Driver side cubby in bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SLeeper512, Aug 5, 2021.
  1. Aug 5, 2021 at 3:08 PM
    SLeeper512
    SLeeper512 [OP] Well-Known Member
    Sam
    2021 SR5 DCLB Tacoma white with red topper with tow pkg
    My 2015 had a cubby/storage area on both driver and passenger side at back of the bed.
    My 2021 only has on passenger side.
    I looked and don't see anything that would interfere with putting one in on driver's side.
    It will be somewhat of a redneck modification.... I will cut the hole in the side and mount some brackets...
    My question.
    After cutting through the bed side wall material do you have to "seal" it? To keep from cracking at edges.
    I know if you drill through glass (special bits) it is best to hit with a torch to seal micro cracks. Wondering if I should do the same with the bed material.
    Thanks
    tacotoe likes this.
  2. Aug 5, 2021 at 3:10 PM
    Tacospike
    Two Trucks
    I don't think it would be needed for a composite bed?
    tacotoe, Skydvrr and SLeeper512[OP] like this.
  3. Aug 5, 2021 at 3:17 PM
    MIDTNTACO
    MIDTNTACO Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
    robmotive (youTube) just did a video of this exact thing. Personally, for the amount of space you gain, it's not worth the effort and worry to me. Check his video out. It looks OEM after he finished.
    tacotoe, JJ Diablo, 316sherm and 2 others like this.
  4. Aug 5, 2021 at 4:12 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    You don't have to seal the cut. A lot of members have put one in, you can get an OEM on e bay. It's a good idea if you're putting one of the compressors that will fit in there, but for storage it'll barely hold jumper cables.
  5. Aug 5, 2021 at 4:19 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I would just make sure to keep the corners you cut, rounded. The sharp corners will be stress risers.
  6. Aug 5, 2021 at 5:13 PM
    SLeeper512
    Sam
    I want to use it for my small viair compressor.
    I live in an RV and my truck bed is very packed...
    I just put ride rite air bags on to combat the big sag when trailer is on. Also, I prefer to air down for some forest roads... so want to keep it handy.
    tacotoe and Grossomotto[QUOTED] like this.
  7. Aug 5, 2021 at 5:18 PM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Drill the corners and then cut straight lines.
  8. Aug 5, 2021 at 5:25 PM
    316sherm
    316sherm Well-Known Member
    South Louisiana
    2020 Tacoma SR TSS Package 4 Cyl
    Those cubbies have holes and are exposed to the elements. I also own a Viair compressor, and I keep it inside behind the back seats. I personally wouldn't want a quality compressor constantly exposed to the elements. I agree with @MIDTNTACO as far as it not being worth the trouble.
    SLeeper512[OP] and gudujarlson like this.
  9. Aug 5, 2021 at 5:25 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yep.
  10. Aug 5, 2021 at 5:28 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Barsoom and MIDTNTACO like this.
  11. Aug 5, 2021 at 5:33 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2012 SR5 4x4 ACab with Old Man Package, MT, 2.7L, Spruce Mica
    Camper Shell w/roof rack, Bed stiffeners, Step Bars
    somewhere on here I saw a metal one that was lockable, think one of the aftermarket fab companies makes it.
    Barsoom likes this.
  12. Aug 5, 2021 at 5:34 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Ya everything I ever put in there turned into a rusty dirty mess. I use it as a garbage can now. It was not designed for Minnesota winters.
    Barsoom, 9th and 316sherm[QUOTED] like this.
  13. Aug 5, 2021 at 6:55 PM
    MIDTNTACO
    Middle Tennessee
    I've also seen advise to cut rounded corners to avoid potential future cracks. Although if the corners are holes.. well there ya go! lol
  14. Aug 5, 2021 at 7:03 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Yup. RobMotive on YouTube has a long winded but decent video showing the cubby install as well as part #s for hardware. Looks factory after its done. Myself Im going to use rivnuts like factory instead of the way he did it, but his way works too..
    Again, the dude loves to talk…
    https://youtu.be/hoeyiCq_x1I
  15. Aug 6, 2021 at 4:35 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    If I could give up one of my cubbies...
    Sometimes I open one up. Just to have a look
    JJ Diablo likes this.
  16. Aug 7, 2021 at 5:49 PM
    Alexbar10
    Alexbar10 Well-Known Member
    Alex
    2020 black tacoma TRD PRO MT
  17. Aug 7, 2021 at 6:07 PM
    taco1954
    taco1954 Member
    Nice mod work. I usually don't store anything there due to water/rust/mold.
  18. Aug 7, 2021 at 7:22 PM
    Barsoom
    NW GA OTP
    That's what I do when I build stuff of the farm. Drill with a 1/2" bit, then use a jigsaw to cut the straight lines. Use a reverse cut blade, that cuts on the down stroke, so that the rough edge is between the truck walls.
