Door speakers not working, only speakers on dash work.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Heavytowing954, Feb 19, 2023.
  1. Feb 19, 2023 at 1:07 PM
    Heavytowing954
    Heavytowing954 [OP] New Member
    2021 toyota tacoma
    I have a 2021 tacoma with the non jbl stereo and only the speakers on the dash work, I get no sound from the door speakers. Already check the fader and nothing from any door. Any ideas?
  2. Feb 19, 2023 at 1:12 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Pull the HU and check the connection. If not a connection the amp may be dead. This assumes all speakers are not dead, have you tested a speaker so you sure it’s not a speaker issue? Is it still under warranty?
  3. Feb 19, 2023 at 2:01 PM
    Spielightdude
    Spielightdude Well-Known Member
    Joseph
    Canterbury
    2023 TRD Offroad
    The door speakers are fed power from a bypass connector on the bottom of the dash tweeter location.
    The signal comes from the head unit to the plug on the tweeter thay then feeds to the front door speakers. Otherwise either head unit speaker wiring.
    Non jbl system not sure if it also has an amp but I know the jbl system does.
  4. Feb 19, 2023 at 2:27 PM
    Heavytowing954
    2021 toyota tacoma
    So should I start by checking the connection on the tweeters on the dash?
  5. Feb 19, 2023 at 2:41 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. Your door speakers are down stream from the dash speakers so if the dash speakers work and the door speakers don’t then you have a disconnect between the two. See the attached schematic.
    • 41.pdf
      File size:
      43.4 KB
      65
    soundman98 and Spielightdude like this.
  6. Feb 19, 2023 at 3:20 PM
    Spielightdude
    Joseph
    Canterbury
    2023 TRD Offroad
    Captqc is correct. On the back of the dash tweeter is a white clip on the back of the tweeter that is the pass through point from the tweeters to the door speakers.
  7. Feb 19, 2023 at 3:23 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    The fact that all the door speakers are not working, but the tweeters are is odd. If the tweeters are working then the front doors should also. So we need some more info here from you.
    Have you done anything to your doors recently? Have you had any service work done on your truck?
    The only thing I can think of here is that all 4 door panels have been removed and the speakers have been unplugged and never plugged back in.
    Chew and soundman98 like this.
  8. Feb 19, 2023 at 3:51 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Turn it up loudah!
    Ernz671 likes this.
  9. Apr 16, 2025 at 7:09 PM
    rotus
    rotus Well-Known Member
    Cypress, TX
    2020 White DCSB TRD OR
    Dragging this up from the dead. I have a similar problem, but my rear door speakers work. I checked continuity from the dash plug to the door and that is good. I though maybe the capacitor in the dash speaker went out, so I tried another set, same result. Both sets of dash speakers I have are kicker. Door speaker is also kicker. Any ideas?
