Door Window Belt Weatherstrip installation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by n3nman, Apr 25, 2025 at 6:38 AM.
  1. Apr 25, 2025 at 6:38 AM
    n3nman
    n3nman [OP] Member
    Lee
    2007 Toyota Tacoma
    Few
    Cannot find any video's on the 2nd Generation install on these. Do you just pull the old one's out and slide these in? No clips or anything.
    68164-04020 and 68162-04050 in question. Thanks
  2. Apr 25, 2025 at 2:33 PM
    Mossyjaws
    Mossyjaws Well-Known Member
    VA
    2015 dclb
    Footprint Gas Pedal
    Just replaced mine a month or so ago. Yes, there are a couple of clips that are on the window belt. I used a pair of pliers to grab the belt and pull up. Does require some force but they pop right off. New pops right back. Less than fifteen minutes and all four doors complete.
    Steves104x4 likes this.
  3. Apr 25, 2025 at 3:14 PM
    Black97v6MT
    Black97v6MT 364k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    27+ years of livin' Gen1 TacoLife...
    Will replacing this stop the window from chattering over bumps when rolled up all the way
    That sound is pure nauseating
    Roll the window down just a bit and it stops chattering
  4. Apr 26, 2025 at 4:14 AM
    Fish Taco 4x4
    Fish Taco 4x4 Well-Known Member
    NC
    2013 TRD OR
    265/70/17s
    The rear belts were straight forward but the fronts were a pain for me. I took off the inner door panel and the mirror, used pliers to pry the window belt off at the clips but after the first one it was easier.
    It didn’t fix my creaking noise that comes from the window seals when I did it. I can only get it to stop when I open the doors and coat all the seals with 303 Aerospace Protectant but it only lasts for a few weeks.
    Black97v6MT[QUOTED] likes this.
  5. Apr 26, 2025 at 4:17 AM
    Black97v6MT
    iMA0
    tacoLand USA
    do you have the original glass still?
    as far as i recall the chattering i have all started once an aftermarket window was installed after the original was broken out from some vandal in a lot
  6. Apr 26, 2025 at 4:22 AM
    Black97v6MT
    iMA0
    tacoLand USA
    you are referencing these?
    and not the glass run channel weatherstripping that the window slides on inside the door?
  7. Apr 26, 2025 at 4:41 AM
    Fish Taco 4x4
    NC
    2013 TRD OR
    265/70/17s
    Yes I’ve got the original glass still. The sound I’m referring to is the creaking squeaking noise from the window seals that a lot of people get.
  8. Apr 26, 2025 at 4:46 AM
    Black97v6MT
    iMA0
    tacoLand USA
    i have a chatter sound (single cab 4wd with crank windows) that can be heard right behind the left ear in the top corner. at least i think that is where it is coming from
    the glass ALSO seems loose in the channel... when fully rolled up you CAN move it up and down in the corner when placing a hand on there, but not sure if that is normal or not :notsure:
    i shall have to keep that ear open to the noise you are referencing, not sure i have noticed it from that area (yet) LoL
    thanks!
    Fish Taco 4x4[QUOTED] likes this.
  9. Apr 26, 2025 at 5:09 AM
    Jbjamn
    Jbjamn Member
    SE Wisconsin
    Black97v6MT likes this.
