dorman oil filter cap issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by choocad, Oct 4, 2019.
  1. Oct 4, 2019 at 12:13 PM
    choocad
    choocad [OP] Member
    2019 Tacoma SR5
    Bought and installed metal filter cap 1st week of september. changed oil for 1st time then at 5k . This week got call at home from fellow tech to check my vehicle, left large puddle of oil in shop. Had left taco running while I cleaned bugs off ws before going home for the day. Sure enough found approx 2 quarts low because of filter leaking. Was 35ft lbs tight as was drain bolt at filter , when I removed it today to put original plastic back on. No nicks on o rings, housing at engine smooth. Compared to original housing cap, appears large O ring more flush on metal cap than the one on the original cap. No oil leaks since reinstalled original one. I Am a 40 year GM tech and I ALWAYS check my oil changes running after I do LOF . Did not see any oil leaks on garage floor then and drove at least 500 miles, until I got back home yesterday when received call from fellow tech. Filter appeared to be leaking around the large screw thread area where cap meets housing . Guess I'll stick with original parts, now to seek refund from Advance auto parts .
  2. Oct 4, 2019 at 12:15 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    You can always get the Toyota metal housing off Amazon.
    TacoJova and wahoobie like this.
  3. Oct 4, 2019 at 12:50 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
  4. Oct 4, 2019 at 12:59 PM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Stick with OEM whenever possible.
  5. Oct 4, 2019 at 1:05 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    I think I got my OEM metal cap for about 15 bucks. Never had an issue.
    G.
    GreyBaldTaco likes this.
  6. Oct 4, 2019 at 2:27 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Last year I bought the OEM metal filter cap and it leaked.
  7. Oct 4, 2019 at 2:33 PM
    GreyBaldTaco
    2019 F150 5.0
    Were the O rings properly installed?
  8. Oct 4, 2019 at 2:35 PM
    Grossomotto
    2017 4WDV6LB6MT
    Everything was installed right and correct filter. Even double checked after. I put back on the plastic cover. Didn’t want Toyota giving me shit if I had an issue under warranty.
  9. Oct 4, 2019 at 2:35 PM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    To be honest I’ve never seen anyone have issues with the plastic ones. If you torque to spec, they’ll come off just fine.
    rtzx9r and Grossomotto like this.
  10. Oct 4, 2019 at 2:36 PM
    GreyBaldTaco
    2019 F150 5.0
    Interesting
  11. Oct 4, 2019 at 2:38 PM
    xsf18cdf
    xsf18cdf Well-Known Member
    Gary
    Texas
    2019 TRD/OR/DC/LB/QS
    None
    There's no difference in a 2016 and a 2019 is there? Just went to Amazon to pick up this kit and says it doesn't fit a 2019? Says it fits a 2016 though.
    Thanks,
    G
  12. Oct 4, 2019 at 2:39 PM
    Grossomotto
    2017 4WDV6LB6MT
    I’m all for OEM everything, but didn’t want to deal with a warranty issue. Like if you put Tundra brakes on and go in for a master cylinder warranty, you’ll get denied if they notice.
    Everyone always quotes the Magnuson act and saying Toyota has to prove this or that. The fact is they don’t have to prove anything and oftentimes tell owners to fuck off.
    Skydvrr and GreyBaldTaco[QUOTED] like this.
  13. Oct 4, 2019 at 2:52 PM
    GreyBaldTaco
    2019 F150 5.0
    Wait.... We can upgrade to tundra brakes?
  14. Oct 4, 2019 at 3:23 PM
    Grossomotto
    2017 4WDV6LB6MT
    Tundra everything, it’s not easy but people do it. You could probably fit a 5.7L in there. With wider fenders.
  15. Oct 4, 2019 at 4:07 PM
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    Come on bud.. 40 year gm tech and you go for a dorman product on your new truck? Shame on you.. Ha!
    I've seen the good dorman products, and the shitty dorman products. I wouldn't use anything dorman on a new vehicle.
  16. Oct 4, 2019 at 4:51 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    One or both of the following issues is happening. Toyota may have different tolerances for the vehicles that employ either the alloy vs plastic cap, and/or their machining tolerances are a tad sloppy for this particular part. I have even seen new oil filter brackets (that is the part the cap screws into) that did not have the female threads machined in deep enough for any cap to seat properly.
  17. Oct 4, 2019 at 5:24 PM
    choocad
    choocad [OP] Member
    2019 Tacoma SR5
    Yes, i too have used doorman products in past when could not get Gm parts that were discontinued etc, I did not at the time, seethe official Toyota part for Avalons that are metal and would work understand about mfgr's tolerance slop that can and I suspect contributed to my issues. Just thank God it didn't cost me an engine . Am curious however, does this vehicle have a low oil level sensor AND does it monitor and report during driving. ?
    specter208 likes this.
  18. Oct 4, 2019 at 5:30 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    No. If it fits the '16 it will fit the '19.
    They just haven't updated the ad to reflect the newer year. Same thing will happen if you searched for a 2019 battery, etc., etc. Or even an '18 battery a couple months ago. Even the big players are often behind the 8 ball..
    xsf18cdf[QUOTED] likes this.
  19. Oct 4, 2019 at 5:42 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Fuck doorman. Chinese junk.
  20. Oct 4, 2019 at 5:52 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Has an Low Oil pressure alert on the LCD screen. No oil pressure guage available standard.
