Download error message Entune App Suite
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TaCOdeRoja, Sep 3, 2021.
  1. Sep 3, 2021 at 9:02 PM
    TaCOdeRoja
    TaCOdeRoja [OP] Member
    2020 Red Tacoma TRD Off-Road
    Anyone know how to correct this issue on a 2020 OR? I dont even have Entune downloaded and use Android Autoplay. I have searched and cant find any answers. Thanks in advance for your help.
    AT6sOp496To4xsg4JdV-oAZ7VlmZ4K21sDdMz39p_b07a012712f6a555a26019662858055812ea8563.jpg
  2. Sep 5, 2021 at 11:18 AM
    TaCOdeRoja
    Is no one else on this board seeing this error? I guess Ill call the dealership after the holiday. Thanks to those that looked at my post.
  3. Sep 5, 2021 at 11:25 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Wish I could help you but they changed things up in 2020 and so I'm not sure what's different. Almost seems like Entune was updating and disconnected part way through. I can't speak from experience though. The dealership would be the easiest way to go, especially for a truck that's (presumably) under warranty.
  4. Sep 6, 2021 at 3:43 PM
    robe689
    robe689 Well-Known Member
    Bob
    SE Connecticut
    2020 Silver Tacoma SR5 Access Cab V6 4WD
    I have been getting this message for the past two weeks. The only way that I can update Entune is to select the option to delete all personal information. So I do that. Then Entune updates and says that it has updated. Yay!! I have to then reset my radio presets (no big deal) and re-connect my phone to the truck (again, no big deal).
    Then the next day I startup my truck and the same message shows up again. WTF? I've done this twice in the past week...so now I have given up and just press the OK button and go on my merry way...
  5. Sep 6, 2021 at 6:25 PM
    Truky!
    Truky! Well-Known Member
    Satellite Beach FL
    2021 TRD Offroad
    My 21 does that every now and then, seems to correct itself, never been a consistent problem, does it clear when you push "OK'?
  6. Sep 6, 2021 at 9:15 PM
    TaCOdeRoja
    Yes it does clear when I hit OK, it comes back next time I turn my truck on again. Not a big deal it is just annoying.
  7. Sep 6, 2021 at 9:21 PM
    TaCOdeRoja
    We shouldn't have to settle, there has to be a way to correct this. I'm hoping the dealership will have some answers. Ill post what I find out.
    MIDTNTACO likes this.
  8. Sep 7, 2021 at 4:17 PM
    robe689
    Bob
    SE Connecticut
    OK - so, I found this page:
    https://www.jackdromey.org/how-to-reset-toyota-entune/
    1. I turned off Bluetooth on my phone.
    2. I deleted the Toyota app from my phone.
    3. I deleted personal data from Entune.
    4. Entune updated (again).
    5. I turned Bluetooth back on on my phone.
    6. I paired the phone to my truck (again).
    7. I reset my radio presets (again).
    8. I reloaded the Toyota app on my phone from the Play Store (again).
    So far, so good. We'll see what happens tomorrow morning...:fingerscrossed:
    Steve Armstrong and RedWings44 like this.
  9. Sep 8, 2021 at 9:57 AM
    robe689
    Bob
    SE Connecticut
    I drove the truck around town several times today and the "Download error" message has not reappeared...I think that this problem may be solved (for now)...:woot:
  10. Sep 8, 2021 at 2:57 PM
    TaCOdeRoja
    I will give that a try thank you!!!!
  11. Sep 8, 2021 at 3:05 PM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    Exactly the same thing is happening to me. I reached out to toyota Corp and they basicly said to head to the dealer.
    When getting the error described, we recommend ensuring that your Toyota app is logged in and connected to the vehicle via Bluetooth. You may do this by following these steps:
    1. Ensure that your phone is paired to the vehicle via Bluetooth and not connected to the vehicle via USB cable
    2. Download the Toyota app and sign in to your account using your email or mobile number
    3. On the Toyota app, scroll to the 'Connect Your Accounts' section
    4. Click on 'Connect Now'
    5. Click on 'Connect'
    After following these steps, you should see a screen on your phone that says "Vehicle connected via Bluetooth". Check again to see if you are continuing to get this error message on the vehicle screen or if you are prompted to complete an Entune update download. If prompted for the download, click on 'Download Now' and then 'Install'.
    If you are continuing to get this error message after following these steps, we recommend contacting your local Toyota dealer for further troubleshooting and ensuring that all software in the vehicle is up to date.
  12. Sep 9, 2021 at 7:52 PM
    TaCOdeRoja
    I think the issue is resolved. I logged out of the Toyota app and deleted it. Reloaded it onto my phone and then connected with Bluetooth. Relogged back into the Toyota app and I haven't seen the error message since. Lets cross our fingers.
    Not even sure why the error occurred in the first place. The 2020 doesn't even utilize Entune for the entertainment system.
  13. Sep 10, 2021 at 5:49 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Now, I didn't follow ALL the steps listed above. But... When I un-installed the Toyota app from my phone (I wasn't near the truck at the time), then re-installed it. This morning I hopped in to drive to work and I didn't get an error message!
    Hopefully it stays fixed.:fingerscrossed:
    Update (as of 09/11/2021 @ 4:45pm) the issue has not happened again. I am 98% sure that the issue was with the Toyota app, not my radio, Entune, the phone or blue tooth.
    Uninstall & ReInstall for the win!
    TaCOdeRoja[OP] likes this.
  14. Sep 10, 2021 at 2:16 PM
    robe689
    Bob
    SE Connecticut
    ^^^ This...I am beginning to suspect that the problem was with an update to the Toyota app all along...
  15. Sep 11, 2021 at 11:43 AM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    I remember getting a notification on my phone to update the Toyota app, I clicked to update but the app is up to date message. Just Uninstalled it, and reinstalled, now it says it's up to date, and no message on the truck.
  16. Sep 11, 2021 at 12:16 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I'm getting this msg on the head unit of my 2021 Sport but it's infrequent and totally random. I click OK and it doesn't come back for weeks, then one day it will re-appear. Will have to try deleting and re-installing the app.
  17. Sep 11, 2021 at 2:42 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    That's exactly what mine was doing, then the message was consistent every time I started the truck
    FL_TRD Sport[QUOTED] likes this.
  18. Sep 11, 2021 at 3:38 PM
    Chaosh1
    2021 Tacoma TRD Pro
    Confirmed, Uninstall app and reinstall fixed the issue for me
    FL_TRD Sport likes this.
  19. Sep 12, 2021 at 4:34 AM
    robe689
    Bob
    SE Connecticut
    I checked my phone this morning and saw that the Toyota app had crashed twice in the past 2 weeks - on 8/31/21 and again on 9/7/21...still no recurrence since the app was deleted and reinstalled...
