Driver side kick panel fastener orientation?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PistolPete412, Nov 29, 2020.
  1. Dec 30, 2020 at 6:11 PM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    I was close to doing that, that’s why I quit while ahead!
  2. Dec 31, 2020 at 8:44 AM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    I think you can get rid of the discoloration with careful use of a heat gun. Heat it slowly until the discoloration goes away. Be careful not to overheat and melt it.
  3. Oct 21, 2021 at 4:53 PM
    Joe_4x4
    Joe_4x4 Member
    16 Black TRD Sport MT
    Hey, that panel is an absolute B****!
    I took all the plastic panels inside the truck out to soundproof/change the speakers/install a sub and change the 3rd brake light.
    Everything went back in it's location smoothly but those 2 kick panels.
    I kept them off for a while waiting for new clips to hopefully fix my issue, got the clips but now I realize I lost the stupid plastic nut that locks it in place (see picture).
    Anyone has an idea what the part number is? Looked through Toyota diagrams for hours and literally cannot find it.
    Any help appreciated, if I have to go to the dealer it almost means a day off for me since they're never opened!
    Thanks,
  4. Oct 21, 2021 at 5:14 PM
    cop414
    Tim
    Central PA
    Here’s the part # and a hint to reinstall. I was trying to slide the panel from the back forward, that seems logical. I spent hours trying to get it on. Put it directly across from where you want it to go and push it straight into the opposite panel, don’t try to slide it in. It will orient itself. 746024C7-605A-4791-BDE0-785B31E86EA4.jpg
    Nadams1977 and Joe_4x4 like this.
  5. Oct 21, 2021 at 5:23 PM
    Joe_4x4
    Joe_4x4 Member
    Thanks a ton! Right on :)
  6. Oct 21, 2021 at 5:57 PM
    cop414
    Tim
    Central PA
  7. Feb 4, 2022 at 1:13 PM
    jobo2718
    jobo2718 Member
    Boston Mtns Arkansas
    2021 Tacoma TRD OR DCSB
    I'm glad I found this thread. I had to remove the driver's side kick panel to install a Redarc brake controller, and the usual instructions of "pull it straight back" wasn't working. I finally worked it loose. I thought the clips had been bent by the extraction. The pictures here show that they're supposed to look like that!
    My contribution here is that I can confirm the panel stays in place and doesn't rattle (much) without those clips, just the sill plate and the plastic nut holding it. ‍
  8. Nov 15, 2022 at 12:16 PM
    Milt0311
    Milt0311 New Member
    2022 Celestial Silver Metallic Toyota Tacoma Limited
    Prinsu Roof Rack, Bug Deflector, Window Visor, S&B Cold Air Intake, Pop and Lock Power Tailgate
    Sorry english is my second language. Angle forward as in the pointy side forward? Or facing towards the rear?
  9. Nov 15, 2022 at 12:22 PM
    cop414
    Tim
    Central PA
    Yes, pointy end facing forward.
    Milt0311 likes this.
  10. Nov 15, 2022 at 12:24 PM
    Milt0311
    Milt0311 New Member
    Both clips pointing forward thanks man
    Dawalker1966 and cop414[QUOTED] like this.
