Driveshaft Center Support Bearing lifespan???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alderleet, Jan 22, 2015.
  1. Jan 22, 2015 at 3:46 PM
    Alderleet
    Alderleet [OP] Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    So, i have a quick question.
    Whats everyones average lifespan of their center support bearing?
    I've added 3" of lift with a OME kit, and I've shimmed the leafs, balanced the shaft, and replaced the u-joints and CSB a year ago.
    As of a couple months ago, the center support bearing started to have some elliptical wobble. It gradually got worse and worse. I'm at the point where i can see the lateral shake in the rear end at highway speeds (about 50-70mph)
    The u-joints are in great shape/lubed well, and I'd like to assume a OEM Toyota center support bearing would last longer than a year...
    Anyone else killing center support bearings quickly?
  2. Jan 22, 2015 at 3:50 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    86k with 2" lift and no issues once I added the ome carrier bearing drop.
  3. Jan 22, 2015 at 3:50 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Shit, just seen this is 1st gen, sorry
  4. Jan 22, 2015 at 5:33 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    I only have about 1.5-2" of lift in the rear, but I replaced my CSB about 6 years ago with a 35 dollar CSB from ebay (I wasn't concerned with OEM parts at the time) and it still is hanging in there. Not much play or vibrations and no squeaks. This leads me to believe an OEM CSB should last a while (depending on how you drive the truck and the angles the driveshaft sees).
  5. Jan 22, 2015 at 5:42 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    first off you need the same drop in the carrier bearing as your lift so if you lifted 3 1/2" then do a 3 1/2" drop on the carrier bearing or it will wear itself out from poor alignment.
    besides that your driving style and conditions you drive in (mud, swamps, dusty gravel, or sand) make a big difference in how long it lasts as well as the quality of the bearing you use. some cheap aftermarket brands don't last more then one or two years at the most so only usequality OEM bearings if you want itto last as long as the original one.
  6. Jan 22, 2015 at 6:22 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Stock factory one lasted 12.5 years and 160k miles on my 01
  7. Jan 22, 2015 at 6:32 PM
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    Not to call you out, but you don't drop the carrier bearing the same amount that you lifted the truck. Just try to get the two portions of the driveshaft in as straight of a line across the carrier bearing as possible.
    RogueTRD likes this.
  8. Jan 22, 2015 at 6:38 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    I replaced mine at 125k miles with 40k of those miles being lifted (OME Dakars). It didn't really need replacing but since I had the driveshaft out while doing the flywheel, I decided I'd do it as well. I used TGP for the replacement.
    The current one has been fine seeing only 10k miles thus far.
  9. Jan 22, 2015 at 8:22 PM
    mustangstephen
    mustangstephen raise hell, drink beer
    Stephen
    by da creek
    02 Tacoma TRD
    Homebrew bumpers and sliders, 5100s & Eibachs up front and mutt leaf pack out back, 285s & Wheelers type B, sway bar deleted. Wife's ride: 01 4Runner 4wd sport. Stock with exception of TRD taco coils, and shift kit.
    I don't remember when I replaced my csb. 5+ years 50-60k+ ago? Truck has had no less than a shackle lift out back and now has a solid 3-4" lift out back. No shims. No drop. No vibes. I think the current csb has seen better days but i don't see a reason to replace it yet.
  10. Jan 23, 2015 at 11:25 AM
    keakar
    karl
    louisiana
    yes this is in fact true, you are correct to point that out. the correct way to do it is to take measurements to calculate the correct amount of carrier drop you need to realign the drivetrain propery.
    I was just going by a basic rule of thumb that because of the angles involved it is very close to being correct angle if you use the same drop on the carrier as you use for the lift. its not perfect but it is usually in the ball park and close enough to avoid any vibration issues.
  11. Feb 3, 2015 at 1:42 PM
    devil1
    devil1 Well-Known Member
    Miami
    '13 SR5 4x4
    Pro comp alloys, trail digger m/ts, icon 2.5 remote resies all the way, OME Dakar leaf packs, OBA. Lots of LEDs
  12. Jun 11, 2015 at 1:05 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    Mines lasted 250k miles before I replaced it.
  13. Jun 11, 2015 at 1:14 PM
    keakar
    karl
    louisiana
    I will say when I changed mine on my old chevy with aftermarket brands, it would only last a year before needing to be replaced again.
    this is one of those items you want to only use oem dealer replacement parts for.
  14. Jun 11, 2015 at 5:43 PM
    04tacoma trd
    04tacoma trd Well-Known Member
    Holy crap, really? No one every mentioned that. I did a 4" lift years ago (Deaver leaf spring pack) and didn't touch the drive shaft. What do I need to look for? By the way, still have original center bearing. If you take the driveshaft and move it, it really moves the rubber around in the housing. Is that correct?
  15. Jun 11, 2015 at 6:51 PM
    keakar
    karl
    louisiana
    I was told it shouldn't have more then about 1/4" of movement in the rubber of the carrier bearing in any direction.
    not adjusting the carrier bearing after a lift will often cause vibration issues from the u-joints binding as it turns so its not a smooth rotation. this reduces u-joint lifespan but not necessarily will make them go bad. if you have low speed or high speed vibrations it from not lowering the carrier bearing. as pointed out its not exact drop to lift ratio but you should do the measurements to get your driveshaft back into alignment. it seams to be more of a problem when doing a spacer block lift then a leaf spring lift so that might be why you didn't notice any vibrations or maybe bigger tires masked it so you never noticed it.
  16. Jun 11, 2015 at 8:30 PM
    04tacoma trd
    I haven't noticed any vibrations.
  17. Jun 11, 2015 at 9:14 PM
    keakar
    karl
    louisiana
    most likely just using the leafs for the lift may have kept your drivetrain angles the same?
    still wouldn't be a bad idea to take a few measurements to make sure its within specs
    Ryans4×4 likes this.
  18. Jun 12, 2015 at 8:14 AM
    04tacoma trd
  19. Jun 12, 2015 at 8:17 AM
    04tacoma trd
    I am not sure what to measure..... I did take a long straight-edge (level) and the driveshaft definately has a pronounced "bend" at the center support. I guess I can get on McMaster and order two spacers to go under the center bearing support bracket bolts to lower the bearing (1"?).
  20. Jun 12, 2015 at 8:35 AM
    keakar
    karl
    louisiana
    I wouldn't just start moving it yet until you know by how much it needs to be moved, or maybe your close enough that its ok as-is
