Drivers door wont open
Discussion in '2nd Gen. Tacomas (2005-2015)' started by utdavist, Aug 1, 2017.
  1. Aug 1, 2017 at 8:46 PM
    utdavist
    utdavist [OP] Member
    Went to get in my 06 tacoma pre-runner (w/ power locks) but the door wont open from the inside or the outside. The key will only turn one way. I got the window down but everything runs into the door lock actuator. Any ideas on how to get the door panel off or open the door so I can replace the actuator?
  2. Aug 1, 2017 at 8:51 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Slim Jim it
  3. Aug 1, 2017 at 9:07 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    This is the third thread in the last few days about trouble getting the door open... What's going on? :help:
  4. Aug 1, 2017 at 9:44 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Sounds like the little plastic clips that hold the connecting rod from the handle to the latch have broke. Being it is 11 years old they will fatigue. A slim jim is about the only way to get it open if your good with one :jerkoff: once open it's a fairly easy repair. Good luck o.p.
  5. Aug 2, 2017 at 11:50 AM
    utdavist
    I rolled the window down and was able to get the top part of the door panel off. From the looks of it the actuator is bad. Unfortunately i cant get the actuator out if the door isn't open.
  6. Aug 2, 2017 at 5:31 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  7. Aug 2, 2017 at 6:21 PM
    utdavist
    All right here is the conclusion. I decided that it wasn't the motor because I could still here is engaging. So I ended up spraying a bunch of WD40 down where the lock and door handle cables connect to the actuator and it started working. After getting the actuator out I realized that some of the levers didn't have full range of motion so I took the actuator apart (which is a pain in the ass and requires patience). One of the springs had broken off and moved some components. I have no idea how the WD40 affected the components but it worked. Went to the Toyota scrap yard and paid 65 for a used one. THE END
    desertrunner24 likes this.
  8. Aug 2, 2017 at 8:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    WD40 works like VooDoo and killing a chicken or a goat... Magic.
    Do not question the WD40.
    Sugar Silva likes this.
  9. Aug 2, 2017 at 9:02 PM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    If you could pop the outer window molding trim off. It's easy access to push the plunger door lock actuator down. The trim is clipped it. I would try pry between rubber and door skin with and use a plastic pry tool
