Dorman rear axle assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Arrow2013, Jul 24, 2023.
  1. Jul 24, 2023 at 9:09 AM
    Arrow2013
    Arrow2013 [OP] Active Member
    Has anyone purchased Dormans rear axle assembly? Any opinion? Looking to replace my wheel bearing but I don't have the press to just do the bearing. I came across the entire axle assembly but can't find much review on them.
  2. Jul 24, 2023 at 9:34 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Haven't come across a review or seen one mentioned either. Most I suspect would (i) pull the axles and take them to a place to have the bearings installed, or (ii) install a used rear assembly from a wreck.
  3. Jul 24, 2023 at 10:00 PM
    TacoTuesday1
    FL
    Dorman probably sucks.
    Used is probably overpriced and hard to find.
    Why don't you buy a cheap press from HFT and DIY?
    Or take them out and take to Toyota dealer ask how much for a tech to replace them with shafts already out, given they likely have the special tool
    the special tool is $130
    can be sold later or rented out
    I've seen presses as low as free on craigslist
    on second thought,
    you may be able to find an entire rear axle for as low as $300 used.
    Keep the third member as a core to regear later,
    and pull the shafts to put new bearings in your spare time, so they can swap in.
    Maybe spin (or have a shop or driveshaft shop do it) on a lathe or similar device to check straightness and inspect.
    however I don't know if there's submodel differences...
  4. Jul 25, 2023 at 1:16 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Dorman is a decent low budget parts supplier. They can be hit or miss, but overall I've found their quality to be OK. Never tried their axles though.
  5. Jul 25, 2023 at 8:57 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I don't have any direct experience with a Dorman rear axle assembly, but I deliver wholesale parts for a large (39 dealerships) automotive group that includes 4 Toyota dealerships. My personal experience with Dorman parts - and talking to our customers every day - is that as a whole they are the Harbor Freight of auto parts. Does that answer your question?
    Bivouac likes this.
  6. Jul 25, 2023 at 9:12 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Comes down to how hard you use the truck !
    How fast do you need to do the job??
    If you don`t know what your doing so many shops mess this job up.
    There products can be hit or miss!
    Good luck!!
