Drifting to the left when braking.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jul 24, 2023.
  1. Jul 24, 2023 at 11:57 AM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Just returned from my 1,000 mile road trip and couldn’t help but notice my truck veers to the left when pushing the brake pedal, does this on any kind of road. Not to mention the steering wheel is slightly off center. 2023 with 5,000 miles. So I just dropped it off at the dealer for the 5,000 mile service and mentioned this to them. See what they have to say about it hoping it’s just an alignment issue.
  2. Jul 24, 2023 at 12:03 PM
    Yoda_Mike
    Yoda_Mike YotaWerx Authorized Tuner
    Michael
    South Glens Falls, NY
    2019 Tacoma TRD Sport
    YotaWerx Blackhawk 2.0 tuned. Typer Auto tail light guards. Rough Country tri-fold tonneau cover. Start-X remote starter. Injen CAI. MBPR Armor Plus high clearance exhaust.
    Pulling when braking is not an alignment issue. That's a brake system issue. Could be a few different causes, but the most likely ones are hung caliper piston or a sticking brake pad.
    The crooked steering wheel IS an alignment issue, specifically a minor toe adjustment.
  3. Jul 24, 2023 at 12:04 PM
    Gfenza89
    Most likely so. Just hope they figure it out . Just trying to get out of the hiccup stage with this truck since the day I bought it.
  4. Jul 24, 2023 at 12:14 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    This is why I wait a couple yrs before buying a used. Let the 1st owner work all the bugs out. Lol
    I agree with @Yoda_Mike ....brake issue for the pulling.
    toe align for steering.
    Gfenza89[OP] likes this.
  5. Jul 24, 2023 at 12:14 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If it still pulls to the left after service, I would check the brake fluid and make sure your lines are bled properly.
    Gfenza89[QUOTED][OP] likes this.
  6. Jul 24, 2023 at 12:17 PM
    Gfenza89
    I’d like to hope they have the intelligence to check all that lol
    TA2016[QUOTED] likes this.
  7. Jul 24, 2023 at 12:19 PM
    Yoda_Mike
    Michael
    The challenge with brake pull in the early stages is often won't happen until they get very hot. It may be necessary to drive it yourself until you feel it happening and then bring it right to the dealership so a tech can drive it with you to feel the pull. Assuming that is they can't locate it already.
  8. Jul 24, 2023 at 12:33 PM
    Gfenza89
    guess we’ll see thank you
  9. Jul 24, 2023 at 12:56 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    I had this on my stock Goodyear tires … once I swapped tires and got alignment done problem went away .
  10. Jul 24, 2023 at 12:58 PM
    Gfenza89
    Good to know. And it was pulling only when braking?
  11. Jul 25, 2023 at 4:40 PM
    Gfenza89
    They did the alignment and never Checked the brakes. It’s still pulling, I looked over the calipers and brake hoses/lines I don’t see anything out of the ordinary . Guess I need to pull the wheels and check better
  12. Jul 25, 2023 at 5:11 PM
    Yoda_Mike
    Michael
    Drive it long enough to get it to pull. Then check for a temp variance between the 2 front wheels. If something is hanging up, one will be noticeably hotter than the other. Then you can return to the dealer and point this fact out.
  13. Jul 25, 2023 at 5:33 PM
    Gfenza89
    It pulls right away regardless of how long to drive it. So frustrating brand new truck.
  14. Jul 25, 2023 at 5:50 PM
    Yoda_Mike
    Michael
    In that case, as the service writer to have a tech go for a ride with you and show him. Sometimes that’s the best way to make your case. Sounds like it may have rolled on of the piston seals in a caliper.
  15. Jul 25, 2023 at 5:52 PM
    TA2016
    Oregon
    Do you notice a studded or vibration also when it is pulling to the left? You might want to check for a warped rotor.
  16. Jul 25, 2023 at 6:18 PM
    Gfenza89
    Thank you it’s just to noticeable for my taste it’s most noticeable the faster your driving I’m not accepting it
  17. Jul 25, 2023 at 6:19 PM
    Gfenza89
    No weird stutters or anything. The rear diff was replaced back in April they had to bleed the brakes now I’m wondering if that is the issue the more I think about it
  18. Jul 25, 2023 at 6:38 PM
    Mallcrawler20
    Yes when braking .. more on hard braking .
  19. Jul 25, 2023 at 6:51 PM
    Gfenza89
    So now I’m wondering if it could be the tires. Rotated them though and it’s still doing it
  20. Jul 25, 2023 at 7:18 PM
    nightstrike
    nightstrike Well-Known Member
    You’re hope is unfounded my friend.
