 at 7:52 AM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Are those horns on the OEM brackets and OEM wiring? Got any sound clips of them? I'd like something a bit beefier than stock but haven't really found it yet.
    Good build!
  17. Dec 22, 2021 at 1:44 PM
    drizzoh
    Andrew
    Arizona
    Thanks d00d!
    The horns are bolted to the stock locations with the factory hardware and the stock wiring harnesses fits onto the Hella's prongs. From there all you need to do is build a ground loop from the other terminal back to the mounting bolt or a ground of your choosing. Pretty simple install. I dig the sound and volume if the vehicle already has dual horns as standard. If you have to split a single connection into 2 they should a bit like clown horns - but they're not bad on my OR or my tC. I don't have any clips of them but the internet is riddled with them. If you do have to split a single connection into 2 (IIRC some SR's have only a single horn), I'd recommend adding their the relay so they get proper power.
  18. Dec 23, 2021 at 9:25 AM
    drizzoh
    Andrew
    Arizona
    Shocks on their way back from ADS with the new valving. Hopefully will arrive to be able to be installed this weekend. Until then, truck still chillen in hovercraft mode.
    MGMDesertTaco and Finn-2187 like this.
  19. Dec 26, 2021 at 4:23 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    Looking clean!!
    All this work before even the first oil change.
    Can’t wait to see how much more work you put in within a year.
  20. Dec 27, 2021 at 7:28 AM
    drizzoh
    Andrew
    Arizona
    Appreciate it vivid. Was hoping to have everything that's been done so far accomplished in the first month, but parts delays put a damper on my progress.
    I saved up for about 2 years to get this build underway so I could go HAM once I got it. Stance was most important to knock out right off the bat, but already far-exceeded the initial budget. Much more to come though :cool:
    vivid02[QUOTED] likes this.
