Driveshaft bolt source
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skigan, Oct 7, 2021.
  1. Oct 7, 2021 at 9:53 AM
    skigan
    skigan [OP] Well-Known Member
    Utah
    2009 Timberland Mica SR5
    Anyone find another source for driveshaft bolts besides the stealership? Looking for the bolts/nuts/washers for both the front driveshaft as well as the rear. After meticulously digging through the Toyota parts website for all the part numbers, I'd be looking at around $60 for everything which I thought was pretty steep for a handful of fasteners. I also looked at fastener suppliers but from what I understand the the nuts/bolts are M11 x 1.0 which is a weird size to find. Thoughts?
  2. Oct 7, 2021 at 12:16 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Get them from the dealer or Merlin crawler has them a little cheaper. These are special sized shoulder bolts, with high grade and fine thread count due to torque. You can get by with a metric 12.9 for a while but I’d stick with the oem.
    TnShooter, Jimmyh and skigan[OP] like this.
  3. Oct 7, 2021 at 1:31 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'd just play it safe and go OEM. You don't want a driveshaft coming apart at speed
    Biscuits, vtown and skigan[OP] like this.
  4. Oct 7, 2021 at 1:39 PM
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
  5. Oct 7, 2021 at 3:29 PM
    VoodooBlueATL
    VoodooBlueATL Well-Known Member
    2007 FJ Cruiser
  6. Oct 7, 2021 at 4:00 PM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    ARP might be able to help if you've got the size you need.
