Driver door won't lock/unlock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by adambs928, Jul 10, 2020.
  1. Jul 10, 2020 at 9:30 PM
    adambs928
    adambs928 [OP] New Member
    Adam
    2016 Red Tacoma TRD Off-Road
    I own a 2016 Tacoma TRD Off-Road 4 door. Recently I have had an issue where I cannot lock or unlock my driver door using either the key fob OR keyless entry. All other doors unlock except my driver door. Additionally my truck beeps 5 times consecutively when attempting to unlock the doors. I also noticed that when I put my truck into drive, the same issue occurs where all doors automatically lock except my driver door. Doing some brief research I have concluded that this might either be an issue with a fuse or more likely, the door lock actuator has gone bad. Has anybody else experienced this issue with a 3rd gen and how did you fix the problem.
  2. Jul 11, 2020 at 9:54 PM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    Wow this same problem just happened to me yesterday, driver door. Taking it in on Monday
  3. Jul 12, 2020 at 3:26 AM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    Let us know . It’s probably the latch .
  4. Jul 12, 2020 at 9:21 AM
    Garrett75x
    Torrance
    Op do you not get the locking beep as well? I get the 2 beeps for unlock but when I press lock no beep
  5. Jul 13, 2020 at 5:33 PM
    Garrett75x
    Torrance
    Just got back from the dealership, They wanted $140 to diagnose the electrical.
    They found a bad door lock actuator. No surprise there.
    They want $660 parts and labor and they have to order the part.
    20,600 miles and 39 months I will just have to eat the cost.
    Not too happy about it but what can you do
  6. Aug 1, 2021 at 8:40 PM
    Tegar23
    Tegar23 Member
    Rincon,GA
    2016 TRD sport
    I have a 2016 TRD sport and having the same issue…does anyone think this can be resolved at a regular shop instead of the dealership? I guess i can just unlock drivers door with the hidden key thing inside fob but seems like a pain long term
  7. Aug 1, 2021 at 8:43 PM
    Garrett75x
    Torrance
    I told my stereo/tint guy and he told me he could get an aftermarket one installed for under 200
    Try some independent shops first or be prepared to fork out the $$$ at the dealer
    Tegar23[QUOTED] likes this.
  8. Aug 1, 2021 at 8:59 PM
    Tegar23
    Tegar23 Member
    Rincon,GA
    2016 TRD sport
    Can’t hurt to ask! Thanks
  9. Aug 1, 2021 at 10:19 PM
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    I had this exact issue with my old 2016 4Runner. It is a common problem on lots of Toyotas. There is a little motor inside the door latch that had failed and needed to be replaced. Try manually locking one door at a time and then pressing the button. For example, I would manually lock the passenger front door and then hit the button on my fob and it would work. If I didn't manually lock that door first, the fob wouldn’t work and I wouldn’t hear a beep. Do one door at a time and if the fob works as normal, that is your failed latch. The latch as a whole is expensive, but the little motor inside is usually less than $10 bucks on Amazon or eBay. There are YouTube videos how to open the latch and replace the motor (this is the one I followed for opening the actuator)
    https://m.youtube.com/watch?v=AbRTg7L5nsE The motor in my 4Runner (same in almost every Toyota) was listed on Amazon as:
    10mm Flat Shaft Central Door Lock Actuator Motor FC-280PC-22125 FLAT SHAFT, D Spindle, Power Locking Repair Engine
    Bastek, Bleep100, Skydvrr and 2 others like this.
  10. Aug 2, 2021 at 6:11 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    I've placed a few power window motors in my time but never a lock actuator. I can't imaging it being any harder. Removing the door trim was always the most confusing.
  11. Aug 2, 2021 at 6:14 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Why not purchase the part yourself and have someone put it in if you can't do it yourself?
  12. Aug 2, 2021 at 6:18 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Depending on the door, lock actuators can suck. Usually inline with the strike plate on the door. One on my moms CTS sucked.
  13. Aug 2, 2021 at 11:59 AM
    Absolut_Boost
    Cincinnati, OH
    Toyota latch actuators are pretty painless once you get the panel off. The latch actuator itself doesn’t have to be adjusted at all, it’s a straight bolt in part.
    crackils and Tegar23 like this.
  14. Jul 18, 2022 at 8:23 AM
    Fabman500
    Fabman500 Member
    Michael
    2017 White SR5
    Driver door lock problem, Just spent $380.00 for new latch.. wasn't the problem, fuses under dash are good, checked wiring. I'm lost on idea's, hate to take to shop. door latch was easy to do, if you are thinking about it. Any idea where to look would be helpful.
    thanks
  15. Jul 18, 2022 at 8:31 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    What’re your symptoms?
  16. Jul 18, 2022 at 10:10 AM
    Fabman500
    Fabman500 Member
    Michael
    2017 White SR5
    remote will lock and unlock all the door but driver, only using the key will lock or unlock door
  17. Jul 18, 2022 at 10:12 AM
    batt700
    batt700 Well-Known Member
    2017 SR5 Premium 4Runner
    it's usually the actuator 99% of the time. Had the same issue in my first gen Tacoma as well as my RSX-S and I just went down to the local junkyard both times and pulled actuators for like $10
  18. Jul 18, 2022 at 10:18 AM
    batt700
    It's your actuator in the driver door.
  19. Jul 18, 2022 at 10:33 AM
    Fabman500
    Fabman500 Member
    Michael
    2017 White SR5
    changed it
    Skydvrr likes this.
  20. Jul 18, 2022 at 2:33 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Unfortunately, new doesn't always mean good.
    Aside from that, here is the wiring diagram for the locks.
