Double cab front bench seat?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Deluxe247, Feb 5, 2020.
  1. Feb 5, 2020 at 9:28 AM
    Deluxe247
    Deluxe247 [OP] Member
    Rich
    2007 Silver Tacoma Double Cab SR5 TRD Off Road
    Standard tow package. Tailgate lock.
    I think this is an unusual question but here goes. I have a 2014 double cab. Has anyone ever swapped out the factory front bucket seats for some type of bench? Obviously you would lose the center console, but may gain another seatbelt.
  2. Feb 5, 2020 at 9:32 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Never seen it done but I’m sure it’s possible.
  3. Feb 5, 2020 at 11:05 AM
    DG92071
    DG92071 Well-Known Member
    I did that swap on a full size Chevy Blazer and I added 3rd row seating as well. It changed from a 4 full size passenger vehicle to a 7.
    I'm curious to know if the Tacoma bench seat could be swapped in too but my days of being a taxi service for my kids are over.
  4. Feb 5, 2020 at 11:11 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    As far as I know it is possible. I did the opposite in my regular cab so the bolts should line up correctly. Getting the seat airbags to work is another story, seeing as I haven't figured out how to make those work since the swap. Maybe you'll have more luck than me?
    If you are in need of a bench I know a guy trying to get rid of one in Montana :anonymous:
    Rjenkins. and DG92071 like this.
  5. Feb 5, 2020 at 11:19 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    x2 RC seat swap guy here - it's 100% possible.
    @ryfox0276 you need to solder in (x1) 2 OHM 1/4 watt resistor to each un-used airbag connection, swap the passenger seat sensor to the bucket, and secure the seat rail sensor to part of the seat metal. You'll probably have to grind down the male end of the seat belt to fit the bucket receiver, unless you swap it as well.
    Spent a few weekends troubleshooting my SRS and finally got it working as advertised.
    ryfox0276[QUOTED] and DG92071 like this.
  6. Feb 5, 2020 at 7:26 PM
    ryfox0276
    Montana
    2013 RC 4x4
    Thanks for the tip man. I already have the seat rail secured and the seat sensor in. And yeah had to grind the buckles just a little bit. I need to get those resistors on there I guess. The passenger seatbelt buckle light still flashes too, doesn't make a sound tho thank god.
    MY50cal[QUOTED] likes this.
  7. Mar 12, 2020 at 10:07 AM
    '14RC
    '14RC WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    Are you saying to use the resistor on the bench seat's wire harness airbag connections?
    This bypasses the bucket seats airbags then, correct?
    Also that magnetic sensor, if you attach it to metal (either taping it up with some steel or attaching to the rail), we're telling the truck to turn off the pax dash airbag so now we have no seat or dash airbag for the passenger? That's my understanding
