Door seals constantly squeak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Priddle, Aug 1, 2012.
  1. Aug 1, 2012 at 12:06 PM
    Priddle
    Priddle [OP] And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    When I'm driving, there is a bad squeaking coming from both doors (driver and passenger), above the windows. I think I narrowed down to the seals against the body. When I open both the drivers side and access cab doors, and then close just the driver door, I can tell the seal squeaks on the painted body surface. I tried waxing the body surface where the seals meets it and armour-alled the seals but without even test driving it, closing just the driver door and applying different pressure recreates the seal rubbing squeak.
    Is the seal gone bad or does the door need to be tightened? The door appears solid on its hinges to me and the locking mechanisms on the access and driver door seem solid.
    Any advice is appreciated.
  2. Aug 1, 2012 at 12:11 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I clean / lube my seals / gaskets / weatherstrip with Aerospace303
  3. Aug 1, 2012 at 12:29 PM
    Squisha
    Squisha Well-Known Member
    Westminster, CO
    99 Taco Reg Cab 4x4
    Try some silicone lube? The kind you can use on rubber.
  4. Aug 1, 2012 at 1:19 PM
    Priddle
    Thanks. That was my next plan although I thought that may be hiding the symptoms versus fixing the root cause.
  5. Aug 1, 2012 at 1:19 PM
    graywolf2011
    graywolf2011 Well-Known Member
    Orlando Florida
    11 Tacoma 4X4
    undercover hard toneau, stainless steel nfab step bars
    Ive tried everything on mine(not 303), still does it, sounds like peeling tape off or something sticky, not a squeek though. Went to dealer and looked at a new one, did the same thing, must be the type of rubber the weatherstrip is made from.
  6. Aug 1, 2012 at 2:37 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Everytime I detail the interior of the truck, I wipe all the seals with whatever I am using for the interior. Lately it's been Turtle Wax Ice, nice smell, no high shine, ... and no squeaking seals ever. Make sure your door hinges are tight/aligned.
  7. Aug 1, 2012 at 3:06 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    just spray some sillycon lube on a paper towel and wipe the rubber gaskets down with it.
    JAMES399 likes this.
  8. Aug 1, 2012 at 3:11 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Spray some silicone (not WD-40) on a rag and wipe the rubber seals ... helps to stop squeaks and rubber will last longer too.
    A racing guy that I know even sprays silicone on his CV boots and etc. (works basically on almost anything that is rubber).
  9. Aug 28, 2012 at 6:39 PM
    Toyoghi
    Toyoghi Well-Known Member
    Shoghi
    Calgary, AB
    2011 Tacoma Double Cab
    Solid tri-fold Tonneau, Deezee Bed mat, Pop n Lock.
    I have had this problem on my truck since last october when I bought my truck. I thought it was just mine!! Kinda relieved to hear it's not.
    Keep me updated if you fix it.
  10. Sep 5, 2012 at 6:02 PM
    Priddle
    I seemed to have gotten rid of the squeak. I cleaned the painted surface where the seal meets and waxed it. I put Armor All on the rubber itself. It's been a month and still no squeak.
  11. Nov 5, 2012 at 1:58 PM
    Bsfilter
    Bsfilter Well-Known Member
    Bob
    San Pedro, CA
    08 4.0 AC 2WD SR5 TRD OR/RT
    Awesome! My 08 Access Cab is doing this and it is driving my anal retentive ass crazy. Your fix is EXACTLY what I intended on doing to try to fix the squeaking/rubbing sound. I'm on it tomorrow morning and will report back with results as well.....
  12. Jun 26, 2013 at 4:44 PM
    tgoatman
    tgoatman Active Member
    Tim
    San Diego
    2013 DBL CAB 4X4 TRD OR
    Black powder coated wheels Tool Box Rock Sliders
    My truck is doing this relentlessly, driving me crazy. So, have you narrowed it down to where the glass goes in the window-track at the top of the door, or is is where the window seal meets the door on the outside?
    Dealer has seen the truck 3 times for this, and can't fix it. Even opened a case with Toyota, but they can't figure it out either...
    Any help greatly appreciated.
  13. Jun 27, 2013 at 4:47 AM
    Priddle
    Read my earlier post. For me its where the rubber door seal meets the painted surface. After a year mine is doing it again. It is really bad when I pull into my work parking lot that has a slight grade at the entrance. The truck chassis flexes and all the rubber seals on the doors squeak. I need to wax the paint and armor all the rubber seals again.
  14. Jun 28, 2013 at 9:51 AM
    tgoatman
    Tim
    San Diego
    OK, I'll give it a try today, and will also hit it with silicone lube.
    This truck has been the biggest surprise ever - meaning I'm surprised at the NUMEROUS quality and build issues it has. Considering it's the 8th year of this model, and all these issues are well documented with thousands of customers experiencing them, I'm utterly disappointed in Toyota.
    Do you also have the axle-wrap issue causing vibrations on acceleration? Mine has it so badly, the steering wheel shakes if I use even half-throttle through 1st and 2nd gear...
    My wife's Highlander, which carries a nearly identical sticker price to my Taco (dbl cab, TRD offroad 4X4) is a far superior car. The profit margin on these Tacos must be amazing considering how they cheaped out on everything.
    T
    Got2ryde likes this.
  15. Jul 17, 2013 at 3:39 AM
    Priddle
    I applied Armor All to the rubber seals and cleaned the painted surfaces and the squeaking it gone again, hopefully for another year. lol
  16. Jul 17, 2013 at 10:26 AM
    Aryota
    Aryota Rabbit n Pancakes vs. Chicken n Waffles
    Dave
    Central Arkansas
    09 Access V6 4x4 TRD-OR SR5
    My 09 Access cab has done this the entire year I've owned and it drives me crazy !! :mad:
    Thankyou, thankyou, thankyou for the tips on curing that annoying rubber seal squeek!
    Not a big fan of Armor All but do have some silicone spray in the garage.
    Will be breaking it out tonite for sure! :D
  17. Aug 14, 2013 at 8:31 PM
    jabarth
    jabarth New Member
    Butte, MT
    12 6-speed 4.0l TRD Sport Black Pearl
    I too have horrendous door seal noise, it started before 5k miles and mostly on the drivers side only a bit on the passengers side under harder flexing. At the contact surface where the rubber meets the paint there are wear marks from the movement of the door ~3/8" wide around nearly the whole door. But, it makes most of the noise right by my left ear up top.
    I'm going to clean the seals and a wipe them with silicon, but I too felt this was a bandaid fix. If it's not just me I suppose I have to accept it.
  18. Aug 15, 2013 at 4:42 AM
    Priddle
    My wife's 2012 Kia Sportage does this too. I figure it is not specific to Tacomas. if the above fix lasts a year, then its not a big deal to me.
    Since I redid mine, it is still quiet.
  19. Aug 20, 2013 at 10:19 PM
    tgoatman
    Tim
    San Diego
    So I decided to go in for a closer look. This is simply a design flaw - the window channel seal rubs on the inside of the door channel where it sits when the truck chassis has any flex at all. Eventually, this will wear out the paint, and the long term will be that moisture will get trapped in there, I'll end up with rusty doors...
    Silicone lube fixes it right up, and given that it's pretty tightly sealed in there, I think it will last a while, but how utterly disappointing to find yet another (in addition to the axle wrap situation) known quality problem with these trucks that Toyota couldn't care less about.
    I'll tell you one thing, my 42 year old GMC doesn't have this problem!
  20. Aug 20, 2013 at 10:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Silicone paste, learn to love it!
