Drilled vs Slotted Rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevinztaco, Nov 30, 2016.
  1. Nov 30, 2016 at 12:09 AM
    Kevinztaco
    Kevinztaco [OP] Well-Known Member
    none yet
    I've done some reading and it is said that drilled rotors are more susceptible to cracking. Instead of ordering slotted rosters as I intended to do, I ordered drilled instead. They don't look like they were drilled through but I can't tell by looking at the pic. Anyone had any experience with these rotors and what kind of problem should I expect from them? BTW-My Tacoma is more of a Mall crawler through different seasons :) .
  2. Nov 30, 2016 at 12:46 AM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    I have slotted rotors and can't be happier. Hope this helps
  3. Nov 30, 2016 at 12:53 AM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    I hear drilled/ slotted rotors get mud packed in them pretty easily. Along with whatever else you may drive in
  4. Nov 30, 2016 at 6:48 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    The photo shows dimpled rotors. They are drilled but not all the way through. There is no reason for a mall crawler to have these and yes drilled is prone to cracking. Dimpled and slotted are not prone to this but again you dont need these. Use your money on mods that are useful.
    Kevinztaco[OP] likes this.
  5. Nov 30, 2016 at 9:38 AM
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    I've been wary of going with drilled rotors purely because I don't need them, but it's hard to find any recommendations on TW for a set of rotors that aren't drilled.
    The set I often see recommended are these https://www.amazon.com/Power-Stop-K137-Ceramic-One-Click/dp/B005FKS28C
    My truck is stock and used on road only, can anyone recommend rotor/pad combo?
  6. Nov 30, 2016 at 9:49 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    i'm going with maxx brakes, made in Canada and real good prices for us Canadians.
  7. Nov 30, 2016 at 9:54 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    The more surface area between the pad and rotor the better, why the heck would you want to decrease that? Drilled/slotted rotors are a huge waste of $$$. Remnants from a time 50+ years ago where brake pad technology sucked and the material needed to offgas.
  8. Nov 30, 2016 at 10:11 AM
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    Slotted rotors are great for aggressive driving and racing as they disperse heat better than solid rotors. For trucks, you want as much surface area as possible so solid rotors are the way to go.
    crashngiggles likes this.
  9. Nov 30, 2016 at 10:36 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Disc brakes work by changing kinetic energy to heat energy. The heat is then sucked up by the metal mass of the rotor, then the rotor is air cooled for use again. For the best brakes, you want the thickest, heaviest rotor available. Drilling, slotting, etc. removes metal mass from the rotor, increasing stopping distance by reducing pad/rotor surface contact area and reducing the rotor's ability to suck up the max amount of heat. Worst case, brakes won't work when they're too hot.
    TacomaMike37 likes this.
  10. Nov 30, 2016 at 2:03 PM
    raskal
    B.C.
    2013 DCLB TRD MGM
    their website is terrible. When I select my truck, they only show 5 lug as the option.
    That said, is there any benefit for choosing MaxBrakes over what my local autoparts store would sell me?
  11. Nov 30, 2016 at 2:33 PM
    hardground
    hardground Well-Known Member
    Massachusetts
    2011 TRD OR DC V6 Manual
    OME Lift, ImMrYo Mirror Bracket, BlendMount & Mirror Tap ,TRD Quickshifter, 4x4 Illuminated Switch, Red Line Hood Struts, Bak Roll-X
    Buy OEM and get over the idea that they will make a difference.
    They are rotors
    Crosis, 06Tacooo and Maticuno like this.
  12. Nov 30, 2016 at 4:11 PM
    qfast817
    qfast817 Well-Known Member
    Q
    Fort Worth Texas
    Tacoma
    I put drilled and slotted power stop rotors on mine and they stop like my stock ones.
    Went to the deer lease and drove though some Oklahoma clay and didn't have it build up in the slots. I've only had them on for about 1 1/2 months so far.
  13. Nov 30, 2016 at 4:15 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I prefer centrix slotted rotors for oversized tires. I can't remember who they are owned by. I guess it is personal pref but for 35s a heavier duty slotted rotor is great for me. I have never heard or seen any proof coming from drilled rotors.
  14. Nov 30, 2016 at 4:17 PM
    Northern Taco
    Not that you need them on a tacom
    Their website works fine for me. The difference in price from the lowest option to the premium set is less than $20 Canadian. I called and got a set of rear drums/shoes/spring kit for $168 Canadian which I thought was cheap.
  15. Nov 30, 2016 at 4:25 PM
    raskal
    B.C.
    2013 DCLB TRD MGM
    I've tried their "Search by vehicle" in Chrome and Firefox, but can't get it to state anything but 5 lug for my Tacoma. It also only has vehicles as new as 2013.
    /edit
    Found if I select 2011, Base Crew Cab it'll finally give me a 6 lug option. MaxBrakes only has OE set available for $67.85 USD pretty good price (might be due to the sale they are having until Dec 1)
  16. Nov 30, 2016 at 6:13 PM
    Northern Taco
    Search KT032981 on Amazon dot ca and it'll list an add for each model year 2005, 2006, 2007, .......2015 6 lug. It's 105.44 Canadian, the basic ones are $87. Just search 2005 Tacoma on max brakes website to get the kit number you want and they are a seller on Amazon for pretty much the same price after you convert to Canadian money from their website.
  17. Nov 30, 2016 at 7:02 PM
    Tatts521
    I drive 98% street so for me the slotted rotors work great
  18. Nov 30, 2016 at 7:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I can, Stock OEM Rotors and Pads.
    06Tacooo likes this.
  19. Nov 30, 2016 at 7:36 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I think you meant to say "Increase your stopping distance".
  20. Nov 30, 2016 at 7:37 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    How did you measure this?
