Dorman Wheel Bearing Hub Assembly Good?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Sep 17, 2021.
  1. Sep 17, 2021 at 10:27 AM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
  2. Sep 17, 2021 at 11:43 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Dorman, the Harbor Freight of auto parts. Need I say more?
    wi_taco, steelcity2, Key-Rei and 2 others like this.
  3. Sep 17, 2021 at 7:48 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    The doorman hub itself is fine, I’d stay away from their bearing. Maybe go to the store and see what kind of bearing they use? If it’s an NSK you’re probably good to go but if it’s a cheap off name I’d stick with an NSK.
  4. Sep 17, 2021 at 7:52 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I'd say it really depends on your needs.
    If this is a hard pounder heavy armored truck I would go with OEM only. (Or equivalent like NSK SKF etc.)
    If it's a light duty street only grocery getter you're probably fine with Doorman.
    They're not the best by a long shot but they might be enough for your needs.
    Rob MacRuger and burrito782 like this.
  5. Sep 17, 2021 at 7:53 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Dorman anything is usually trash.. just get a good Japanese bearing and a decent hub.
    steelcity2 and Rob MacRuger like this.
  6. Sep 17, 2021 at 7:54 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    ^This.
    Key-Rei[QUOTED] likes this.
  7. Sep 17, 2021 at 7:59 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'd check Amazon. I've got a pair of Detroit Axle going on 100k so far. They are similar in price.
    The warranty means nothing. No one is going to rebate your labor.
  8. Sep 17, 2021 at 7:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    With their track record on most parts I don't think I'd trust a wheel bearing from them, another brand to stay far away from is O'Reilly Master Pro that stuff is junk.
    eherlihy and po35042 like this.
  9. Sep 18, 2021 at 1:38 PM
    burrito782
    08 TRD Off Road
    The 1 year warranty you mention is Autozone's, not Dorman's. From what I understand under Dorman's warranty policy this would fall under their limited lifetime duration. That being said, these warranties (like most auto part warranties) are probably both worthless in all reality. For Autozone, the likelihood of a failure in 1 year or less is highly unlikely. For Dorman, a failure years down the road would probably just fall under "normal wear & tear" thus allowing them to dust their hands of any responsibility (although I will say with Dorman being such a large outfit I've heard they're pretty good about standing behind their products, so...:notsure:).
    I've been running the Dorman wheel bearing hub assemblies on both the LH & RH fronts for a few years now with around 25~30k on them. As was mentioned earlier, I'd consider what your usage & needs are and assess from there. I knew going into it Dorman wasn't some top tier brand or choice, that'd be OEM, but for my own personal needs I decided they were worth a shot given how cheap and easy/convenient they are to replace.
  10. Sep 18, 2021 at 3:16 PM
    TacoBell07
    Four door 2wd Taco
    Good to know about their warranty being AutoZone not Dorman burrito. Seems like the big 3 auto parts really play games with their brands and warranties alot. Remember when you could buy brake rotors and they were lifetime warranty but now no one has a lifetime warranty on rotors. Auto parts available by brand seem to be getting less and less where you have to buy online to find anything halfway good.
    I really thinking of getting these to save time pressing bearing in the hub etc. but now I am thinking about buying the Moog wheel bearings and installing those in the original hubs.
  11. Sep 18, 2021 at 3:30 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    FWIW I got 1 on my driver side , just put it on . So too early to tell
  12. Sep 18, 2021 at 4:33 PM
    Too Stroked
    Tom
    Just a warning. Moog parts are not what they used to be at all. Beware!
    wi_taco, Key-Rei, Dm93 and 1 other person like this.
  13. Sep 18, 2021 at 5:27 PM
    TacoBell07
    Four door 2wd Taco
    Well what brands are good becuase Moog is only half way decent brand at a parts store anymore it seems.
  14. Sep 18, 2021 at 5:36 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I've got a couple of Beck/Arnley from RockAuto still in the box in the garage as well. I'm at 120,000 miles on the OEMs but will likely need to replace one or both in the next year. Current supply chain issues 'encouraged' me to go ahead and order a set. I'm pretty easy on my truck, we'll see how they do.
    steelcity2 likes this.
  15. Sep 18, 2021 at 5:37 PM
    Titanx85
    Titanx85 Well-Known Member
    AJ
    Between Lexington, VA and Richmond, VA
    2006 Red Tacoma crew cab long bed
    I got mine from rockauto.com and they have been on there for 5 and 4 years between the 2 with no issues.
    winkel likes this.
  16. Sep 18, 2021 at 6:04 PM
    Csharp987
    Csharp987 Navy Chief
    Bob
    Athens, Ga
    07' Prerunner | SR5 | 4.0L | Double Cab | Tan Interior
  17. Sep 18, 2021 at 6:08 PM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    I'm rocking a Dorman assembly on the passenger side. I replaced it before going to windrock Park and no issues yet. I have another hub assembly with the factory bearing in it for a spare so we'll see how long the Dorman lasts considering how many hubs I've gone through in the past 2 years
  18. Sep 18, 2021 at 6:13 PM
    Key-Rei
    Key
    Florida
    Why are you going through so many hubs?
    Also Windrock OHV park is pretty legit! :thumbsup:
    Sasquatch3153[QUOTED] likes this.
  19. Sep 18, 2021 at 6:20 PM
    CRev
    CRev Member
    Tennessee
    ‘21 DCSB TRD OR
    OP
    I had a 2012 DCSB PreRunner, where the front driver wheel bearing had cracked inside the hub, and allowed the grease to heat up and then im assuming escape. All due to Tennessee road work..:frusty:
    The passenger side was fine, since my front driver tire took the majority of the impacts. After discovering the bearings would need to be pressed, I looked into the Dorman replacement. It was an easy install, and I had zero issues with it. I actually posted a thread here leading me to discover what the actual cause was. It was unlike any wheel bearing issue ive ever seen, heard, or felt.
    But yes, the Dorman replacement was solid for me on my 12 PreRunner
    https://www.tacomaworld.com/threads/solved-metallic-rattle-i’ve-been-hunting-for-days.607075/
    Page 2 of the thread has the result, with the exact Dorman Part # youre looking at.
  20. Sep 18, 2021 at 6:34 PM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    I'm thinking install error possibly. Also thinking the A-trac system and wheel spacers are playing a hand too :notsure:
