Door seal size?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Sep 27, 2020.
  1. Apr 12, 2021 at 12:32 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Portland, Oregon
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Ok, so the weatherstripping I posted above works out very well considering the price difference. The lip is a tad longer than original, which I can trim or find a shorter one. I plan on posting more pics later but for now here are the profiles/ crossections of the new one linked above and the oem original. I’m working on a source for the sponge rope inside the oem but it’s totally possible to re-use that. New on top, old on bottom.
    TWJLee likes this.
  2. Apr 13, 2021 at 10:08 PM
    jnossoff
    jnossoff 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
    My reference vehicle is my 2000 Extracab PreRunner.
    @Rastopher ! Great research, thank you SO MUCH for sharing your information.
    @Kristi with a K Thanks for bringing up the subject.
    I was not aware there is a sponge "rope" inside the existing OE door seal.
    As I press the full length of the existing OE door seal it seems that there is sponge "rope" inside some sections of the hollow tube, and other sections remain hollow. The "rope" is not continuous. Perhaps only at high impact "pinch points"? Any one else checked this out?
    If it is not continuous then it would be difficult to properly place replacement "rope" in a hollow (new) seal. It would prove challenging even to feed a continuous rope through the length of the seal's hollow tube (like trying to feed a cooked spaghetti through a drinking straw?). Perhaps feeding a "fish" wire through the tube and pulling the "rope" through?
    I have been using a product to temporarily (6 years!) repair the part of my driver's door seal that is torn up (just like the left edge of the driver's seat, it got torn up through repeated entries and exits.) This product could maybe function as the "rope" inside the seal's hollow tube? Here is the product, which I purchased at O'Reilly Auto Parts:
    SuperStik Weatherstrip at O'Reilly's Auto Parts https://www.oreillyauto.com/detail/...06f1fa10/carrand-weather-stripping/hopc/01058
  3. Apr 14, 2021 at 1:28 AM
    Rastopher
    Ras
    Portland, Oregon
    I have a link for the real deal insert, but it’s on my other laptop. I’ll post it tomorrow.
  4. Apr 14, 2021 at 1:44 PM
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    Rastopher likes this.
  5. Apr 14, 2021 at 2:48 PM
    Rastopher
    Ras
    Portland, Oregon
    Good initiative! Some people have used that, and probably with some success. But (unless I have fundamentally misunderstood) it’s not the right material. The material isn’t closed cell rubber for repeated crush and release, so it would probably fall apart very quickly. Here’s an alternative that is pretty much exactly the real deal: https://www.grainger.com/product/TRIM-LOK-INC-Rubber-Seal-10G532?opr=APPD&analytics=altItems_10G523
  6. Apr 14, 2021 at 2:50 PM
    Rastopher
    Ras
    Portland, Oregon
    Glad i can help! The insert is in the top corners, i’ll get a picture or two tonight.
  7. Apr 14, 2021 at 7:46 PM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    So I was close. Just missing that extra flap. Good find. Thank you for picking up the mission. Leaf springs, wheel bearing & power steering pump have held me hostage.... Just ordered front diff bushings.... & I'm not sayin' you're just sittin' around twiddlin' your thumbs.... simply, thank you....
    Rastopher[QUOTED] likes this.
  8. Apr 14, 2021 at 7:51 PM
    Kristi with a K
    Western MA
    Thanks! Even if it's not weatherstrip, sounds like a good roadtrip :thumbsup:
  9. Nov 13, 2021 at 3:39 PM
    Kristi with a K
    Western MA
  10. Nov 14, 2021 at 3:06 PM
    Rastopher
    Ras
    Portland, Oregon
    Looks like they used it to replace the section on the bottom, but not all the way around. It makes sense.
  11. Nov 14, 2021 at 3:24 PM
    Kristi with a K
    Western MA
    I didn't take it that way. Just that they doubled up on the bottom by using an extra (leftover) piece. You could be right though.
    Did you get any further with what you were trying? I have backshelved this long enough....
  12. Nov 14, 2021 at 4:16 PM
    Rastopher
    Ras
    Portland, Oregon
    What I bought works, but it isn’t what I would call a good fit. It takes a bunch of trimming, it’s about 1.5 mm too large in every dimension.
