Door sill trim removal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChadVKealey, Jun 1, 2017.
  1. Jun 1, 2017 at 5:18 AM
    ChadVKealey
    ChadVKealey [OP] Well-Known Member
    Philadelphia, PA
    2017 Silver Sky Tacoma SR5
    None (yet)
    Are there any particular tools or tricks needed to remove the trim panel between the door sill and the driver's side seat? There's no obvious hardware visible, so I'm assuming it's snapped in with Christmas tree clips or the like, but wanted to be sure before I break something. I also need to remove the driver's side kick panel, which I assume is fastened the same way?
    FWIW, these need to be removed to get to the brake controller wiring plug and install the ESP P3 controller mount in the cubby to the left of the steering wheel.
  2. Jun 1, 2017 at 5:45 AM
    NY Taco
    NY Taco Well-Known Member
    Rochester, New York
    2017 Inferno Sport DCLB
    Leer 180 Cap, Beat Sonic Navi By-Pass
    The cover on the sill just snaps in, just pull up on it. The kick panel does have one nut (top right) that would need to be removed before unsnapping it.
  3. Jun 1, 2017 at 6:47 AM
    ChadVKealey
    Philadelphia, PA
    None (yet)
    Probably a 10mm bolt/nut, like the ones below the dash?
  4. Jun 1, 2017 at 7:10 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Nope, a plastic "push nut" comes off easy with your fingers, at least mine did!
  5. Jun 1, 2017 at 7:39 AM
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
  6. Jun 1, 2017 at 7:55 AM
    NY Taco
    Rochester, New York
    I do think it's 10mm, but mine did turn with my fingers too.
