Drive line vibration caused by too much positive caster?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco2525, Dec 18, 2017.
  1. Dec 18, 2017 at 8:42 AM
    Taco2525
    Taco2525 [OP] Well-Known Member
    Los Angeles
    2009 access cab trd-offroad 4x4
    Do you think it’s possible a high speed drive line vibration is caused by too much positive caster?
  2. Dec 18, 2017 at 8:45 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Sounds more like your tires are not balanced correctly.
  3. Dec 18, 2017 at 8:46 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Ugh I highly doubt moving the wheel up in the wheel well would cause that. @nd4spdbh
  4. Dec 18, 2017 at 8:46 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    When you say drive line vibration I assume your talking about the driveshaft. Alignment numbers have nothing to do with a driveshaft vibration
  5. Dec 18, 2017 at 9:35 AM
    Taco2525
    Los Angeles
    Wheels tires hub and wheel berring are technically considered driveline so I figured I’d ask before I rule to much caster causing something out
  6. Dec 18, 2017 at 11:04 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    agreed. About the only thing it could cause is the needle bearing vibe if anything and that would go away in 4wd
  7. Dec 18, 2017 at 11:18 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
  8. Dec 18, 2017 at 12:40 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    The higher the caster (more pos.) more stability at higher speeds the lower more neg the less. What you can induce with high caster is low speed driving feeling kind of sluggish or weird. To low of caster at highway speeds can feel like the vehicle is unstable or very twitchy. The only way an alignment would cause a vibration would be from toe being ridiculously out of spec and it would want to try and steer the vehicle or act like the Jeeps infamous death wobble.
  9. Dec 18, 2017 at 3:02 PM
    Taco2525
    Los Angeles
    My vibe is at 65 plus tho
  10. Dec 18, 2017 at 3:02 PM
    Taco2525
    Los Angeles
  11. Dec 18, 2017 at 8:58 PM
    Taco'09
    Taco'09 Well-Known Member
    Op, how much caster are you taking about? Actually additional caster can help improve stability as noted above but there is a threshold where too much is too much and apparently the front wheels will start to shimmy. I do not know what that threshold is and it is going to be different on every vehicle.
  12. Dec 18, 2017 at 9:10 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Wheel bearings?
    My prerunner would growl and have vibes through the floor at about 60mph and higher. Never had play in the wheels so multiple shops swore it wasn't my bearings but I replaced them anyway and that fixed it.
    Also, I have had steering wheel shakes/vibes caused by bad alignment. I think it was a combination of toe and caster. Didn't take much of an adjustment to resolve it.
  13. Dec 18, 2017 at 9:12 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yes an no to that threshold. The threshold goes either way too much you get low speed steer in and weird handling at low speeds too little and instability at higher speed which can be misinterpreted as a shimmy when in reality it is the vehicle not handling well and unstable. It will want to jerk quickly as you make small inputs into the steering at higher speeds. There are factory vehicles with over 10* of caster. approximately 2-4* is the sweet spot for a daily driven commuter car.
    BTW you can modify and make any vehicle handle the way you would like by making drastic alignment changes. His alignment #s are well within spec. I actually have mine set out more pos. and have no issues.
    Toe more than likely the culprit. But rarely if ever should an alignment cause or induce vibrations unless it is just totally botched.
  14. Dec 18, 2017 at 9:13 PM
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    Off topic but is that dove springs in your avatar?
  15. Dec 18, 2017 at 10:07 PM
    Taco2525
    Los Angeles
    I think It was set to around 3 degrees positive
  16. Dec 18, 2017 at 10:08 PM
    Taco2525
    Los Angeles
    Before that it was set at like 2.5+
  17. Dec 18, 2017 at 10:09 PM
    Taco2525
    Los Angeles
    That’s something I thought about I did the driver side wheel berring when I baught the truck cause it was making noise but no vib
  18. Dec 18, 2017 at 10:10 PM
    Taco2525
    Los Angeles
    Yea and my alignment was pretty much spot on everywhere else I have firestone lifetime alignment so I go like ever trip out to the dez and or every like every 2 months
    ovrlndkull[QUOTED] likes this.
  19. Dec 18, 2017 at 10:14 PM
    Taco2525
    Los Angeles
    Yea that is dove springs right by the dirt bike road jump was supposed to be there right now!!
    Sorry everyone for all the messages I just realized what the multiquote thing was for my bad!!!
    Thesandaddict[QUOTED] likes this.
  20. Dec 19, 2017 at 6:57 AM
    Taco'09
    Ya know Op I hate to be that guy but if this were mine I think I would take a hard look at the condition of the control arm bushings and ball joints (UCA and LCA, both sides) for play and for breaks between the honeycomb-like structure of the bushings.
    Also take a look to see that both outer tie rod ends have an equal amount of threads showing on both the L and R side between the jam nut against the TRE and along the tie rod. You can do this by taking a 3X5 card and placing it along the tie rod to just touch the jam nut and marking where the threads on the rod stop, then compare with the other side. A max of 1.5 threads difference between sides is spec. While you are there additionally try to determine if the is obvious slop in the inner tie rod on the other side. I'm curious if there is possibly very unequal lengths of tie rods side-to-side which could lead to bump steer.
    totmacher likes this.
