dorman oil filter cap issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by choocad, Oct 4, 2019.
  1. Oct 4, 2019 at 6:01 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I don't even torque for oil changes. Going on six years and three Yotas with this system, I'm yet to experience a problem.
    (Done all my own changes, including the freebies)
  2. Oct 4, 2019 at 6:02 PM
    Dens71TA
    Dens71TA Well-Known Member
    2014 SR5 ACLB 4x4 2.7L A4
    Whenever possible, never buy anything with Dorman, HELP!, or Motormite in the name!
    GreyBaldTaco likes this.
  3. Oct 4, 2019 at 6:07 PM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    I usually just torque it because I already do the lug nuts while I rotate tires, so I figure why not. As you’ve mentioned though, either way, the plastic housings are plenty tough.
    jmneill[QUOTED] likes this.
  4. Oct 4, 2019 at 6:07 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    What do u mean? U tighten the housing with just your hands??
  5. Oct 5, 2019 at 5:23 AM
    jmneill
    SE
    No, I hand tighten, but with a with a 3/8 or 1/2 ratchet. Just don't break out the split beam for oil changes..
    Skydvrr[QUOTED] likes this.
  6. Oct 5, 2019 at 10:20 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    I secretly laugh every time I see someone post they removed the glass fiber reinforced nylon housing to install a die cast aluminum housing...because it's stronger
  7. Oct 5, 2019 at 12:47 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Plastic is utilized for cost and weight, and yes, it's plenty tough.... for a while. The environment it operates in will eventually cause it to deteriorate, not to mention install and removal stress/wear. Aluminum is used in this application because the service life on every front is significantly longer... that info comes right from Toyota.
    StillNoPickles likes this.
  8. Oct 5, 2019 at 12:53 PM
    StillNoPickles
    2020 RAV4 Hybrid LE
    Been using them for about 6 years now in 2 different Toyota’s that have seen temperature ranges of -40 to 120. Never seen them deteriorate. I also however don’t over-tighten them. While aluminum may be better, the plastic is plenty strong and has proven to be. The few instances in which I’ve seen them broken is because people tighten them far too much or don’t know which way it spins off and actually crack the housing by accidentally tightening it more.
  9. Oct 5, 2019 at 9:57 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yup. Aren't there valve covers that're plastic? Oil pans even?
