Driveshaft clunk - changing from Park to Drive or Reverse
Discussion in '1st Gen. Tacomas (1995-2004)' started by dmk679, Sep 11, 2023.
  1. Sep 11, 2023 at 8:50 AM
    dmk679
    dmk679 [OP] Well-Known Member
    Orlando, Florida
    2002 2wd 4door automatic doublecab 5vz-fe 3.4L v6 prerunner
    Extremely loud clunk when changing from Park to Drive, or Drive to Reverse or vice versa. Vehicle drives perfectly fine except when letting off the gas (coasting) and accelerating will get the same clunk.
    With transmission in neutral, the driveshaft will turn about 1/4 turn before engaging the rear. Seems like it the driveshaft is loading up and causing a lot of noise due to the rear end being loose.
    All u-joints are greased and appear fine. I've greased the rear slip yoke and no change. The carrier bearing appears fine. The transmission and motor mounts appear fine also.
    I'm thinking the rear is too lose which is causing this issue or am I way off base here? Need some help!
    Videos added on Oct 6, 2023 at 1800 Eastern
    Driveshaft movement (about 90 degrees) when parked and in neutral
    https://youtu.be/-36b3aI0xug
    Carrier bearing movement (which I believe is a normal amount of movement)
    https://youtu.be/KatJkvdJRpg
    Vehicle is stationary and driver switches between Reverse and Drive several times, and pauses in Neutral for about 5-6s during the gear transition. No sounds/clunk is made during this maneuver due to the pause while in Neutral.
    https://youtu.be/7SPWokpYXwM
    Vehicle is stationary and driver switches between Reverse and Drive several times, and pauses in Neutral for 1s during the gear transition. A loud clunking sound is made during this maneuver. On occasion, depending on the sequence, the sound is even louder than the posted video.
    https://youtu.be/uwnZMSPtB1E
  2. Sep 11, 2023 at 3:13 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    What you're hearing is the rotational force being applied to the drive shaft, and it rapidly using that 1/4 turn of play. 1/4 of a turn is a lot. To properly check u joints you gotta pull the drive shaft out. But there is a good chance something is outta spec within the 3rd member / diff if you've got that much play.
    1997tacomav6 and wilcam47 like this.
  3. Sep 12, 2023 at 4:49 AM
    dmk679
    Orlando, Florida
    Thank you for weighing in. I will pull the driveshaft and check all the u joints.
  4. Oct 1, 2023 at 7:33 AM
    dmk679
    Orlando, Florida
    Update: I greased the slip yoke and changed out the u joints. No change in the clunk noise from changing from Park to Drive. Thinking its the 3rd member unless someone else has some insight. Thanks.
    wilcam47 likes this.
  5. Oct 1, 2023 at 4:18 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Can u have a buddy shift while you’re under truck?
    To observe/hear klunk?
    my initial guess was carrier bearing but u stated was fine
  6. Oct 1, 2023 at 4:32 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Carrier bearing can appear fine.
    Need to get under there and grab onto the drive shaft with both hands and give it a good shake.
    Shouldn't be any play in it.
  7. Oct 1, 2023 at 4:33 PM
    dmk679
    Orlando, Florida
    Yeah, I ordered a carrier bearing earlier today. It's the last thing left so figured I'd replace it! Will let you know know if it does the trick.
    Madjik_Man and bkhlrTaco's like this.
  8. Oct 1, 2023 at 5:41 PM
    matches3215
    matches3215 Well-Known Member
    SACRAMENTO
    2001 Beige Tacoma PreRunner TRD OffRoad
    Watching this as I have the same issue. Keep us updated!
  9. Oct 1, 2023 at 5:51 PM
    Papaya
    Papaya Member
    My buddy's does this too. Please let us know if you find the cause. I hope it's a cheap fix!
  10. Oct 1, 2023 at 6:17 PM
    matches3215
    SACRAMENTO
    Same! I read in another thread somewhere that it was a 3rd member.
  11. Oct 1, 2023 at 6:24 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
  12. Oct 1, 2023 at 6:44 PM
    matches3215
    SACRAMENTO
  13. Oct 1, 2023 at 7:04 PM
    ControlCar
    Steven
    Sugar Land TX
    OP plz let us know!!!!
  14. Oct 5, 2023 at 11:46 AM
    dmk679
    Orlando, Florida
    The Spicer/Dana carrier bearing arrived this week and I have not installed it yet. I've been doing a ton of reading about the subject, probably too much reading, borderline obsessed with figuring this thing out. I like a good puzzle but this mystery is starting to get to me. Telling you'all something that you already know ... there are multiple root causes of the issue, such as u joints (by far the most common reason), too much rear backlash (how much is too much, nobody seems to know!), slip joint dry/noisy, carrier bearing, trans mount, motor mount(s), trans fluid low, issue where the trans meets together after the carrier bearing (there are splines where it is connected), loose u bolts holding leaf springs. I'm probably missing a few items, but as you can see there are a ton of variables involved. It's not a one size, fix all so what may work for one person may not work for another. I'm starting with the easier items first and progressing up the chain of potential fixes (from least $$ to most $$).
    I did some experimentation this week and if I put the truck in neutral for about 5s or so before changing to reverse or drive, it rarely clunks/pings/makes noise. I've tried this on multiple occasions and it holds true for me. I watch the driveshaft during this exercise and when it goes in neutral, the slack in the driveshaft appears to be removed which makes me believe the backlash in my 3rd member is causing this issue.
    I'm going to tear apart my driveshaft *again* this weekend and see if I can determine if anything else is impacting my situation. I dont mind getting my 3rd member rebuilt and/or buying a new driveshaft if I knew it would definitely fix my issue once and for all but at this point I'm not absolutely certain of the root cause.
  15. Oct 5, 2023 at 11:55 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Did you ever check for play in the d.s. at the carrier?
    I see you mentioned mounts.
    Carrier bearing, motor/tranny mounts and ujoints seem to be most common causes.
    Similar symptoms in my '01 Taco and it was the carrier.
    I had a '91 Honda Prelude a long time ago and it was a broken motor mount
  16. Oct 5, 2023 at 12:08 PM
    dmk679
    Orlando, Florida
    For my carrier bearing, it goes up/down a little bit (0.25" or less) and does not have any play horizontally. I truly believe my carrier is fine but I bought a new one b/c my current one appears original (135k) and I'm trying to rule things out. I also dont have any driveline vibes at 80+.
    I looked at my transmission mounts and motor mounts and they do not appear to be my issue. Also looked at them when the d/s noise is being made.
    I do plan on separating my driveshaft at the carrier bearing and inspecting the splines. Also, checking the amount of torque on the nut holding the d/s together.
    bkhlrTaco's likes this.
  17. Oct 5, 2023 at 8:16 PM
    02 quadcab
    02 quadcab Well-Known Member
    You sure it’s not normal slack being taken up?
  18. Oct 5, 2023 at 9:21 PM
    Madjik_Man
    Colorado Front Range
    Could axle wrap be added to the list of potential causes?
    Fuergrissa likes this.
  19. Oct 5, 2023 at 10:12 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
  20. Oct 6, 2023 at 12:05 AM
    dmk679
    Orlando, Florida
    I need to do a video. It is such a loud noise that something is not right. It's downright embarrassing!
