Drive shaft is falling off, please advise!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeebz, Feb 5, 2016.
  1. Feb 5, 2016 at 7:57 AM
    Jeebz
    Jeebz [OP] AKA Dirty Birdy
    Jon
    Chino Hills
    08 fully caged LT DC
    AFE CAI w/ K&N Filter Black Widow 2.5 dumped Camburg UCA & LCA Camburg Spindles Camburg Clevis & Inner rods Buckshot Racing Shock Hoops 2.5 Race 10" Fox Coil Over 2.5 Race 10" Fox Double Bypasses 2.0 Race Series Fox Bump-Stops Total Chaos Coil Bucket Tower BuckShot Racing Stealth Bed-cage H70 Deaver Leaf Pack Richer Racing 2nd Gen Shackles 2.5 Race Fox Double Bypasses 2.0 Race Fox Bump-Stops 17' SCS SR8's General Grabbers 35s BuckShot Racing Front Bumper Glassworks Unlimited Fenders 20" SDS Offroad Hyperion LED bar MCM Fab Roll Cage Moroso Roll Cage Padding Longacre 14" mirror Blue Leather Recaro Racing Seats Boxed frame from cab-back. FOUR PCI Headsets Full PCI Race Radio & Intercom PCI Antenne
    Lol so like the title says, my driveshaft is about to fall off. Yesterday I went to Lexus to pick up parts for a customer's vehicle and noticed a really bad shutter, which prompted me to pull over. After a under belly inspection, I noticed that my drive line is splitting in half and pulling out of the transmission. On the way back to the shop I had to stop every 2 blocks just to kick the driveshaft back in to the trans. I know my carrier bearing is shot and about $100-$150 but my question is about the connection between the trans and drive line. What holds the driveshaft to the tranny?
    All comments welcomed lol
  2. Feb 5, 2016 at 8:01 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    Sorry man, I wished I could help. I have not had this problem yet. My 2015 is still new at the moment. Good luck finding a fix! I'm sure someone else on here has run into the same problem.
    Jeebz[OP] likes this.
  3. Feb 5, 2016 at 8:04 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
  4. Feb 5, 2016 at 8:13 AM
    Nor7
    Nor7 Well-Known Member
    Eric
    Texas
    2011 Tundra, Texas Edition
    I'm not an expert either but I do have access to all Chilton repair manuals. Hopefully this helps.
  5. Feb 5, 2016 at 8:21 AM
    Jeebz
    Jon
    Chino Hills
    Okay great so nothing is broken on that end. I am LT in the rear and figured the same thing that I'm still using the stock driveline. I'm towing my taco to Reel Driveline to help me build a rebuild and mod my drive shaft next. Just needed some input from TW. Thanks for answering my question and hope this will solve my problem.
  6. Feb 5, 2016 at 8:34 AM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    Hey Bro sick color on ur truck.
    I can't believe u have broke 2 rear ends.
    Anyway I'm not a second gen expert but it looks like it just a slip spline into the tranny there. Aka if u take the back of the drive line apart you just pull straight back out of the tranny.
    I would say the rubber bushing in the tranny is just a vibration damper.
    If your taking it to a legit driveline shop that is experienced I wouldn't worry to much.
    But I wouldn't drive it don't want the carrier to start eating the cross member or other unforseen.
  7. Feb 9, 2016 at 6:52 PM
    Jeebz
    Jon
    Chino Hills
    Problem solved. The carrier bearing was about to fall apart. Replacing all 3 u joints, carrier bearing and getting a driveline balance
  8. Feb 9, 2016 at 8:39 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  9. Feb 9, 2016 at 8:52 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You absolutely need a slip yoke
    Rock Lobster likes this.
  10. Feb 10, 2016 at 6:51 AM
    Jeebz
    Jon
    Chino Hills
    The balancing was included in the service so I'm not sure. Apparently there was a weight missing in mine. What I do know is that the driveline has to be taken out to be balanced
    I do have one, that was the first thing that was mentioned to me when I brought it in. I told him I needed a slip yoke and he said I already had one lol.
  11. Feb 10, 2016 at 6:55 AM
    anthony250f
    Anthony
    San Diego, CA
    You need a slip yoke at the rear axle...do you have one right at the rear axle ?
    If not that's what you need
  12. Feb 10, 2016 at 6:56 AM
    anthony250f
    Anthony
    San Diego, CA
    Needs to look like this...otherwise your d shaft is pulling on the CB then pulling out of the tranny
    MrDibblesTaco and Jeebz[OP] like this.
  13. Feb 10, 2016 at 7:07 AM
    Jeebz
    Jon
    Chino Hills
    I have one but it's not at the end like that the slip I have makes my driveshaft look like a 3 piece. I'm glad you chimed in. Here are the only pics I took yesterday of the driveline. My driveshaft extends and compresses in the middle not on the end like yours. I was told that my driveshaft wasn't factory and has been modded with a slip yoke. See anything I don't?
  14. Feb 10, 2016 at 12:50 PM
    anthony250f
    Anthony
    San Diego, CA
    Exactly what he said ^
    You NEED a slip yoke at the end...the axle is pushing and pulling the carrier bearing too much with the long travel rear.
    I couldn't even drive a day without adding a rear slip yoke like that. Idk how It lasted this long lol
  15. Feb 10, 2016 at 12:51 PM
    anthony250f
    Anthony
    San Diego, CA
    It's hard to see actually. Is there a slip yoke before the carrier bearing ??b
  16. Feb 10, 2016 at 8:00 PM
    Jeebz
    Jon
    Chino Hills
    I don't have one by the trans and it's just a solid driveshaft I have one on the front of the rear shaft and that's it. From what JE Reel said, my driveshaft isn't factory and set up for a LT rear end. As far as if it's the right one, he doesn't want to comment. I measured from the center carrier bearing to the face of the driveshaft mount on the third member and got 47" sitting on the ground. 46" at full droop. The driveshaft matches up with a little of extra play so being short doesn't seem to be the issue. I explained how I needed/wanted to add a slip yoke at the rear but he replied that I already have one, two on one driveshaft would be redundant, would fall apart and laughed. he offered to put the slip yoke on the other side for an added fee but declined
    Yes there is, if you are talking about the driveshaft starting from the third member. Mine looks just like yours but backwards Lol
  17. Feb 10, 2016 at 8:05 PM
    anthony250f
    Anthony
    San Diego, CA
    You should be fine line...likely just the carrier bearing
  18. Feb 11, 2016 at 7:10 AM
    Jeebz
    Jon
    Chino Hills
