Drilling into bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by udrunk2002, Jul 3, 2020.
  1. Jul 3, 2020 at 3:02 PM
    udrunk2002
    udrunk2002 [OP] Well-Known Member
    I'm making a DIY fridge/freezer slider. I need to screw or bolt it down in the bed. Any tips or advice on this? Obviously I'm going to try and use shallow screws or bolts and it'll be on the passenger side towards tailgate, so I should be good as far as gas tank.
  2. Jul 3, 2020 at 3:17 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Drill into it, you're fine. I've drilled several holes in mine. It'll shoot up a lot of dust.
    Junkhead likes this.
  3. Jul 3, 2020 at 3:36 PM
    udrunk2002
    yeah, i just gotta get under there and see how much clearance there is to get the nuts onto the bolts
    Boghog1 likes this.
  4. Jul 3, 2020 at 4:10 PM
    udrunk2002
    i'm mounting the slider onto L-brackets so the bracket should distribute the weight to the bed
    ...i'll post pics later
    Vbpiper likes this.
  5. Jul 3, 2020 at 6:01 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Bolt into the OEM fittings, there are enough of them and they are super strong. Nothing worse than a Swiss cheese bed, all you’ll do is piss off the next owner.
    Rock Lobster, Junkhead and SR-71A like this.
  6. Jul 3, 2020 at 7:05 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Getting ready to put a few in my bed to mount a Swing Case. As to the next owner, I really won't be in a position to care. You see before this the last vehicle I bought was my '82 Jeep Scrambler (new). So assuming this vehicle lasts as long and I'm in my late 60's, I'll be dead when it comes time for someone else to own it.
  7. Jul 3, 2020 at 7:15 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    Double check what’s under the bed. There’s been a few threads about drilling through filler necks haha.
  8. Jul 3, 2020 at 7:59 PM
    JEEPNIK
    Heck I know a guy that was burning through the deck plate of a Henderson class destroyer and cut into a fuel line. That was a fun fire.
    CaptainBart45 and shakerhood like this.
  9. Jul 3, 2020 at 8:51 PM
    joesrcool
    joesrcool Well-Known Member
    Joe
    2019 Tacoma TRD Off Road
    Shouldn't have any problems near the tailgate. I drilled 4 holes for my fridge slide then used some rivnuts and stainless steel hardware. There's a lot of empty space under the bed. I also cut some holes in my bed mat and sandwiched it between the fridge slide and the bed.
    AZ Pete, tacotoe, mello03 and 6 others like this.
  10. Nov 12, 2020 at 8:38 AM
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    Hey Joesrcool, I'm thinking about putting some rivnuts in the bedsides to attach some tie-downs (inside the bed). Did you see any sign of the composite material cracking or deforming after you put the rivnuts in? If you had to guess, how much load do you think a tie-down attached with two rivnuts could safely handle?
  11. Nov 12, 2020 at 8:49 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I would use jack nuts over rivet nuts. Rivet nuts work well in metal because they expand as well as creating a small flange. Jack nuts dont expand, but the create a huge flange. Expanding rivet nuts in a composite bed puts pressure on the hole and will cause it to crack.
    Here is a jack nut.
    Here are the different kinds of nuts in some plastic. You can see the far right side is a rivet nut and how it bows the material and can cause the hole to crack.
    Middle is a rubber one that works well. Left side is a jack nut, If you need more support, you can put a metal washer in the jack nut and it will create a even stronger mount.
    mquibble, AZ Pete, tacotoe and 8 others like this.
  12. Nov 12, 2020 at 8:54 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Put mine right on top of the bed mat too.
    tacotoe likes this.
  13. Nov 12, 2020 at 2:09 PM
    joesrcool
    Joe
    I used rivnuts for simplicity, as I thought I'd be taking the fridge slide out more often. The rivnuts allow me to unscrew the screw/bolt without having to worry about catching the nut on the other side. The bed floor was thicker than I thought, and I imagine the bedside would be the same. I've had the fridge mounted for months and it's seen several offroad trips and moderate wheeling. There are no signs of fatiguing and nothing has ever come loose. I have 4 holding the fridge slide in, and with a full fridge, it's maybe 70-80lbs of weight. I'm pretty confident I won't have any issues.
    tacotoe and TexasTacoLT[QUOTED] like this.
  14. Nov 12, 2020 at 2:10 PM
    joesrcool
    Joe
    Yeah, I could never live without my bed mat, and thought it was a good idea to sandwich it between the slide and the bed.
  15. Nov 12, 2020 at 2:23 PM
    5nahalf
    Erik
    Minnesota
    Use a drill bit limiter. Set it at 1/4 inch and you wont have any problems. Otherwise do like I did and use a step drill.
    Boghog1[QUOTED] likes this.
  16. Nov 12, 2020 at 5:05 PM
    TexasTacoLT
    Killeen, TX
    '14 TRD Offroad
    Yeah, those Jacknuts look like the way to go. I'd like to get some washers on the backside to reinforce, but it's a beeotch accessing the other side which is why I was thinking rivnuts might be simplest. I've got some pretty light duty tie downs on there now that I put on with nuts and bolts and I'd like to avoid having to do that again. I think I'll pickup some jacknuts. Thanks for the input.
  17. Nov 12, 2020 at 5:10 PM
    5nahalf
    Erik
    Minnesota
    The jack nuts without washers would still be better than the rivet nuts, Im actually ordering a bunch to replace all the bolts with nuts I used to put my o-tracks into my bed. Installing bolts with nuts was by far the worst idea I could of had while installing these rails, I had to duct tape a box wrench to the nut, then drive the bolt in with the drill holing the wrench didnt fall off..... so its time to remove them all and put in the jack nuts....
    tacotoe, jspb15, hfjeff and 2 others like this.
  18. Nov 12, 2020 at 5:12 PM
    TexasTacoLT
    Killeen, TX
    '14 TRD Offroad
    I was thinking rivnuts for simplicity too. If I were mounting to the floor, I'd probably do the same. I didn't know Jacknuts were a thing though. They seem less likely to pull out of the bedside than a rivnut would. Thanks for the input
  19. Nov 12, 2020 at 5:18 PM
    TexasTacoLT
    Killeen, TX
    '14 TRD Offroad
    I feel your pain man. I put 5 tiedowns on each side of my bed with nuts and bolts and 3 on the front side. Many foul words were said and many beers consumed putting those damned things on. Jacknuts will be so much easier.
    5nahalf[QUOTED] likes this.
  20. Nov 12, 2020 at 6:05 PM
    5nahalf
    Erik
    Minnesota
    Yeah, I finally grabbed a neighbor to finish the last few bolts. My tie downs take 8 bolts per big one, and 3 bolts for each small one. So I ended up doing 22 bolts with nuts... 19 of them I did by my self with the duct tape.
    TexasTacoLT[QUOTED] likes this.
