Drilling through the frame....need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Jun 21, 2017.
  1. Jun 21, 2017 at 2:00 PM
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'm attempting to install some sliders on my double cab. They are "bolt on" which means, after you drill forty 1/2" holes, you bolt them on. And that's my issue....drilling out those holes.
    I've tried two different kinds of drill bits intended for "hard steel" and my progress is painfully slow even when oiling the bits as I go. I'm pretty sure my drill will be at the end of its life after this (if it even makes it). It's so slow I'm having to cool off my drill with compressed air after a while before I can continue.
    Is there a secret to this?
    Mike likes Tacos likes this.
  2. Jun 21, 2017 at 2:08 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I would return them and buy SOS Bolt on sliders. They just bolt on.
  3. Jun 21, 2017 at 2:08 PM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Sharp drill bits, Vermont American makes great ones...If you have a compressor that can support it, pick up an air drill (self cooling).
    Plus, you will get more RPMs out of it.
  4. Jun 21, 2017 at 2:17 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Drill a smaller hole to start with and work your way bigger.
  5. Jun 21, 2017 at 2:18 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Also if you are actually using "oil", as in 3-in-1, motor or some other lubricating oil, then STOP--you are using the wrong stuff. Get some cutting fluid--Tapmatic #1 Gold is my favourite...
  6. Jun 21, 2017 at 2:20 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Thanks for the advice but I'm not willing to explore that option.
    Is faster RPM better? Is more pressure better or worse?I've been using the DeWalt bits that state they are for heavy steel. Brand new bits.
    I was trying to go from 1/4" to 1/2" but I think that was a bit too big of a jump. Using about 3 other sizes in between now and that's seem to made the most difference.
    I was using some old diff oil in the garage actually. What's different about cutting fluid?
  7. Jun 21, 2017 at 2:22 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    X2 - start with smaller pilot hole, then I would use a decent "step bit" - they cut really well! Even the step bits at Harbor Freight have served me very well...
    DriverSound and Sandman614 like this.
  8. Jun 21, 2017 at 2:22 PM
    Bebop
    Nick
    1/4 to a half is a hell of a jump. Your never gonna cut that. Get out a good complete set of Irwin bits and work your way from smallest to biggest and go to town.
  9. Jun 21, 2017 at 2:24 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Are you seriously drilling 40 holes in your frame? I would weld them on before drilling so many holes in my frame. Good luck.
    agunday21, T4RFTMFW, Hoonatic and 2 others like this.
  10. Jun 21, 2017 at 2:25 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    This, but I'm biased. There are other brands that bolt straight on as well. I'm not sure what brand you bought but I hope they're worth it.
    @ItalynStylion
    Slow speed with pressure. I just drilled 1/2" holes for my t-case skid plate. Put my Craftsman c2 19.2v drill on my floor jack and lightly applied pressure. Went through like pretty easy, used a few shots of wd-40. Drill bit was a standard gold colored one bought a few years ago from sears.
    SOS CONCEPTS likes this.
  11. Jun 21, 2017 at 2:32 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    How many Holes do you need to drill??
    A little planning would have been a big Help
    Since I did Quite a lot of frame Stretching A mag drill was not a luxury 1/2" annular cutter would go through that like butter
    I use it quite often repairing Tacoma frames I just clamp a 1/2" plate to the frame
  12. Jun 21, 2017 at 2:33 PM
    ItalynStylion
    Steven
    DFW, Tx.
    I guess it's actually 3 per attachment point. My mistake.
  13. Jun 21, 2017 at 2:33 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    The slower you can let your bit turn, the better. It will actually cut through the steel faster. Step bits are nice to use for this as well. Use lots of oil as it lubes and cools. Clean away the metal shavings as they can dull your bit.
  14. Jun 21, 2017 at 2:33 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Exactly. Drilling holes in frame = no bueno
  15. Jun 21, 2017 at 2:35 PM
    JoefromPTC
    Joe
    Doughnut Spaghetti likes this.
  16. Jun 21, 2017 at 2:35 PM
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    Do they use any existing holes? I put 3 bolts in my sliders then had a welder finish it off. Cost me 60 bucks. Save a little cause they were already mounted. I think drilling holes in the frame is too much work and not as good as welded.
    MotoEd likes this.
  17. Jun 21, 2017 at 2:36 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    That is a slight difference from 40
    Why pray tell is drilling holes in the frame bad ??
  18. Jun 21, 2017 at 2:36 PM
    Mully
    CA
    How many attachment points x 3 holes = ??
    15 minutes weld time. Done, never worry about.
    Don't drill 36 to 40 holes in your $36000.00 dollar truck.
  19. Jun 21, 2017 at 2:38 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Cutting oil like Tap Magic. Drill slow and constant pressure. Drill all holes with 1/8" or 3/16" bit and work your way up from there. Step up 1/16" or 1/8" each time. Constant cutting oil, keep the drill bit cool.
    Or, buy ours and never drill a hole.
  20. Jun 21, 2017 at 2:39 PM
    ItalynStylion
    Steven
    DFW, Tx.
    This has been my experience thus far too.
    No existing holes sadly. Really annoying.
    4 attachment points, 3 holes each, 2 sliders.....24 holes. Don't know what the fuck I was smoking before. Probably my drill bit lol.
    Gearheadesw likes this.
