driveline lash/slop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rotax29, Jun 28, 2013.
  1. Jun 28, 2013 at 9:47 AM
    Rotax29
    Rotax29 [OP] New Member
    Mario
    Calgary
    06 off road TRD
    trd intake, trd exhaust
    New to forum. I have an 06 TRD Off Road. The truck has had a driveline lash noticeable when starting off from a complete stop and when coming to a stop. The issue is becomes more noticeable after towing. Any Ideas what causes this?
  2. Jun 28, 2013 at 9:50 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    How many miles? Bad carrier bearing? Bad U-Joints?
  3. Jun 28, 2013 at 1:26 PM
    Rotax29
    Mario
    Calgary
    06 off road TRD
    I bought the truck new in 06 and it has only has 84000km/52000 miles. Is the rear pinion a common problem? it recently started making a small grinding sound like a bearing in the rear of the truck is about to go. If it is the pinion would it be an easy fix? This truck has the locking rear differential, so i am worried that it may be an expensive fix.
  4. Jun 28, 2013 at 1:31 PM
    Aryota
    Aryota Rabbit n Pancakes vs. Chicken n Waffles
    Dave
    Central Arkansas
    09 Access V6 4x4 TRD-OR SR5
  5. Jun 28, 2013 at 1:40 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    greasing the zerks might help... just a thought
  6. Jun 28, 2013 at 2:43 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Grease the slip yoke, you have to pull it apart to do so.
    That is all.
